[Solved] GeForce GT 730 Driver Installation Issues on Win7/64: GV-N730D3-2GI. 2GB DDR3 & GA-770TA-UD3 Board
Zdzichu 7188 6
  • #1 17534290
    Zdzichu
    Level 32  
    Help: 14
    Rate: 441
    GA-770TA-UD3 board, the graphics card was damaged so I wanted to start a new one.
    I have Gigabyte GeForce GT 730 graphics (GV-N730D3-2GI. 2GB DDR3)
    I can not install drivers for this graphic neither from the supplied CD nor from the manufacturer's website. The system is win7 / 64. It starts installation every time, but after a while an installation error appears. I also downloaded older versions of drivers from nVidia but the effect is the same. When I give update driver / search for the best driver in device manager, it downloads the drivers but writes that the driver is up-to-date. It shows up as unknown device in the manager. The card is new, what could be the problem?
  • #3 17534332
    Zdzichu
    Level 32  
    Help: 14
    Rate: 441
    After being forced, it also starts installing and then such a message.
  • #4 17534602
    DriverMSG
    Help: 3984
    Rate: 4883
    Uninstall the card in the device manager with a check mark to remove the drivers from the system.
    Restart the system.
    Retry the manual installation.
    If the problem returns, check if there are any errors (related to the above-mentioned problem) in the event viewer.
  • #5 17534656
    Zdzichu
    Level 32  
    Help: 14
    Rate: 441
    Still the same after uninstalling and rebooting. In the event log, I don't really know how to get around or what to look for. I would like to add that I put 2 other cards into the computer and both installed without any problems, the system found the drivers only with the GT 730 there is a problem.
    DriverMSG
    Help: 3984
    Rate: 4883
    Zdzichu wrote:
    only this GT 730 is a problem.
    Check it on a different computer.
  • #7 17542338
    Zdzichu
    Level 32  
    Help: 14
    Rate: 441
    The card works, the problem was in the system, after reinstalling the system everything installs correctly.
The user experienced difficulties installing drivers for a Gigabyte GeForce GT 730 graphics card (GV-N730D3-2GI, 2GB DDR3) on a Windows 7 64-bit system. Despite attempts to install drivers from the supplied CD and the manufacturer's website, as well as older versions from NVIDIA, the installation consistently failed, resulting in the card being recognized as an unknown device in Device Manager. Suggestions included forcing driver installation, uninstalling the card and its drivers, and checking the event viewer for errors. Ultimately, the issue was resolved by reinstalling the operating system, which allowed the drivers to install correctly.
