Steamjet Enbio Class B Autoclave - Water Spillage Issues: Locating Sources & Leak Prevention
skittlesys 10836 4
  • #1 17448769
    skittlesys
    Rate: 12
    Hello, I have a steamjet enbio class B autoclave. Every now and then, when sterilizing instruments, water appears on the countertop. It spills as if from the back where there are supply pipes but I can not locate it exactly. Recently, I discovered that in the cabinet underneath and there are containers for clean and dirty water there is also a small puddle. The wires are dry. Where can water get out of? Sometimes when I look under the autoclave water droplets appear on the terz screws. Is it normal?
    I ask for advice.
    leonard64
    Help: 22
    Rate: 79
    I do not know this autoclave very well, but the emerging water may indicate a leak in the internal water supply system or its discharge, but it can also be the result of condensation of steam escaping through a leak during the process. I suggest calling the site, it is not possible to locate the cause remotely.
  • #3 17479212
    Sonora7
    Most likely the bulkhead fitting (into which you attach the hose - red) has become loose and leaking.
  • #4 17479299
    skittlesys
    Rate: 12
    I think so too, because with the red tongue the water always appears, can it be tightened somehow? I tried my hand but nothing came of it
  • #5 17480515
    Sonora7
    You can't try with your hand, you can try with the key. If you fail to write to the site, they will send a replacement for the time of repair, so it should not hurt
