Win XP DNS Issue: No Internet Connection, Connected to Router (IP Config, Pings Tried)
pbqvx 1989 2
  • #1 17382930
    pbqvx
    Hi.
    I have problem with my Windows XP.
    I don't have Internet. I think there is problem with DNS.
    My computer is connected to the router but there is no Internet.
    Other computer and my cell is connected and have Internet.
    I tried pings and nothing.
    This is what I've got:
    Microsoft Windows XP [Version 5.1.2600]
    © Copyright 1985-2001 Microsoft Corp.
    C:Documents and Settingskasztelan>ipconfig /all
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : kasztelania
    Primary Dns Suffix . . . . . . . :
    Node Type . . . . . . . . . . . . : Unknown
    IP Routing Enabled. . . . . . . . : No
    WINS Proxy Enabled. . . . . . . . : No
    Ethernet adapter {2136CD6D-00DB-49EC-BF35-0505BFC36788}:
    Media State . . . . . . . . . . . : Media disconnected
    Description . . . . . . . . . . . : Anchorfree HSS Adapter
    Physical Address. . . . . . . . . : 00-FF-21-36-CD-6D
    Ethernet adapter Wireless Network Connection:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Ad
    apter
    Physical Address. . . . . . . . . : 00-23-4D-89-54-9A
    Dhcp Enabled. . . . . . . . . . . : Yes
    Autoconfiguration Enabled . . . . : Yes
    IP Address. . . . . . . . . . . . : 192.168.0.24
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.0.1
    DHCP Server . . . . . . . . . . . : 192.168.0.1
    DNS Servers . . . . . . . . . . . : 209.18.47.61
    209.18.47.62
    Lease Obtained. . . . . . . . . . : Monday, August 13, 2018 1:58:46 PM
    Lease Expires . . . . . . . . . . : Monday, August 13, 2018 2:58:46 PM
    C:Documents and Settingskasztelan>ping 192.168.0.24
    Pinging 192.168.0.24 with 32 bytes of data:
    Reply from 192.168.0.24: bytes=32 time<1ms TTL=128
    Ping statistics for 192.168.0.24:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
    C:Documents and Settingskasztelan>ping 192.168.0.1
    Pinging 192.168.0.1 with 32 bytes of data:
    Request timed out.
    Request timed out.
    Request timed out.
    Request timed out.
    Ping statistics for 192.168.0.1:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
    C:Documents and Settingskasztelan>ping wp.pl
    Ping request could not find host wp.pl. Please check the name and try again.
    C:Documents and Settingskasztelan>ping 194.204.159.1
    Pinging 194.204.159.1 with 32 bytes of data:
    Request timed out.
    Request timed out.
    Request timed out.
    Request timed out.
    Ping statistics for 194.204.159.1:
    Anybody can help me?
    I'll be appreciated.
  • #2 17382973
    Wojtek(KeFir)
    Help: 678
    Rate: 562
    If there is a problem with DNS you can try type IP address of desired server directly in address field in your browser. This will cause direct connection without DNS involvement at all.
    Other way is to type google's DNS in DNS field in IP-connection properties. That is 8.8.8.8.
  • #3 17383095
    pbqvx
    Wojtek(KeFir) wrote:
    If there is a problem with DNS you can try typing the IP address of the desired server directly in the address field in your browser. This will cause a direct connection without DNS involvement at all.
    Another way is to type Google's DNS in the DNS field in IP-connection properties. That is 8.8.8.8.
    Unfortunately, it doesn't help.
    Still nothing.
    Any other ideas?
