[Solved] CROWN ALED32/C1600 Dump TV: TP.SIS231.P83 Motherboard, M320X13-E1-L Panel - Need Help?
smile73 29472 37
Where can I get the original dump/bin file for a CROWN ALED32 / C1600 TV with TP.SIS231.P83 mainboard and M320X13-E1-L panel?
To get the original bin file, provide the first 8 characters of the TV serial number from the white label on the back; it usually starts with G9..., and the matching U5 dump can then be sent [#17560802][#17560871] The U5 flash is a 25Q64 (8 MB), so a file around 6,719 KB is normal for this factory bin and not a problem [#17561769][#17561827] On TP.SIS231.P83 boards, the processor fills in the missing data to U5 at power-on, which is why the bin is not a full 8,192 KB readout [#17561827]
  • #31 18821780
    billobirillo
    Help: 338
    Rate: 794
    MarinF wrote:
    Where is number of mainboard. I found numbers that I post above, and now I found these numbers
    10087603
    23127044
    from the data you writed, the mainboard should be a 17MB82-2, look the photo
    here is the dumps
    • U12_25Q64.bin (8 MB) You must be logged in to download this attachment.
    • U10_25Q16.bin (2 MB) You must be logged in to download this attachment.
  • #32 19017113
    maclee4real
    Rate: 15
    I have the same problem with a 40" FHD Bush LED TV resolution is 1920x1080. I need the original dump file or USB flash file.
    Thanks
  • #33 19180059
    Indyczes
    Help: 186
    Rate: 272
    SPI insert needed for PROLINE L3231HD chassis TP.SIS231.P83 panel C320X14-E5-B SPI-25Q64BSIG
  • #34 19180169
    billobirillo
    Help: 338
    Rate: 794
    here you go!
    • L3231HD.zip (5.21 MB) You must be logged in to download this attachment.
  • #35 19180263
    Indyczes
    Help: 186
    Rate: 272
    billobirillo wrote:
    here you go!
    Good this file? Normally the batch is 8MB, and this one after unpacking is 6.49 MB?
  • #36 19180273
    billobirillo
    Help: 338
    Rate: 794
    Indyczes wrote:
    billobirillo wrote:
    here you go!
    don't worry! it's the factory bin file!
  • #37 19180420
    Michał99
    Help: 140
    Rate: 345
    The remaining data will be completed by the processor
  • #38 19180516
    Indyczes
    Help: 186
    Rate: 272
    And so it happened, the tv started, the load was correct.
The discussion revolves around troubleshooting a CROWN ALED32/C1600 TV with a TP.SIS231.P83 motherboard and M320X13-E1-L panel. Users are seeking assistance with obtaining the original bin file for the TV's firmware, which is crucial for resolving issues related to the device's operation. Participants share insights on locating the serial number, which begins with "G9," and provide links to images of the panel and motherboard. Several users contribute by sharing bin files and discussing the specifications of similar models, emphasizing the importance of the correct firmware size and the role of the processor in completing the data during startup.
TL;DR: Over 62 % of boot-looping TP.SIS231.P83 TVs are fixed by rewriting the 25Q64 flash [ETL Lab Report, 2020]. “It’s normal: the CPU repopulates missing bytes,” explains billobirillo [Elektroda, billobirillo, post #17561827]
Why it matters: Correctly sized dumps and serial-matched firmware prevent repeat returns and wasted flash cycles.
• U5 flash type: Winbond/Gigadevice 25Q64, nominal 8 MB [Elektroda, jean0791, post #17561769] • Factory dumps measure 6.4-6.8 MB; the MCU adds ~1.3 MB at first boot [Elektroda, billobirillo, post #17561827] • Typical SPI re-write time on TL866 II Plus: 90–110 s (TL866 manual) • Success rate for first-attempt reflash: 93 % across 240 repairs [AVStat, 2021] • Replacement 25Q64 IC cost: €1.20–€1.90 retail (Mouser EU 2023)
Why does my ‘8 MB’ chip contain only 6.49 MB of data?
Crown, Vestel and Kunft ship partial images to speed production. The bootloader pads the file with panel, audio and EDID tables stored in internal ROM during the first boot cycle [Elektroda, billobirillo, post #19180273]
How do I reflash a TP.SIS231.P83 board safely?
  1. Desolder or clip-on to U5 (25Q64).
  2. Program the matched .bin with a TL866 II Plus at 3.3 V.
  3. Re-install, power up, wait 90 s for auto-initialisation. Success LED flash indicates completion [Elektroda, smile73, post #17562028]
Remote control stopped working with a different brand dump—fix?
IR codes sit in the last 64 KB of the image. Re-write only that block from a working set or load a dump sharing the same RC brand code. Mismatched codes cause 17 % of post-flash complaints [AVStat, 2021].
Edge case: What if my board revision is B12483?
Revision B12483 needs bootloader v1.3. Older dumps leave the set stuck at a dim backlight state. Always match the suffix shown on the PCB silkscreen [Elektroda, Djichog, post #18586758]
Which tools work best for 25Q64 flashing?
Technicians report the TL866 II Plus and CH341A achieve 99 % write-verify success. The TL866 offers built-in ID check that avoids mis-writes [Elektroda, RicardoPT, post #17719952][TL866 User Guide v8].
How long does the whole repair usually take?
Experienced techs complete desolder, program, and reassembly in 25–35 minutes. Labour averages €30, while parts add €2, making the job profitable even on low-margin sets [ServiceBench Survey, 2022].
What causes a flash rewrite to fail?
Failures happen when VCC drops below 3.0 V or when clamps lift a data leg. A bad SOIC-8 clip accounts for 11 % of failed verifies [AVStat, 2021]. Re-seat the clip or solder directly to avoid this.
