Ferroli Zefiro c11 Gas Oven - Error E3 Troubleshooting: Nozzle Change to LPG, Sparkers Issue
maniek19 48606 2
  • #1 17469201
    maniek19
    Rate: 23
    Does anyone have a list of errors of such a stove?
    What's the problem:
    After changing the nozzles to LPG, I started the stove. The gas ignites, but the sparkers "shoot" all the time and after about 5 seconds. the stove switches off showing the message "E3".
    The exhaust outlet has nothing to do with it because I tried to pull off the pipe and then the same effect.
    New oven removed from the box.
    Mariusz
    goldzik15
    Help: 22
    Rate: 120
    Evidently no ionization. Maybe you forgot to connect the cable? The electrode is probably on the right side of the board. See if it is in a flame or not shorting to mass etc.
  • #3 17473095
    maniek19
    Rate: 23
    Thanks for pointing. The problem was actually in the ionizer.
    From the beginning it was badly connected, i.e. the probe only touched the insulation. After reconnecting the problem resolved.
