ELM 327 OBD II does not work under Windows 10
ymek007 20259 2
  • #1 16434878
    ymek007
    Hi, I have cables as above but I can not install it under Windows 10 :( did anyone have a similar problem and could help me?
    in info about the driver I have something like:
    USB \ VID_067B & PID_2303 & REV_0300
  • #2 16435022
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    From my experiences (amateur for my own use) I remember that the correct cooperation of diagnostic "interfaces" ends on Windows XP.
  • #3 16435246
    pepe150
    Level 36  
    Help: 288
    Rate: 940
    2303 - shows that he is sitting at Profilic.
    It depends on version 2303 which was sitting there.
    Sam I have ELM327 on Profilic2303 I just do not remember with which terminal and works on max Windows 7. About Windows 8, 8.1, and 10 I can forget.
    There are programs to check what version is layout. e.g. here: CheckChipVersion
    edit:
    I found.
    "Windows 8 / 8.1 / 10 are NOT supported in EN-2303HXA and PL-2303XEOL chip versions.
    Run PL2303 CheckChipVersion tool program in Windows XP / Vista / 7 is check chip version.
    Windows Vista, XP, 2000, 98 and Windows ME driver technical support are discontinued.
    Prolific recommends to use PL-2303HXD (HX Rev D) or PL2303TA chip. "
