[Solved] UPC Connect Box: Changing IP Address - Basic WAN IP Renew Option Missing?
kat13 12285 9
How can I change the public IP address on a UPC Connect Box when the WAN IP Renew option is missing?
You usually cannot force a new public IP from the Connect Box itself, because router resets do not affect IP allocation and the WAN IP is handled by UPC; if the address does not change after reboot, it may be fixed or only changed very rarely by the provider [#17455430][#17455448][#17455533] If you need a different IP right away, use a VPN so sites see a different address [#17455430][#17455528] One sometimes-working workaround is to unplug the router for more than 48 hours, although it does not always work [#17456460] A more reliable method is to switch the Connect Box to bridge mode and use your own router, which can result in a different IP [#17456460]
  • #1 17454830
    kat13
    Rate: 65
    Hello, is there an IP change in Connect Box from UPC ?? I did not find such an option in the router, although it was shown on a foreign YouTube video that it can be, but I do not have such a tab as BASIC in which there is WAN IP Renew ??
  • #2 17455151
    makosuu
    Help: 369
    Rate: 370
    Why do you want to change something for the WAN configuration? Probably it's blocked by UPC.
  • #3 17455158
    icooz
    Help: 14
    Rate: 43
    What are you for? The modem is associated with the customer number you have on the contract. I have internet from UPC myself with this Connectbox to play it is tragic I do not recommend it. When I was behind with money, the router blocked me that I could not enter the settings.
    You can use a VPN or contact UPC via chat like I did.
  • #4 17455426
    kat13
    Rate: 65
    Mainly I mean changing IP, I have a blockade on some websites and I can enter without any problems from another IP, e.g. from a friend.
  • #5 17455430
    makosuu
    Help: 369
    Rate: 370
    If after restarting the router it does not change, you have a fixed public IP, which has advantages and disadvantages. You can connect via VPN and it will be different.
  • #6 17455448
    jimasek
    Help: 3783
    Rate: 2681
    As far as I know from users of UPC services, the IP address is dynamic, but changes are made by the service provider and very rarely.
  • #7 17455519
    kat13
    Rate: 65
    Router reset does not help the IP is the same.
  • #8 17455528
    makosuu
    Help: 369
    Rate: 370
    Then connect via VPN, eg Cyberghost, it will be different.
  • #9 17455533
    jimasek
    Help: 3783
    Rate: 2681
    As I wrote, your router reset has no effect on the allocation of the IP address.
  • #10 17456460
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Sometimes it helps to permanently unplug your router for more than 48 hours (but this won't always work).
    Another more reliable method is to switch Compala to bridge mode and connect your own router - then the IP will change.
    You can still through Tor (but many sites block it).
The discussion revolves around the inability to change the WAN IP address on the UPC Connect Box. Users express frustration over the lack of a "BASIC" tab for WAN IP renewal, as seen in a foreign YouTube video. Responses indicate that UPC may block such changes, and the IP address is typically dynamic but rarely changes without intervention from the service provider. Suggestions include using a VPN to bypass IP restrictions, resetting the router, or switching to bridge mode with a personal router to potentially change the IP address. Some users report that unplugging the router for an extended period may help, but results can vary.
