Obtaining a Permanent IP Address for UPC Internet: Remote Monitoring Access & Privacy Laws
Rodmano80 24660 15
How can I get remote access to home monitoring on a UPC private internet contract if UPC will not provide a fixed public IP address?
You usually cannot get a fixed public IP on a private UPC contract, so the practical solution is to use DDNS and your own router instead. [#14675485] A Ubee modem-router can be switched to bridge mode, then you connect a separate router behind it. [#14675485][#15151357] One suggested option is a router with Gargoyle/OpenWRT, which supports free DDNS services. [#14670900][#14670823] UPC’s explanation linked in the thread says bridge mode is available, and the fixed-IP option is for company contracts only. [#15151357][#14675485]
  • #1 14670508
    Rodmano80
    Rate: 8
    I have a question about obtaining a permanent ip address on the Internet with an upc-contract for a private person.
    I have monitoring at home and I want to have remote access to it, and a permanent ip address is required for this.
    After talking to the supplier, I found out that they cannot give me a permanent ip address, because the Personal Data Protection Act prohibits it, and by signing a contract for a company, I get a permanent ip address, but you pay a lot more for services.
    A friend advised to use the dyn.com website, but there you also have to pay a minimum monthly subscription of $ 5.
    Do you know any solution to my problem?
    I will be grateful for any help.
  • #4 14670823
    jimasek
    Help: 3783
    Rate: 2682
    A router from Gargoyle and using some free ddns service.
  • #5 14670844
    Rodmano80
    Rate: 8
    What is a gargoyle router?
  • #6 14670900
    jimasek
    Help: 3783
    Rate: 2682
    Router - one of the basic devices in computer networks, working in the third layer of the OSI model and used to connect different networks.
    Gargoyle - alternative software for routers based on OpenWRT. It allows, among other things, to use free ddns services - Link
  • #7 14670997
    Rodmano80
    Rate: 8
    Thanks! I understand what is the router. I didn't know this Gargoyle.
  • #8 14674741
    KOCUREK1970
    Help: 3867
    Rate: 5500
    @ Rodmano80
    And what equipment does a colleague from the operator have at his disposal?
  • #9 14674872
    Rodmano80
    Rate: 8
    KOCUREK1970 wrote:
    @ Rodmano80
    None for now, because they will connect me in a few days, after a year of struggle ... Why are you asking? What exactly do you mean?
  • #10 14675485
    KOCUREK1970
    Help: 3867
    Rate: 5500
    Rodmano80 wrote:
    ...And why do you ask? What exactly do you mean?
    Because you will probably get UBEE - it's a modemorouter - and here, as you know, external IP ends with it - so you will not see the recorder in the external network.
    BUT, you can switch this UBEE to bridge mode - additionally your own router and this problem is no longer there.
    And that's what I recommend you to do.
    What a nonsense translation on their part - and this company is not in force, you do not need to (any longer) protect your data ...
    The answer is simple - an ordinary user does not need (according to the operator) a fixed IP - in their opinion, people take 250 Mb only for browsing the web, e-mail and nothing else ... - I don't understand it myself, why I can't have a fixed IP.
    I have 2 servers that I have "exposed to the world" - but everything done in roundabouts ...
    At one time, probably Vectra for PLN 10 a month "gave" a fixed IP to a home client - as it is now I do not know, but I think they still offer it.
    At UPC, only the company gets a fixed IP.
  • #11 14675498
    Rodmano80
    Rate: 8
    Thanks so much for the tip!
    Switching this Ubee to bridge mode is my reason that it is on the Upc side?
  • #12 14675507
    KOCUREK1970
    Help: 3867
    Rate: 5500
    And yes and no - no, because they want their dumb WiFree service (a different type of wifi - just their networks) to run on their hardware - so they won't switch it for you.
    And yes - because you yourself can switch it without any problems.
  • #13 14675683
    Rodmano80
    Rate: 8
    And yes - because you can easily switch it yourself.
    And where is this Ubee device going to be located? At my house or in their mailbox?
    Will you tell me how to switch it easily?
  • #14 14676049
    KOCUREK1970
    Help: 3867
    Rate: 5500
    At your home.
    How do you get this equipment.
  • Requests guidance configuring Ubee in bridge mode
    #15 15149761
    Rodmano80
    Rate: 8
    KOCUREK1970 wrote:
    At your home.
    Welcome,
    It took a while, but finally I have this Ubee hardware and UPC services. Now I have to buy a good router and set the UPC one as a bridge.
    Will you suggest how to do it, or how to check if it is done?
    Asus RT-N18U meets needs; three TP-Link routers failed
    #16 15151357
    KOCUREK1970
    Help: 3867
    Rate: 5500
    In bridge mode it is not 100% done:
    Anyway, here's the operator's ready-made:
    https://pytania.upc.pl/?q=fact_1006973
    I have an Asus RT-N18U as a router - I do not use wifi at all (it only has 2.4 GHz wifi - no 5 GHz), and the rest 100% meets my expectations: POLISH menu in the router, everything is arranged simply and clearly in the GUI router, working port forwarding, detachable antennas, router firmware updates issued every 3-4 months, 3-year warranty, hardware NAT, gigabit LAN and WAN ports - for me up to PLN 300 there is nothing better.
    I had a total of 3 TP Links (different models on the same network configuration at my home) - all of them died.
The discussion revolves around obtaining a permanent IP address for remote monitoring with UPC Internet services. The user faces challenges due to UPC's policy, which restricts permanent IP addresses for residential contracts under the Personal Data Protection Act. Alternatives suggested include using a router with Gargoyle firmware and free Dynamic DNS (DDNS) services. Users discuss the UBEE modem-router provided by UPC, which can be switched to bridge mode to allow for a personal router setup. Recommendations for routers include the Asus RT-N18U, noted for its features and reliability. The conversation highlights the need for a permanent IP for effective remote access to home monitoring systems.
