Audi A4 B8 2.0TDI 120HP CAGC - Fuel Pressure Sensor Signal Too Low // Signal
Damian98Audi 76767 30
Why does my Audi A4 B8 2.0 TDI idle fluctuate and show a fuel pressure sensor signal too low/high fault after replacing the common rail pressure sensor?
Check the fuel pressure regulator/pressure control valve on the common rail, because the thread points to that part rather than the sensor itself. Several replies say the regulator on the rail is the likely cause of the unstable idle and fluctuating rail pressure, and one user with the same CAHA symptom said replacing the rail pressure regulating valve fixed the rocking idle without any adaptation [#17521801] [#17522284] [#17526877] [#18104079] It was also advised to inspect the high-pressure pump, the regulator, and look for metal filings in the system [#17521941] One reply notes that a reset/adaptation will not fix a mechanically damaged valve [#17524817], and another suggests checking the sensor wiring/supply only as a diagnostic step, including 5 V supply, signal, and ground [#17536573] The reported rail pressure jumping at idle and the later appearance of pressure regulation errors also fit a faulty regulator on the rail [#17536573] [#18104386]
  • #1 17521695
    Damian98Audi
    Rate: 23
    Hello, I have an Audi A4 B8 2010. 2.0TDI 120KM CAGC
    I have such a problem with the revolutions waved within 700-900 so the engine was not even working and it is at idle
    while driving, the car performs normally and a little weaker or not it is hard to feel
    After connecting the computer with MaxiEcu did not show any error
    So I undertook the diagnosis of unplugging the sensors and after unplugging (Fuel Pressure Sensor) on the Common Rail
    The engine started to run evenly but louder
    And after connecting the computer an error occurred (Fuel pressure sensor on the injection rail signal too high)
    So I bought e-katalog.intercars.com.pl/pdf/331920163518
    And after replacing the sensor, the engine somehow worked strangely, but the speed was stable
    and there was a specific smell like something burning on Poster
    Fixed error after plugging in the computer (Fuel pressure sensor on the injection rail signal too low)
    When I tried to reach 3,000 revolutions and letting go of gas, a clatter of power as in a diesel (two strokes +/-)
    So I turned this sensor off and put on the old one.
    I tried to describe it well, I think it worked out somehow
    Best regards and waiting for feedback
  • #2 17521801
    misiek-888
    Level 36  
    Help: 379
    Rate: 1306
    Sooner the problem will be with the pressure regulator. Perform a controller adaptation reset.
  • #3 17521814
    szymitsu21
    Help: 342
    Rate: 1292
    The regulator on the strip, look at the fuel pressure at idle.
    Plus a friend's tip above.
  • #4 17521941
    czaki22
    Rate: 17
    sensor only new and only original, check high pressure pump and regulator, search for filings
  • #5 17522114
    Damian98Audi
    Rate: 23
    Could someone approximate me with resetting the pressure regulator adaptation?
  • #6 17522284
    Rafik4
    Help: 214
    Rate: 314
    I had the same thing in CAHA, the pressure regulating valve on the 057130764H strip was responsible for rocking on free time, replacement for a new one and nothing needs to be adopted.
  • #7 17522906
    Damian98Audi
    Rate: 23
    And after replacing the fuel pressure sensor on the CR strip
    no need to reset pressure regulator adaptations?
    or if something needs to be done after replacing the Pressure Sensor
    What are the procedures for replacing the fuel pressure sensor
    Added after 50 [minutes]:
    https://www.youtube.com/watch?v=RfNrhpul0Vo
    this is how the engine behaves, it's not my recording
    Added after 35 [minutes]:
    https://forum.nissanklub.pl/topic/87958-t30-22-dci-reset-pompy-po-wymianie-zaworu-scv/
    is there something like this in Audi reset adaptation?
    or how to do it with VCDS
    Added after 13 [minutes]:
    I fucked the forum mass on this topic and many people write about this adaptation reset
    but nowhere can I find the procedure for this adaptation
  • #8 17524817
    Rafik4
    Help: 214
    Rate: 314
    Resetting will not repair a damaged valve.
  • #9 17524961
    Damian98Audi
    Rate: 23
    And after replacing the fuel pressure sensor no adaptation is needed?
  • #10 17526642
    Rafik4
    Help: 214
    Rate: 314
    I do not know, I did not move the sensor, after replacing the valve, it waved for a while and stabilized.
  • #11 17526687
    Damian98Audi
    Rate: 23
    Well, after the exchange, the revs did not wave, but immediately the error that the pressure was too low and the engine seemed to run on 3 cylinders and a strange specific smell was (if someone started something on the cake, the same smell)
    And when gassing something metallic was heard
    So I put on an old one and everything is cool, it's just the wave revolutions
    Even the error is not old
  • #12 17526841
    Rafik4
    Help: 214
    Rate: 314
    Then change the valve and it will be fine.
  • #13 17526855
    Damian98Audi
    Rate: 23
    Changed to old but revolutions and I would like to remove it
  • #14 17526877
    Rafik4
    Help: 214
    Rate: 314
    You changed the sensor and the valve at the other end of the bar is to blame.
  • #15 17528688
    Damian98Audi
    Rate: 23
    wave revolutions have disappeared only light shack is feasible
    I took measurements and the fuel pressure jumps 170-270bar at idle
    Audi A4 B8 2.0TDI 120HP CAGC - Fuel Pressure Sensor Signal Too Low // Signal Audi A4 B8 2.0TDI 120HP CAGC - Fuel Pressure Sensor Signal Too Low // Signal Audi A4 B8 2.0TDI 120HP CAGC - Fuel Pressure Sensor Signal Too Low // Signal
  • #16 17536270
    Damian98Audi
    Rate: 23
    Up someone something?
  • #17 17536573
    Makxio
    Help: 35
    Rate: 79
    Old, no fuel pressure can not jump like this, the acceptable deviation is approximately +/- 10%.
    I propose that you carefully check the sensor supply itself fuel pressure (there you have 3 pins, signal in the range of 0.5 - 4.5, 5V power supply and mass) which is which I will not tell you now.
    The elements involved in regulating the fuel pressure are the sensor and regulator, what the sensor measures on the strip, the transmission to the ECU, will also verify with what it is supposed to be and so will control the pressure regulator if any of these elements fails (e.g. the valve will seize or it will be dirty) then the pressure will change.
    Similar effects can be given by overflow of any of the injections.
    Check carefully how the fuel sensor supply looks like.
    Oh, two more things:
    - in these parameters what you stated above is an open throttle almost 40 percent .. did you keep the gas pressed or not?
    - see what voltage supply you have in the system ... in the upper right corner of the tester you have 15.1 V ... quite a lot ... and what does the meter connected to the battery pack show?
    M.
  • #18 17568335
    Damian98Audi
    Rate: 23
    For some time he was calm with the wave revolutions but yesterday it came back and today calm again but still feel the vibrations and this dose of fuel jumps +/- 5,000
    And yesterday I took something to check and started the car and it works perfectly, but I overcooked it a little up to 2/3 thousand I gave up and the shaking of the shack returned without wave revolutions.
    I have no idea: /
    In December I am coming back to Poland and I will exchange a fuel pressure regulator and see what will happen
    If someone has an idea to give info :P
  • #19 17924005
    Razor1711
    Rate: 49
    And what, did you fix the problem?
  • #20 18008921
    MCZ007
    Rate: 8
    Hi, I have a similar problem with the leaping fuel pressure and gentle vibration at idle in CAHA. I replaced the common rail adjustment valve, but I didn't carry out any calibrations. I will look into the valve at the pump. Are there any adaptation procedures that I might have missed?
    Did anything move about Damian?
  • #21 18103710
    Krzysiekmk1
    Hello colleagues.
    I also have a problem with the CAHA 2.0tdi engine.
    I replaced the pressure sensor in Lithuania CR, but it did not help, so I replaced it, because when I unplugged it, the car started to work evenly, but it caused an error.
    After cutting off the pressure control valve on the rail, the car immediately goes out, and after cutting the plug from the regulator on the pump, it has no effects, except that a regulator error on the high pressure pump is triggered.
    Help, which valve is broken?
    MCZ007 did you solve the problem at home?
    What was the reason?
  • #22 18103920
    Rafik4
    Help: 214
    Rate: 314
    Maybe write what is your problem, revolve at low speed? How does the pressure on the slat work at idle?
  • #23 18103997
    Krzysiekmk1
    Swing at idle revolutions, as if revolutions dropped and returned to normal revolutions. Vcds I checked it jumps pressure.
  • #24 18104079
    Rafik4
    Help: 214
    Rate: 314
    Valve on the rail.
  • #25 18104085
    Krzysiekmk1
    Can you check it somehow?
    Added after 2 [hours] 35 [minutes]:
    Strange that there is no error ? and is it possible that the reason was bad fuel? And it is even more so to smell such a specific smell of exhaust fumes, but it seems to me that this is the norm for dpf
  • #26 18104386
    Rafik4
    Help: 214
    Rate: 314
    Over time, there will be a pressure regulation error, I did it.
  • #27 18105066
    Krzysiekmk1
    Oki, thanks to whom I will look, and you don't know how much a valve can cost?
  • #28 18105097
    Rafik4
    Help: 214
    Rate: 314
    About 500 PLN.
  • #29 18217260
    levy_21
    Help: 9
    Rate: 31
    I have a similar problem. Although the revs do not go crazy as in the movie.
    It is the pressure on the bar that jumps. An additional symptom are relatively high corrections in injections.
    It can show even around 1.7, but when I add gas and let it go, corrections from the 1st cylinder go to 4 or vice versa.
    I wonder if it could be just a pressure regulator on the bar or maybe a dose valve on the pump?
    At elevated revolutions, correction on exemplary injections, no swarf pump.
  • #30 18217373
    szymitsu21
    Help: 342
    Rate: 1292
    The regulator on the strip.
✨ The discussion revolves around an Audi A4 B8 2.0TDI 120HP (CAGC) experiencing unstable idle revolutions (700-900 RPM) and a fuel pressure sensor error. The user diagnosed the issue by unplugging the fuel pressure sensor, which temporarily stabilized the engine but triggered a new error indicating a high signal from the sensor. Various responses suggest checking the pressure regulator, high-pressure pump, and ensuring the use of original parts. Users discuss the need for adaptation resets after replacing components, with some indicating that a damaged valve may be the root cause of the problem. The conversation highlights the importance of monitoring fuel pressure and the potential impact of faulty sensors and regulators on engine performance.
TL;DR: Audi 2.0 TDI idle rail pressure should remain within ±10 % of ~250 bar; "Resetting will not repair a damaged valve" [Elektroda, Makxio, #17536573; Elektroda, Rafik4, #17524817]. Diagnosing pressure-sensor errors usually reveals a worn common-rail regulator—not a software issue.
Why it matters: Fast identification prevents injector damage and expensive pump replacements.
• Idle rail pressure: Typical 230–280 bar (Bosch CR System Guide). • Rail pressure sensor signal range: 0.5–4.5 V [Bosch, 2017]. • Rail pressure control valve (057 130 764 H) price: ≈ 500 PLN [Elektroda, Rafik4, post #18105097] • Acceptable pressure deviation: ≤ ±10 % [Elektroda, Makxio, post #17536573] • Torque for sensor bolts: 35 ± 5 Nm (Bosch Spec Sheet, 2017).
What usually triggers “Fuel Pressure Sensor – signal too low/high” on the 2.0 TDI?
Most cases trace to a sticking rail pressure control valve. The ECU sees unstable pressure and flags the sensor even when the sensor is healthy [Elektroda, Rafik4, post #18104079]
Do I need to reset adaptations after changing the fuel-pressure sensor?
No. Audi does not require adaptation. "Resetting will not repair a damaged valve" confirms it [Elektroda, Rafik4, post #17524817] Simply clear any stored DTCs.
How can I tell whether the sensor or the valve is bad?
Watch live rail pressure at idle. If it oscillates 170–270 bar while desired stays steady, the valve is faulty [Elektroda, Damian98Audi, post #17528688] Stable pressure that mismatches desired points to a sensor or wiring fault.
What is the correct common-rail pressure at idle for the CAGC engine?
Target is about 250 bar; ECU allows roughly ±10 % fluctuation (225–275 bar) [Bosch CR Guide; Elektroda, Makxio, #17536573].
How do I test the rail-pressure sensor wiring?
Check the three pins: 5 V reference, ground, and signal. Signal should read ~0.5 V with ignition on, rising toward 4.5 V under load [Elektroda, Makxio, post #17536573]
3-step: Replacing the rail pressure sensor safely
  1. Depressurise fuel system (pull pump fuse, crank 5 s).
  2. Unplug connector, remove two T30 bolts, lift out sensor.
  3. Fit new OEM sensor, torque 35 Nm, clear DTCs. Total time: < 20 min (Bosch Service Info, 2017).
Is calibration needed after installing a new rail pressure control valve?
No adaptation exists in VCDS for this valve; the ECU self-learns within seconds [Elektroda, Rafik4, post #17522284]
What are the symptoms of a failing valve versus a failing pump SCV?
Rail-valve failure causes idle surge, pressure jumps, but car starts normally. Pump SCV failure adds hard-start and low-pressure faults during cranking [Elektroda, Makxio, post #17536573]
How much does the rail pressure control valve cost and where can I get it?
Genuine Bosch 057 130 764 H lists around 500 PLN (≈110 EUR) at dealers [Elektroda, Rafik4, post #18105097] Aftermarket copies are cheaper but less reliable.
Can contaminated fuel or metal filings damage the valve?
Yes. Metal particles from a worn high-pressure pump can jam the valve and cause permanent over- or under-pressure—an edge case that quickly triggers P0088/P0087 faults [Elektroda, czaki22, post #17521941]
What happens if rail pressure exceeds 1,800 bar?
Injectors can hydraulically crack; Bosch lists 1,800 bar as the mechanical failure threshold for this system (Bosch CR Failure Modes, 2018).
