Resolving Faulty Hardware Corrupted Page Error and Slow Internet Connection on Windows 10
rickysingh 6528 3
  • #1 17416319
    rickysingh
    Today when I booted my PC after booting I received an error Faulty Hardware Corrupted Page but this error resolved automatically but after this my internet connection slowed down to 50kbs. I searched a lot on google but nothing useful found. Anyone expert here who can help me to solve this issue.
  • #2 17416440
    paszczakq
    Help: 48
    Rate: 204
    What kind of internet connection U have ? By lan cable to modem , router , other ?
  • Suggesting SFC scan for corrupted system files
    #3 17421695
    imuser
    Hi @rickysingh
    This issue may occur due to incorrectly configured, old, or corrupted device drivers.
    Please follow the below methods and check if that helps.
    Method 1: Run the System file check (SFC) Scan and Repair System Files: The sfc /scannow command (System File Check) scans the integrity of all protected operating system files and replaces incorrect, corrupted, changed, or damaged versions with the correct versions where possible.
    This Guide by ValidEdge.
  • Incompatible drivers or faulty RAM causing BSOD
    #4 17541480
    shabnam9
    While using any version of Windows, we may face Blue Screen of Death which other name is BSOD. A list of error messages come out with a blue screen of death. Mostly these kinds of error messages which you will see on the Blue Screen of Death is the Faulty Hardware Corrupted Page. There are a lot of reasons behind this error but most of the time it's due to the incompatible drivers when you upgrade your windows to windows 10. It also due to the faulty driver or a faulty RAM. There are more than 1 methods to fix this issue.
    1- Update Drivers: To update the drivers, we can fix this issue. Write devmgmt.msc on Run Window and enter > double click Display Drivers > Right-click display drivers and select Update Driver Software… option > If internet connected then click Search automatically for updated driver software > When done then restart your PC.
    2- You need to Check your RAM and procedure to check the performance of the RAM contained at https://appuals.com/faulty-hardware-corrupted-page/ and this will definitely help to get rid of this error and more about other solutions.
