Assessing Black Smoke Issue in 2003 BMW E60 530d: INPA Graph Analysis and EGR Check
kornias 8019 1
  • #1 16695951
    kornias
    Rate: 45
    As in the subject, i.e. BMW E60 530d from 2003. He smokes terribly black when stepped on violently. I exclude the turbine reconditioned 11 months ago. The engine starts nicely. EGR smoky (photo), in INPA without errors. Should it be sucked at low speed after disconnecting the hose from the egr or only after adding gas? What can I check with home methods.
  • #2 16697463
    kornias
    Rate: 45
    Today I had fun with INPA and I have such charts
    At idle speed:
    Assessing Black Smoke Issue in 2003 BMW E60 530d: INPA Graph Analysis and EGR Check Assessing Black Smoke Issue in 2003 BMW E60 530d: INPA Graph Analysis and EGR Check Assessing Black Smoke Issue in 2003 BMW E60 530d: INPA Graph Analysis and EGR Check
    RPM when the car starts to smoke 1700-1900 RPM
    Does it mean that cylinder 4 injection must be replaced ???
