PS4 Console - Unable to Connect to DualShock 4 Controllers: Reballing API, Service Mode Sync
maly_kowal 49623 13
Why will a PS4 not pair with DualShock 4 controllers in normal mode even though the controller works over USB in service mode?
The most likely cause is a faulty Wi‑Fi/Bluetooth module, since the PS4 uses the BT/Wi‑Fi combo for controller pairing; in some cases the related NOR area or bridge can also be responsible [#15493355] [#15504010] [#15519945] [#18190725] Check whether you have about 3 V on standby first [#15493355] If you already reballed the APU and the problem remains, try reballing the bridge before replacing the Wi‑Fi/BT module, because a module swap may only fix it temporarily [#18762239]
  • #1 15492506
    maly_kowal
    Rate: 12
    Hello, I got the Ps4 console. After turning on, the console will not connect to the pad. Tested on 2 different pads and the problem is the same, although in the service mode the pad is detected and works via usb, but only in the service mode, in normal operation, synchronization does not take place. So far I have reballed the API and the problem remains. Has anyone encountered a similar problem?
  • #2 15493355
    robin11
    Help: 57
    Rate: 160
    Hello.Probable damaged wifi module. Foto check if you have about 3v on standby.
  • #3 15502874
    iraz75
    As far as I know, the console communicates with the pad via Bluetooth, maybe there is a problem here. You can also reset the pad if you haven't tried it yet. If that doesn't help, the service will.
    https://www.youtube.com/watch?v=VNyT1PfodyY
  • #4 15504010
    robin11
    Help: 57
    Rate: 160
    As far as I know, BT / WiFi is in one. greetings
  • #5 15519945
    Viacomp
    I would also bet on problems with bluetooth.
  • #6 18190725
    dj_master0
    Rate: 28
    The software update is successful, are you popping up errors ?. If so, I bet on the wifi / bt module or the damaged Nor area responsible for wifi / by.
  • #7 18759015
    burzaxxx
    Rate: 78
    I have the same problem but the pad is cable Nacom.
    In the soft menu it works, but it does not work on the blue screen where there is information about the connection in several languages.
  • #8 18759907
    lysy1980
    Help: 209
    Rate: 324
    As far as I know and have dealt with some Chinese wired PS4 PADs, they do not work as the first / main PAD. The original controller must be connected first to initialize the console / login. Wired only worked in the console menu.
  • #9 18761778
    pawelGT27
    And tell me what corresponds to the board in the xbox pad one for blothooth? Where to look for the problem?
  • #10 18762239
    xbox-serwis.eu
    Help: 52
    Rate: 210
    Hi, before replacing the wifi / BT module, do a bridge reballing, I had some PROs like that, which is too bad :)
    I had one in which I replaced the Wifi module, it worked for 2 days, it came back, after the bridge was reballed, the problem disappeared.
    XBOX-SERWIS.EU
    Karmelicka 15, Kraków, 31-131 | Company Website: http://www.xbox-serwis.eu
  • PS button only flashes white after reset
    #11 20146743
    zibi.sdz
    Rate: 8
    Will heat up the cutlet a little.
    I have a similar problem with the PS4, after turning on the console, the image information on the blue screen about the connection falls with the USB cable and pressing the PS button. After connecting the cable, there is no reaction to the PS, in safe mode the same. As I press PS without cable connection, it displays an additional text message about cable connection and registration. Resetting it rains did not improve the situation and even worsened because the PS was previously loaded on the cable and not in this chili. Only white light flashes when PS is pressed. After the reset, the yellow light will light up for a moment. Can you handle it somehow or is it something thicker?
  • #13 20147297
    zibi.sdz
    Rate: 8
    Thanks. It does not look cheap, unfortunately. We'll see.
  • #14 20797428
    Albin
    Rate: 11
    What could have gone wrong with the pad if it works via Bluetooth (checked via Bluetooth from PC), but unfortunately it doesn't via cable and doesn't pair with the console?
The discussion revolves around a PS4 console that fails to connect with DualShock 4 controllers. The user reports that the controllers work in service mode via USB but cannot sync in normal operation. Various responses suggest potential issues with the Bluetooth or Wi-Fi module, as well as the possibility of a damaged NOR area affecting connectivity. Recommendations include resetting the controller, checking for voltage on the Wi-Fi module, and performing reballing on the affected components. Some users also mention that certain wired controllers may not function as primary controllers, requiring an original controller for initialization.
