[Solved] Samsung Galaxy J3 2016: Water Damage, Yellow Triangle Exclamation Mark, Battery Issues
BladeMasterPL 9030 7
  • #1 17433208
    BladeMasterPL
    Rate: 14
    I warmly welcome. I have a problem, namely the Samsung Galaxy J3 phone (I think 2016) fell into the water. The battery was almost empty so almost immediately after this accident my phone turned off. After removing the battery and reinserting it, I wanted to charge it. However, when loading, when I try to turn it on at the beginning I get 0% and then instead shows me a yellow triangle with an exclamation mark and next to it temperature. What should I do?
  • #2 17433221
    sosarek
    Help: 9320
    Rate: 15532
    BladeMasterPL wrote:
    he fell into the water
    After that, the battery was removed, the phone was taken apart, dried?
    Z
    Pka, Poznań, 60-850
  • #4 17433329
    BladeMasterPL
    Rate: 14
    Unfortunately, it wasn't until recently and at that time I didn't have access to the phone. Only now I received it and a year has passed and I doubt that someone had dried it before so it falls off.
  • #5 17436395
    BladeMasterPL
    Rate: 14
    It's weird. I tried to insert a different battery and the phone works. So it may have a different battery than the one I get from the beginning?
  • #6 17445010
    kongomaj
    Help: 5
    Rate: 20
    In J3 2016, after flooding, displays often sit down, the phone looks like it has died: it does not respond to a new battery, or to Home + Vol- + Vol ++ Power. After changing the set, everything returns to normal. Get to some service, let them connect you for a short time and it turns out.
  • #7 17445150
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    What does this have to do with the fact that lcd displays it ??
    At the beginning you have to follow the link sent by nutergsm. As for the battery, you can use another one that fits, J3 (16) probably fits with J5 and GRand prime.
  • #8 17601149
    BladeMasterPL
    Rate: 14
    The problem has long been solved, it turned out that when I returned it to the service, the motherboard was flooded, after replacement everything flashes as it should.
The discussion revolves around issues faced by a Samsung Galaxy J3 (2016) after it was exposed to water. The user reported that the phone turned off after the incident, displaying a yellow triangle with an exclamation mark and a temperature reading when attempting to charge it. Responses included suggestions to check if the phone had been dried properly and to try a different battery, which led to the discovery that the original battery was faulty. Ultimately, it was revealed that the motherboard had been damaged due to water exposure, and after its replacement, the phone functioned normally again.
