[Solved] Strange Internet Problem - Some websites and programs cannot "see"
slyyt 35343 5
  • #1 17474374
    slyyt
    Hi to all :)
    I'm new to the forum, but I went here on purpose, because I know that I will probably find the answer here.
    Well, I have a problem with the Internet. Sites like YT and Facebook work fine, turn on immediately and no connection errors are displayed. Other sites, on the other hand, for example the electrode forum, or other sites less frequently visited by me, either keep loading indefinitely, or crash the error message "This site is unreachable". There is no rule whatsoever. Whether the website works or not is total roulette.
    Unfortunately, the problem does not end with the websites. I also have problems, for example, with Origin, which, despite the working Internet connection, is stubbornly pushing me that there is no Internet, and without it it is impossible to log in to the account and with the Windows SmartScreen, which after downloading a file from the Internet (e.g. installation ) crashes a message saying it would tell me if something is wrong with this file but it doesn't have internet access so it won't say.
    The problem is very strange and irritating. I have never encountered something like this before, the Internet only works a little, but not completely. From important information I will add that my computer is the only computer in the house connected to the network via a cable, there are no major problems with WiFi. The router is Orange FunBox 2.0
    calixto
    Help: 75
    Rate: 66
    Does the same symptom occur when you use other devices (e.g. telephone) connected via wifi?
    The randomness of loading sites may be the result of a DNS malfunction. Display (run cmd, then in the console window enter: ipconfig) what DNS you have in network connection settings, temporarily change to another (e.g. google: 8.8.8.8). Check what addressing your computer and modem are receiving (including the public address you have received e.g. via www.whatismyip.com). This symptom may be the result of an allocation of the ipv4 and ipv6 addresses. The operating system may prefer ipv6 connections - so it will load YT and Facebook pages quickly, but you may randomly receive timeouts when visiting other websites. This is rare, but can be checked as a preventive measure.
    I found a thread that may be helpful -> Link
  • #3 17474572
    slyyt
    No, the internet via WiFi on the phone is fine, maybe one game on the phone sometimes has a problem, but only in it. The internet works fine.
    As for DNS, I had previously set to 8.8.8.8, and the alternative to 8.8.4.4. Ironically, the website whatismyip.com crashed the error "This site is unreachable", but after a few tries it crashed (roulette, I said).
    Public IPv6 is: 2a01: 115f: 65d: c400: 7dde: 8392: fe50: 62d6
    IPv4 is: 83.26.252.217
    Local IP is: 192.168.1.12
    calixto
    Help: 75
    Rate: 66
    What is your operating system on your desktop computer? Can you try to disable IPv6 on FunBox router (as described in the thread)? Also check MTU settings between computer and router and router and internet. A description of how to do this can be found under THIS and THIS link.
  • #5 17474944
    slyyt
    I entered the router's settings through a browser and removed "/ IPv6" from my nickname in Neostrada. Everything is now working as it should. Thanks a lot for help, I close the topic.
  • #6 17474948
    slyyt
    As written above ;)
