Choosing the Right Soldering Station: WEP 852D + 2in1 2xLED KOMPRESOR Review
polo44 11499 4
  • #1 17501574
    polo44
    I would like to ask for advice.
    I would like to buy a soldering station, I need it to solder, for example, charging connectors in phones.
    What do you recommend, what to pay attention to?
    A station such as "WEP 852D + 2in1 2xLED KOMPRESOR Soldering Station" for PLN 193 caught my attention, is it a good choice?
    xpira
    Help: 87
    Rate: 108
    "Soldering Station WEP 852D + 2in1 2xLED KOMPRESOR" seems decent and is not expensive.
  • #4 17503034
    lukaszd82
    Help: 143
    Rate: 491
    Don't take anything on old tips. It is better to buy 2 separate devices than 2in1.
    As a cheap soldering iron, I recommend something on the T12 tips (tip and heater integrated, new tip from China ~ 12 PLN), heats up quickly, real 70W.
    As you choose, note that there are STC and STM32 versions. I recommend definitely the more expensive, the STM32. Better temperature stabilization.
    Buy hot air separately.
    Including WEP, the butt has a real 48W (907A butt, heaters 45 and 48W), I don't know how many hot air, but also not as much as it is in the auction;>
    There were even a few topics on the electrode about these flasks so you can read for yourself. There are auctions with 60W heaters, but the standard one comes. I used to buy and rework this topic for my DIY station. I was supposed to put on a stronger trafo, but I did not find a stronger heater with a thermocouple.
    The 907f stock is like 75W, but that's not entirely true either (WEP937D +).
