[Solved] Xbox One Pad Bluetooth Connection Issue: Win10 PC with Gigabyte GC-WB867D-I BT Card
Yakers 3993 4
  • #1 16632999
    Yakers
    Rate: 43
    I have a pad from xbox one and I would like to connect it to BT in a PC with win10, I updated it and it works without a problem on the cable, but I don't want to connect via BT, I click the connect button and the logo is blinking but the pc does not want to detect it, I have a BT Gigabyte GC card -WB867D-I newest headsets. Do I just have to play on the cable or buy a receiver?
  • #2 16634210
    lysy1980
    Help: 207
    Rate: 322
    What PAD model? You can read the label under the battery cover. Model 1708 can be connected to a computer via BT - older only with a cable or an Xbox One Wireless Controller Adapter PC.
  • #3 16634246
    Yakers
    Rate: 43
    lysy1980 wrote:
    What PAD model?
    Well, the problem is that there is no label because someone peeled it off: /
  • Xbox One controller model identification by shell design
    #4 16634255
    lysy1980
    Help: 207
    Rate: 322
    If the casing around the button with the XBOX logo is uniform with the whole front - it is the 1708 model, if it is made of glossy plastic separated from the front and the RB and LB buttons, it is the older model without BT.
    In this photo you can see what I am writing about - the pad can of course be in a different color. On the left is the model from BT.
    http://digitalspyuk.cdnds.net/16/31/640x320/landscape-1470071350-xbox-one-s-controller-5.jpg
  • #5 17492741
    Yakers
    Rate: 43
    I had an old pad that didn't have BT
