Bosch KGN36ML3P fridge - First start, power connection, temp display & alarm issue
Inżynier_Mamon 27633 9
How long should a Bosch KGN36ML3P fridge take on first start to reach the set temperatures, and is it normal for the alarm/display to behave like that at the beginning?
Yes — on first start you should give the fridge time to stabilize, because it can take up to 36 hours to reach the indicated temperatures, and only after about 48 hours would it be worth worrying [#17425992][#17425257] The alarm being on initially is normal, and the unit may make louder noises at first, especially if the super-freezing function is active [#17425992] One user reported that after opening and closing the door, the panel shows the default refrigerator/freezer temperatures again, and the buttons work normally once the appliance settles [#17426318] If the super-cooling mode is involved, it can be turned off by setting the freezer to -20 °C so the super option is not activated [#19411527]
  • Clarifying normal first-start display and alarm behavior
    #1 17425144
    Inżynier_Mamon
    Rate: 13
    As in the title it is about the first start of the Bosch KGN36ML3P fridge. Nowhere on the internet did I find any preview videos of this model,
    The fridge is connected to the power outlet. When connected, the display showed the fridge and freezer temp and the alarm went off. As in the instructions, I turned off the alarm button. After some time the temperature shown disappeared and the display shows the state as in the attached photo. The fridge has been on for over an hour. Is this status on the display is it meant to be or is something wrong?
    Bosch KGN36ML3P fridge - First start, power connection, temp display & alarm issue Bosch KGN36ML3P fridge - First start, power connection, temp display & alarm issue
  • #2 17425257
    Piotr2608
    Help: 851
    Rate: 4487
    You've written that it can take several hours.
    After 48 hours, this can be disturbing.
    ZimTech Piotr Zimny
  • Refrigerator temperature button unresponsive and compressor runs continuously
    #3 17425854
    AnnaSz.
    Rate: 8
    Also, I have a problem with starting this fridge, which we bought yesterday. Sorry, but I don't know anything about such equipment, and the last fridge only fell after 20 years, and during this time the technology has changed a lot. Just like the author of the thread - the alarm was on, turned off manually etc. We did everything according to instructions. Her husband leveled her and touches her nothing, etc.
    After a few hours, the illuminated alarm button turned off and it was supposed to be - supposedly the recommended temperature (was set by the manufacturer) in the refrigerator + 4 ° C, and in the freezer - 18 ° C was reached. My husband and I decided that everything is ok. It was only this morning (i.e. after 11 hours from switching on) that I noticed that the fridge was loud all the time and did not turn off. In the freezer, everything ok - freezes, and in the refrigerator it is also ok. No frost, no ice. The problem is that he is still buzzing, working constantly.
    And in addition in the control panel: I can easily set the temperature in the freezer and it is great; alarm and lock buttons also without a problem, but when I press the button to change the temperature in the refrigerator it does not turn on at all and I can not change anything they are still 4 ° C. We will be watching her today, hopefully I don't know what for. We are considering a complaint ...
    Thank you in advance for any reply.
  • #4 17425992
    Piotr2608
    Help: 851
    Rate: 4487
    User manual e.g.
    - Normal noises - a tip
    If the super-freezing function is activated, the sounds made by the machine may be louder.
    Give this refrigerator time to reach the indicated temperatures and cool the products inside. It may take up to 36 hours for the refrigerator to stabilize.
    ZimTech Piotr Zimny
  • #5 17426318
    Inżynier_Mamon
    Rate: 13
    As for my fridge is already in use. After opening and closing, default panel temperatures appear on the panel. The fridge freezer and freezer temperature increase and decrease buttons operate correctly. I didn't notice the buzzing as such, at first it may have been a bit louder, but now it is barely audible.
    I had the previous Ardo fridge for over 20 years. Let's be honest, not everyone needs to know how to connect refrigerators, so some instructional video on the manufacturer's website could be useful. The instructions are instructions, but if it is written, for example, it will switch off immediately, and an hour passes and nothing happens, then a person falls into a certain nervousness. We will see, until now, the purchased fridge was the first choice, despite watching many other models, we finally decided to buy it.
  • #6 17426331
    Piotr2608
    Help: 851
    Rate: 4487
    And it was the same with the Ardo fridge, but you don't remember it or pay attention to it.
    Why is the movie here? Just a little patience to make any fridge, no matter what company,
    "created" its own microclimate. Warm products (at room temperature) after insertion
    into the fridge or freezer steams. The first time the interior temperature is "high", a lot of steam is produced. The fridge does not have to get rid of condensed steam in the form of water, it still maintains a low temperature or cool the temperature to the set temperature.
    ZimTech Piotr Zimny
  • #7 17426407
    Inżynier_Mamon
    Rate: 13
    This video is mainly in relation to the electronic display. Increasingly, such displays appear in refrigerators, so it would be nice to see a small tutorial. If they are about phones, laptops or TVs then they could also be about refrigerators. And that's it. :)
  • #8 17426419
    jack63
    Help: 851
    Rate: 2822
    Is it not enough to read the instructions slowly and with understanding?
  • #9 19411527
    avacon
    Rate: 8
    Super cooling can be turned off by setting the freezer temperature to -20 ° C, then the super option will not be activated.
  • #10 19671199
    stratus84
    Rate: 13
    Hello, I am planning to buy a Bosch KGN39MIDA refrigerator. It's been a while since the first posts, I have a question for you, how are these refrigerators doing, are you satisfied?
The discussion revolves around the initial setup and operational issues of the Bosch KGN36ML3P fridge. Users report that upon first connection, the temperature display showed readings for both the fridge and freezer, but an alarm was triggered. After disabling the alarm, some users noted that the temperature display disappeared, leading to concerns about whether this was normal. It was suggested that the fridge may take several hours, or even up to 36 hours, to stabilize and reach the recommended temperatures of +4 °C for the fridge and -18 °C for the freezer. Some users experienced continuous buzzing noises, which they later found to be normal as the fridge adjusted to its microclimate. The need for instructional videos on the manufacturer's website was emphasized, as many users felt uncertain about the setup process. Additionally, a user inquired about the Bosch KGN39MIDA model, seeking feedback on its performance.
