[Solved] Programmable LED Dimmer Switch for E27 Bulb to Simulate Sunrise Effect in Bedroom
marianmaciag 1839 3
  • #1 17438501
    marianmaciag
    Rate: 8
    Welcome.
    I know that there are ready-made designs and products that fulfil a similar function, such as the PHILIPS HF3520. However, I would like to use the existing lighting in the bedroom, i.e. a ceiling lamp for a classic bulb with an E27 thread. I am only interested in light effects, no sound effects, so a light bulb + a suitable dimmable switch should do the trick. Do you know of a dimmer in which I could programme the time and length of switch-on to finally get the sunrise effect? I am mainly interested in solutions dedicated to LED bulbs. Or are there other solutions to this problem that I am not yet aware of? Any suggestions welcome.
    Greetings
  • #2 17438582
    Stanislaw13
    Hello, perhaps something like this will settle the matter:
    Moderated By Marek J.:
    Link to all...o I have removed. For future reference, remember not to add links to auction sites because: 3.1.18. Do not send links that become inactive after a certain period of time. This will make the discussion lose any sense.
    The name "BAWLED Smooth LED brightening fade" alone is sufficient.
    or a link to the manufacturer/distributor website https://www.elkosmito.pl/index.php?id=produkt.php&produkt=53
  • #3 17439928
    marianmaciag
    Rate: 8
    Thanks for the reply, but I'm looking for a rather off-the-shelf switch with dimmer to mount in an existing box. I came across something like this: http://blebox.eu/pl/glowna/23-wlightboxs-sciemniacz-led-iphone-i-android.html Unfortunately it is dedicated to 12-24V and I need something for 230V.
    Edit:
    I seem to have found the answer to my question, and it reads BLEBOX DIMMERBOX. - link . I haven't bought it yet, but from the information I've received from the manufacturer, it should meet my expectations 100%.
    Each of our units has a freely programmable schedule (switch on, switch off, etc.) at:
    - at a preset time
    - before sunset (number of minutes)
    - after sunset (number of minutes)
    - before sunrise (number of minutes)
    - after sunrise (number of minutes)
  • #4 17472675
    marianmaciag
    Rate: 8
    The device I was looking for was the BLEBOX DIMMERBOX.
