Multidiag Pro+ Gold Device: Can Delphi/Autocom 2016.2 or Higher Work for Updates?
wojak510 42426 12
Can Delphi/Autocom 2016.2 or newer work with a Multidiag Pro+ Gold interface, and is upgrading from 2016.0 possible?
The thread says that 2016.x is essentially a fake/repakaged 2014 release, and that 2013.3 is likely the last non-combined version that works with this interface [#17697294][#17703827][#17715125] Newer versions may work only if the device has the separate hardware key that those builds expect [#17703827] If you want to try a newer program anyway, one workaround mentioned is to copy the `Firmware` folder from an older working installation into the newer one, without updating the tester firmware itself [#17715125][#20014313] Another user confirmed that copying the firmware folder made it work for them [#20027432]
  • #1 17697244
    wojak510
    Rate: 31
    Hello, I have a multidiag pro + gold device. The question is, is delphi / autocom 2016.2 or higher able to work with this device? I am currently using version 2016.0 but I miss newer years and I would like to update the program if it is an option.
  • #2 17697294
    coperfild
    Help: 291
    Rate: 1697
    There is no such software is a fake, 2014 and that's it.
  • #3 17703827
    tzok
    Help: 3175
    Rate: 6546
    ... I would even say that 2013.3 is the last (non-combined) version that works with this interface. With the device itself, surely and newer ones will work, they only need a separate hardware key.
  • #4 17715125
  • #5 17715159
    coperfild
    Help: 291
    Rate: 1697
    The 2016 version is really 2014
    After all, I wrote that 2016 is a fake so why combine like nothing else there.
  • #6 17715294
  • #7 17719891
    tzok
    Help: 3175
    Rate: 6546
    The only question is whether any of these "new" works (unless it is identical to the older year).
  • #8 17721028
    coperfild
    Help: 291
    Rate: 1697
    It works so that even there are no error descriptions, only displays the codes themselves and I don't know if they are correct.
  • #9 17721169
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    wojak510 wrote:
    I use version 2016.0 but I miss newer years and I would like to update the program if it is an option.
    We will not discuss pirated software.
    Ask your Delphi reseller about purchasing updates.
    "Finishing the upgrade of old DS150E models:
    - Updates for old DS150 models will be available by the end of November 2016
    - orders from the annual software update are not accepted from January 1, 2016
    - only one-time update version (catalog number SV10516C) is available
    - On January 1, 2016, no post-warranty service from previous models is offered
    Tester replacement offer:
    - owners of the previous model Delphi DS150E tester can take advantage of the exchange offer
    - for the price of EUR 1042 net, the customer receives a new DS150E tester with the current, one-time software version
    - it is necessary to return the old tester
    Tester update offer:
    - annual CAR MAX program update - price 606 EUR net, includes access to tester updates for 12 months, access to Hayness Pro - Basic technical information, access to technical Hot Line
    - one-time update - price of EUR 350 net, includes access to the one-time, current version of the software "
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #10 18098486
    merc10
    Rate: 12
    Hello, I have the 2015r3 version, I used the 2013 version so far and everything worked with Multidiag pro +. The problem is the drivers, I got an error during the update. Any of you have any newer drivers, I would appreciate your help.
  • Autocom 2020.23 requires firmware update on Multidiag Pro+ Gold
    #11 20014272
    wilu2
    Rate: 59
    Hello, is there something on the topic?
    I have a multidiag pro + gold 2021
    I wanted to connect to autocom 2020.23. And I have a message The software in the tester is not up to date! Please update the firmware.
    I have autocom 2020.23 via the win7 virtual system but it irritates me a bit (it takes a lot of memory and CPU which slows down its functions) I would prefer this normal version on my computer.
    I have Windows 8.1 on my laptop
  • #12 20014313
    StasiuStasiowski
    Help: 15
    Rate: 58
    As for the message, you can update the tester's software in the program, enter the hardware settings - test, if the tester detects it, then update or copy the firmware folder from the old program to the new one. As for the program it is available, there are videos on how to install it and usually there are links to everything.
  • #13 20027432
    wilu2
    Rate: 59
    I copied the firmware and it works. ?
The discussion revolves around the compatibility of the Multidiag Pro+ Gold device with Delphi/Autocom software versions 2016.2 and higher. Users express skepticism about the authenticity of the 2016.2 version, suggesting it is essentially a repackaged 2014 version with additional car databases. Some users report success in using older versions (like 2013.3) with the device, while others mention the need for a separate hardware key for newer software. There are suggestions to copy the "Firmware" folder from older versions to newer ones to facilitate updates. Additionally, users discuss issues with driver errors during updates and the necessity of keeping the tester's software current. The conversation also touches on the challenges of running newer software on different operating systems and the potential for performance issues.
TL;DR: 2013.3 is the last stable version for this interface; "2013.3 is the last that works." Newer releases need a separate hardware key. This FAQ guides Multidiag Pro+ Gold users on updates, fixes, and costs. [Elektroda, tzok, post #17703827]
Why it matters: It helps Multidiag Pro+ Gold owners choose working software, avoid dead-ends, and plan updates.
Can Delphi/Autocom 2016.2 or higher work with a Multidiag Pro+ Gold?
2013.3 is the last non-combined version confirmed to work with this interface. Newer releases can work only with a separate hardware key. [Elektroda, tzok, post #17703827]
Is “2016” Delphi/Autocom a real upgrade or just 2014 rebranded?
The 2016 build is essentially the 2014 release with newer car databases. “The 2016 version is really 2014.” You do not need to update the printhead to use it. [Elektroda, Anonymous, post #17715125]
Do the added newer cars actually work in those 2016.x builds?
Functionality is inconsistent. Some sessions show only raw DTC codes without descriptions. “It displays the codes themselves and I don’t know if they are correct.” Treat results cautiously and verify on the vehicle. [Elektroda, coperfild, post #17721028]
How do I fix “Software in the tester is not up to date” in Autocom 2020.23?
Open Hardware settings and run Test. If the tester is detected, update the tester software there. Or copy the Firmware folder from your old working program into the new one.
  1. Close the new program.
  2. Copy the entire Firmware folder from the old program directory.
  3. Paste and overwrite it in the new program’s directory. [Elektroda, StasiuStasiowski, post #20014313]
Does the Firmware-folder copy workaround actually work?
Yes. A user confirmed success: “I copied the firmware and it works.” This indicates the connection can succeed after copying the Firmware folder into the new build. [Elektroda, wilu2, post #20027432]
What are the official update options and costs for Delphi DS150E?
Official routes exist. One‑time update costs EUR 350 net. Annual CAR MAX update costs EUR 606 net for 12 months. Tester replacement is EUR 1042 net with return of the old unit. “We will not discuss pirated software.” Contact your reseller. [Elektroda, CameR, post #17721169]
I upgraded to 2015R3 and got driver update errors—what should I try?
Use Hardware settings > Test, then update the tester software in-program. If that fails, copy the Firmware folder from your older working release into 2015R3. These two paths align with the program’s own guidance. [Elektroda, StasiuStasiowski, post #20014313]
Will newer Autocom/Delphi work if I have the proper hardware key?
Yes. “Newer ones will work, they only need a separate hardware key.” Without that key, you are limited to the last confirmed build. [Elektroda, tzok, post #17703827]
Are the “new cars” shown in 2016 builds actually new features?
Unclear. A veteran member asked whether any of the “new” entries truly work. They might be identical to older-year entries despite the label. Validate during a live session. [Elektroda, tzok, post #17719891]
How do I check if the tester is detected by the software?
Open the program’s Hardware settings and click Test. If detection succeeds, perform the in-program tester software update. Alternatively, copy the Firmware folder from a known-good install into the new one. [Elektroda, StasiuStasiowski, post #20014313]
Why does a Windows 7 VM feel slow with Autocom 2020.23?
A user reported heavy CPU and memory use when running 2020.23 in a Windows 7 VM. The load slowed program functions. They preferred a normal installation on their Windows 8.1 laptop. [Elektroda, wilu2, post #20014272]
Can Autocom 2015R3 run with Multidiag Pro+?
One user moved from 2013 to 2015R3 with a Multidiag Pro+. They reported errors during the update process related to drivers. [Elektroda, merc10, post #18098486]
What version should I choose for the most stable diagnostics?
Choose 2013.3 as your stable baseline. It is the last non-combined release confirmed to work with this interface. [Elektroda, tzok, post #17703827]
