Samsung S6 Potential Water Damage: Key Backlight & Application Tabs Button Issues
Louisi 3120 10
How can I fix a Samsung Galaxy S6 with failing capacitive keys and backlight after possible water damage, and can I disable the physical buttons and use virtual onscreen ones instead?
If the phone was flooded, the proper fix is to disassemble it and replace the board with the system connector; the hardware buttons cannot be disabled from settings, and virtual buttons would require an app or root rather than a built-in option [#16404499][#16405647] One reply notes that the home button is on a separate tape, so disconnecting it should be easy, but the other two buttons are harder to deal with [#16405288] There are apps in the Play Store that can add virtual buttons, but they are not ideal and may overlap the displayed image [#16405647] A warranty repair can be tried, but water damage will likely lead to refusal [#16407778]
  • #1 16404431
    Louisi
    My girlfriend's phone (Samsung S6) started going weird.
    About a week ago, she accidentally put her phone (probably, because I don't know if the water got in via Jack or the charging port) next to spilled water on the table.
    When she dripped, she cleaned the phone dry, but unfortunately did not turn it off, but used (ehh ..).
    It was so that at the beginning there was no key backlight (such bright white light) and the button responsible for the application cards on the phone did not work at all or sometimes the button responsible for the application cards on the phone (the leftmost button from the home button and the fingerprint reader)
    I thought that maybe the compressed air would do something and possibly blow out the remnants of water if there were still any (about a week has passed since then). However, now the phone has such a strange phase that the button for application tabs is still active.
    And the question is what to do :) Is there a chance to turn off the buttons embedded in the phone and make some virtual ones appear?
    Help good people :)
  • #3 16404490
    Louisi
    Do you know what the samsung s6 looks like?
  • #4 16404499
    nutergsm
    Help: 1034
    Rate: 1665
    And what does it matter in the event of flooding? If there is a suspicion of flooding, you need to disassemble the phone, whatever it is.
    In this case, the board with the system connector is to be replaced.
  • #5 16405204
    Louisi
    Let's assume that the system with the connector fell as you say. Is it possible to completely disable the system buttons and possibly "add" them to the bottom of the display?
  • #6 16405288
    bubu1769
    Help: 1177
    Rate: 2374
    As for adding virtual buttons, this is not a problem, the home button is on a separate tape so unfastening it should not be difficult, the problem remains with the other two.
  • #7 16405586
    Louisi
    But how can you add virtual buttons? Need to root the phone, is there an option in the phone settings?
    And the same in the other way if you can lock the buttons from the settings position.
  • #8 16405597
    sylweksylwina
    Help: 1882
    Rate: 2355
    Give back for warranty.
  • #9 16405647
    bogdan2491
    Help: 52
    Rate: 97
    You have applications in the play store, Act, but it works, but no great because it enters the displayed image. Anyway, I'd take care of it properly if you were.
    You will not lock the buttons from the settings level.
    I am aware that replacing this element in the s6 is not the most pleasant, but it is not impossible. The worst thing is the risk of damaging the display, unless it is possible to somehow clean the old tape without removing the "ears" from the buttons under the glass.
  • #10 16407560
    Louisi
    Ok, we will try to return it to Samsung, maybe they will accept it (lottery).
  • #11 16407778
    sylweksylwina
    Help: 1882
    Rate: 2355
    Wait wait. I misled you, I was convinced the s6 was waterproof. However, if the phone was flooded, they will probably refuse to repair it. If you want, you can always try it, but it won't work.
The discussion revolves around a Samsung S6 experiencing potential water damage after being exposed to spilled water. The user reports issues with the key backlight and the application tabs button, which either do not work or are intermittently responsive. Suggestions include disassembling the phone to check for water damage, replacing the system board, and the possibility of adding virtual buttons through rooting or settings adjustments. There is also a mention of returning the device for warranty service, although concerns are raised about the likelihood of repair due to water exposure. The conversation highlights the challenges of repairing the S6, particularly the risk of damaging the display during the process.
