[Solved] JBL Charge 3 Won't Turn On: Connect+ Button Issue & Troubleshooting Tips
Domson1800 20679 5
  • #1 17236173
    Domson1800
    Rate: 29
    Hello, I pressed the speaker jbl charge 3 Connect and plus and I don't want to turn on what to do?
  • #2 17236195
    Pedros050
    Help: 2471
    Rate: 3921
    Hello. Undress and see what has broken?
  • #3 17237420
    Domson1800
    Rate: 29
    Turns on only under the charger but you can't do anything
  • #4 17358583
    Hego 2467
    Rate: 18
    Yes I do
    Maybe you already know what's going on
  • #5 17358737
    bbobii
    Help: 122
    Rate: 83
    After all, this new device is therefore under warranty.
  • #6 17520090
    xares_23
    Rate: 49
    Hello ... Well, I tested the combination on my speaker and I was able to figure it out, you need to connect the speaker to the charger and wait for it to turn on then connect and plus then the speaker will turn off and then it will work normally
