[Solved] Accessing BIOS Menu on MSI Plate & CD: Adjust Memory Voltage & Settings - TONI_2003
raiwan 99311 8
  • #1 4350784
    raiwan
    Rate: 18
    How to enter the bios menu in the msi CD in which you can check and possibly change the memory voltage, etc. ??
    Correct posts in this topic.
    TONI_2003
  • #2 4350806
    Stingerek
    Help: 81
    Do you have manuals?
    Usually the delete or F2 key
  • #3 4350873
    raiwan
    Rate: 18
    well, with the fact that when I enter the bios, there is no menu to change the voltage and he knows how to do it because in the submenu there is no such option and there is no manual ...; (
    TONI_2003
  • #4 4350913
    halik_ltd
    Help: 54
    Enter the name of the board, memory type and speed, and the exact designations of the power supply.
  • #6 4351399
    psssik
    Want to tweak anything on this album?
    This is a typical office album and I don't think it has any over-locking capabilities.
  • #7 4352942
    halik_ltd
    Help: 54
    In bios, in the "Frequency / Voltage" tab, you have the option to change the frequency of the FSB bus, as well as the memory and AGP voltage
  • #8 4353712
    raiwan
    Rate: 18
    Sorry guys that I'm turning four letters :) but in my bios I don't have this function :( even after updating the bios ...
    I do not know if there is any program for this or only in bios, you can do ...> ??
    Added after 13 [minutes]:
    Well, the matter became clear :)
    The problem was solved after updating the BIOS :)
    Such a fuck, and so much trouble and nerves made me :(
    Thank you for all your help :)
  • #9 17335743
    rafalwit
    Rate: 41
    There is also the F11 Boot menu. But I haven't found out if the input is a Del key or something else.
    And for me, after updating Windows 10 32-bit, it broke the system selection menu. And it forced me to boot a slow 32-bit Windows from a regular SATA drive. I have 3 operating systems Still Windows Xp and WIndows 10 64-bit from a new SSD.
    I was able to enter the Boot Menu via F11 and select one of the old drives, from which the selection menu for each of the 3 systems is displayed. I would only like to enter Bios to consolidate this charging scheme, so as not to keep pressing the F11 key all the time. now it has changed by itself that it prefers the faster win 10 system with SSD.
    Finally I found that there is a DEL key to enter the MSI Bios. But decent documentation is missing. you need to master these changing the default disk to run.
The discussion revolves around accessing the BIOS menu on an MSI motherboard to adjust memory voltage settings. Users suggest using the Delete or F2 key to enter the BIOS. However, one user reports not finding the necessary options to change voltage settings, even after updating the BIOS. Another user mentions the "Frequency / Voltage" tab in the BIOS where adjustments can be made. The conversation also touches on the F11 Boot menu for selecting operating systems, with a note that the DEL key is used to access the MSI BIOS. Ultimately, the original poster resolves their issue after updating the BIOS, which enabled the desired settings.
