[Solved] PS4 DualShock Controller Connection Issues on Windows 10 PC: Bluetooth, DS4 Windows & Button Setup
Rossoneri92 17325 3
  • #1 17410094
    Rossoneri92
    Hello. I have a problem with the connection, and in total with the operation properly falls with PS4 under the PC. I connect via a bluetooth usb transmitter, connect to the pad via pairing buttons on the share pad and firing. The pad is connected correctly, it works but not as it should, i.e. the buttons are set up. Now, to make it work properly, you need to run DS4 Windows, and so I do and here the problem arises because in the controllers tab it does not show me this rain. I can not deal with it. I am looking for, I try different methods and it does not work. Maybe someone has had such a problem and knows how to solve it. My operating system is Windows 10 Pro. Once I did not have this problem worked as it should and now unfortunately does not work like that. Thank you in advance for your help.
  • #2 17410200
    Paweł1000
    Help: 58
    Rate: 70
    I connected this controller with a USB cable and in Steam the spacing of keys was OK.
  • #3 17411591
    Rossoneri92
    In steam so no problem, but the problem was from Origin and FIFA 18. I've already done it. Instead of DS4 Windows, I would like the InputMapper program to be as easy as possible. It works without a problem.
  • #4 17411599
    Rossoneri92
    Connection via bluetooth: If we have a connected adapter or a laptop, launch the PS and Share button on the pad simultaneously until the pad starts flashing in white. Next, he will show us the bluetooth device that we are pairing with, maybe the option to enter the pin may pop up, so we enter four zeros. As soon as we paired with bluetooth, we start the program InputMapper and after a while pops out information that it was found raining and to start it just press once on the central button or PS.
