MSI Z370 SLI PLUS: Issue Accessing Boot Menu for USB Install (F10, Delete not working)
Mati140D 10584 8
  • #1 17369870
    Mati140D
    Hello, I have a problem with entering the boot menu. I am trying to install from a flash drive and I cannot enter the boot menu with Delete F10 or all the other buttons.
    Motherboard: MSI Z370 SLI PLUS
  • #2 17369881
    Robert B
    Help: 2027
    Rate: 1412
    Mati140D wrote:
    all other buttons
    :lol:
    Is only one for this purpose and described like a bull on page 41 of the instructions.
  • #3 17369906
    Mati140D
    Robert B wrote:
    Mati140D wrote:
    all other buttons
    :lol:
    This is the problem, I tried it and nothing zero all buttons in the manual do not work, only what it pops up, "Reboot and select proper Boot device or insert boot media in selected boot device and press andy key"
  • #4 17369917
    Robert B
    Help: 2027
    Rate: 1412
    The message means that the BIOS cannot see the disk. Damaged? Can you see it in the BIOS?
  • #5 17369922
    Mati140D
    The BIOS cannot see the disk because sometimes it says "Start booting from USB device ... Remove disks or other media."
  • #6 17369926
    Robert B
    Help: 2027
    Rate: 1412
    After all, the disk is USB or connected to the disc? Show the appropriate BIOS screens.
  • #7 17369930
    Mati140D
    I wrote on a pendrive
  • #8 17369932
    Robert B
    Help: 2027
    Rate: 1412
  • #9 17369951
    Mati140D
    Robert B wrote:
    Thanks for helping, but the problem is solved. The problem was a faulty usb port, I changed it and everything is fine
The discussion revolves around an issue with accessing the boot menu on an MSI Z370 SLI PLUS motherboard for USB installation. The user reports that standard keys (Delete, F10) do not work to enter the boot menu. Responses suggest that the BIOS may not recognize the USB drive, possibly due to a faulty USB port. After troubleshooting, the user resolves the issue by changing the USB port, allowing successful access to the boot menu and installation from the flash drive.
