Ethernet-Controlled Dimmer Module for 220V Bulbs—Ready-Made Options for Smart Home
lision 3687 2
  • #1 16386049
    lision
    Hi. While renovating my flat I decided to take advantage of the situation and build a smart home controller. At its heart will be an application with a touchscreen display which will be the main interface. I would like to connect the whole with an ethernet network and therefore I am looking for ready solutions which will enable me to plug in a cable, connect a light or other devices and control a given medium via sockets or http.
    Has anyone had to deal with such a solution?
    Do you know of any ready-made ethernet-controlled module that allows switching on/off and dimming of some node with bulbs on 220 ?
    Alternatively, do you know of any other interesting ready-made ethernet control or sensor modules ?
    Greetings.
  • #2 16407401
    ditomek
    Help: 24
    Rate: 230
    I've thought about it myself but does dimming still make sense today, in the age of LEDs?
    Dimmable LEDs are more expensive and generally harder to find. In my opinion, it is better to build scenes using a lot of but smaller light sources. Today, LED strips have basically taken over as dimmable light sources. I would also prepare the installation for the installation of RGB tapes
  • Ready-made Ethernet and WiFi dimmer controllers
    #3 16569543
    ehouse
    Rate: 20
    For both variants here are ready-made eHouse solutions:
    - Ethernet room controllers up to 32 outputs with relay drivers + 3 LED dimmers 12VDC/PWM 2.5A.
    Has 24 programmes and light scenes including on/off outputs and dimmers. TCP/IP control + Applications
    Ethernet building automation .
    - WiFi controllers for 4 relay outputs 230v/5A + 3 LED dimmers 12VDC/PWM 3A. Control via TCP/IP, WWW, HTML Request + Applications.
    Intelligent Home WiFi Flats
    Java, Android and web software and development libraries and source code available
