JBL Go Speaker & Windows 7: Troubleshooting Connectivity & Playback Issues (Win10 vs Win7)
mazi292 5280 9
How can I get a JBL Go Bluetooth speaker to connect and appear as a playback device in Windows 7?
Make sure the speaker is actually paired first, and then select it as the playback device; until it is paired, it will not work [#17516832][#17516802] If the Windows 7 Bluetooth manager shows the speaker but offers no Connect option or no playback-device entry, check the playback devices list and the playback tab from the sound settings [#17516895][#17517020] In this thread, the built-in Windows 7 Bluetooth manager still did not work properly for the speaker, but BlueSoleil did make it work [#17517037] So the practical workaround reported here is to pair it normally if possible, and if Windows 7 still refuses to expose audio playback, use BlueSoleil instead [#17516832][#17517037]
  • #1 17516799
    mazi292
    Help: 8
    Rate: 14
    I have a BT JBL Go speaker, I had Windows10 and it was enough to connect the device and play, I went back to Windows 7 and I can not make it work, fresh system, all drivers are there, the computer can see the device, I add but there is no option for it to play.
    Do you have any ideas ?? I will add that I use the windows bluetooth manager, also for windows10 but there were no problems there
  • #3 17516808
    mazi292
    Help: 8
    Rate: 14
    It just does not appear in the sound options to run it, as if it is visible the drivers have uploaded to this speaker but it is not connected to the computer because the speaker is not paired with the computer, the diode on the speaker blinks that it is searching for devices.
  • #5 17516850
    mazi292
    Help: 8
    Rate: 14
    I only know how I am talking, it appears in bluetooth options as a bluetooth headset but you can't connect with it
  • #7 17517003
    mazi292
    Help: 8
    Rate: 14
    I don't have such an option, screen
  • #8 17517020
    badboy84
    Help: 1197
    Rate: 1485
    It looks connected. Show screenshot with playback devices, right click on the speaker, playback devices, playback tab.
  • #9 17517037
    mazi292
    Help: 8
    Rate: 14
    There is no such option there, I tried bluesoleil and it works ok, but I would prefer to connect without this program
  • #10 21638218
    chrisbp
    Rate: 48
    It's different for me - all the drivers won't install, Windows Update doesn't search for the last one. The system sees the speaker, but it's missing drivers and can't be set to play because it's greyed out.
    Hardware ID - BTHENUM{65786365-6c70-6f69-6e74-2e04ffe42003}_LOCALMFG&000f
    JBL Go 4, W7 Professional.
✨ A JBL Go Bluetooth speaker worked normally in Windows 10, but after reinstalling Windows 7 the computer could detect the device without offering it as an audio playback target. The speaker appeared in Bluetooth devices as a headset, but pairing/connection and playback options were missing in the Windows 7 sound settings. Attempts with the built-in Windows Bluetooth manager did not resolve the issue, while BlueSoleil enabled audio playback successfully. A later report from another user described a similar Windows 7 problem with a JBL Go 4, where the speaker was detected but drivers would not install correctly and the playback device remained unavailable or greyed out.
