Exhaust Gas Temperature Sensor Issue on Passat B6 2010 2.0 TDI CR: DPF & Turbine
Honda 133 18210 11
  • #1 17402574
    Honda 133
    Hello Passat b6 2010 2.0 tdi cr
    I have a problem with the exhaust gas temperature sensor and the yellow spiral light turns on. The mechanic diagnosed that it was a sensor for dpf and replaced it, it cost a lot of money but it is still the same and he wants to replace another one, but the one at the turbine. Did you have a similar problem?
  • #2 17402680
    Pedros050
    Help: 2471
    Rate: 3918
    Connect the diagnostic tester and read errors from the controller. And change the workshop, since this mechanic cannot diagnose the fault.
  • #3 17402696
    szymitsu21
    Help: 342
    Rate: 1292
    Probably replaced the wrong sensor.
    There are two for sure and I don't know if not three.
  • #4 17402714
    jurekk55
    Level 36  
    Help: 182
    Rate: 1577
    Most sensors can be simulated. Why is it replaced with a stick?
    Find a reputable workshop that will check the sensors, installation, controller.
  • #5 17402722
    Arton
    Help: 14
    Rate: 62
    But this with an ordinary meter can be checked
  • #6 17402728
    Pedros050
    Help: 2471
    Rate: 3918
    As with 170KM this B6 is one before DPF, one behind DPF, one in front of the turbine. Total 3.
  • #7 17402773
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4171
    All B6 with dpf have 3 exhaust gas temperature sensors.
  • #8 17402944
    Honda 133
    The mechanic claims that the computer first showed that the dpf one is damaged And now he says that it showed that at the turbine and I'm only curious if it is possible that two would have fallen immediately?
  • #9 21904123
    maciejlawski1982
    >>17402574
    Bad diagnosis, I'm betting on the one before the turbo. Common error.
  • #10 21904256
    carrot
    Moderator of Cars
    Help: 1311
    Rate: 3575
    These sensors can be checked with an ohmmeter, a couple of MΩ at ambient temperature, and that the measuring element does not stick to the ground
  • #11 21904392
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4171
    The mechanic misread the error... The sensors can be checked in the parameters as someone is already reading the errors with a tester. The error code is also exact about which sensor is involved. All you have to do is read what the diagnostic equipment shows. Whatever it may be.
  • #12 21904473
    masay1
    Help: 40
    Rate: 81
    Gentlemen so can't quite agree with what you write.... often the descriptions in the VCDS of course I mean the original tester has errors in the numbering of the exhaust gas temperature sensors.... it is not at all that difficult to give a wrong reading of what the tester describes.... even VW itself had errors in the descriptions and this was in both the VAS 5054 and the first Odis.... on this subject there were several TPI service bulletins issued by VW which "straightened out" the errors in the diagnostic software.... on 1.6 tdi engines and some 2.0 tdi PQ platform engines, the manufacturer introduced an update of the engine controllers, because the engine controller itself already had a so called error code mapping error.... unfortunately having good equipment and "trusting him" you can get run over, that's why I would be far from a hasty assessment of this mechanic....
    unfortunately, but modern diagnostics can be quite complicated, and if we add to this the errors in the software of car manufacturers themselves, with which even authorized service are often helpless, it is difficult to blame anyone that acted in accordance with the logic and indications of the computer .... even worse, without being aware that they are becoming a victim of underdeveloped software.... even the aforementioned multimeter won't help much if the temp sensor has a "temporary break" or worse a disturbed hysteresis, and in the ECU the sensor G235 is systemically swapped with G495....
✨ The discussion revolves around an exhaust gas temperature sensor issue in a 2010 Volkswagen Passat B6 2.0 TDI CR. The user reports that after replacing the DPF sensor, the yellow spiral light remains illuminated, prompting the mechanic to suggest replacing another sensor located at the turbine. Responses indicate that the vehicle has three exhaust gas temperature sensors: one before the DPF, one after, and one in front of the turbine. Participants recommend using a diagnostic tester to read error codes and suggest that the mechanic may have replaced the wrong sensor. There is skepticism about the possibility of two sensors failing simultaneously, and advice is given to seek a reputable workshop for proper diagnosis.
