Connecting Ospel Two-Key Shutter Switch: Somfy Programmer Replacement, Cable Connections & Wiring
MaleLampy 33750 9
How do I wire an Ospel two-key shutter switch to replace a failed Somfy roller-shutter programmer when the cable colors and terminal mapping are unclear?
You should not wire it by guesswork: the Ospel switch has three paired terminals (1/2, 3/4, 5/6), so electrically it gives you three connection points, and the blind neutral is normally joined outside the switch while the phase is switched to the two direction wires [#17576072] In the installation described by the poster, the blue wires were actually connected together in a connector outside the switch, while the switch itself carried the brown supply wire, the brown blind wire, and the blind’s yellow-green wire [#17576195][#17576409] That implies the yellow-green conductor from the blind was being used as a live control wire rather than as protective earth, but several replies warn that this is nonstandard and unsafe to assume without checking the actual blind wiring or measuring it first [#17575683][#17576252][#17576072] The Somfy unit was confirmed to be the failed controller, but the exact replacement connection still depends on verifying which conductor is neutral and which two are the shutter directions before energizing anything [#17575759][#17576072]
  • Wiring guidance for Ospel two-key shutter switch
    #1 17575563
    MaleLampy
    Rate: 9
    Dear forum users,
    Recently, the Somfy programmer from the external roller shutter has broken down. Unfortunately, the new one costs PLN 350 and for now I have to postpone such an expense definitely.
    In its place I would like to mount the Ospel two-key switch attached in the photo. Unfortunately, I can't read the pattern learned from it. I regret not buying another company because then I would not have a problem with it.
    Could I ask you for help and answer, which cables where to connect?
    I marked in the picture:
    - red wheels holding screws (each holding two);
    - numbers from 1 to 6 for cable connections.
    In the can I have:
    - phase wire (brown) of the electric network
    - neutral (blue) network cable
    - ground wire (yellow-green) of the network that has not been used before
    - phase wire (brown) blinds
    - neutral (blue) blinds
    - ground wire (yellow-green) blinds, not used yet
    I would be grateful if you could tell me which wire to connect.
    Thank you very much.
  • Need Somfy controller model and wiring confirmation
    #2 17575683
  • Somfy Chronis Uno/Memoris Uno identified as programmer
    #3 17575759
    MaleLampy
    Rate: 9
    You are right - the yellow-green from the blind could be used. A network ground wire is tied with a knot.
    I cannot determine exactly how the cables were connected in Somfy. The service has left the Somfy programmer loose and the cables protruding from the can. They came to two blinds - in the end I decided to fix one and the other I had to let go because of the costs and the fact that the cheapest connector / programmer was Somfy for PLN 350 for the price of the material.
    However, they determined that it was definitely a programmer, because they connected the blind to the electrical outlet and worked.
    The programmer, which was Somfy Crhonis Uno / Memoris Uno.
    Attached picture.
  • Need to verify the yellow-green conductor before wiring the switch
    #4 17576072
  • Yellow-green wire likely used as blind phase lead
    #5 17576195
    MaleLampy
    Rate: 9
    Erbit wrote:
    Because the "fern" ran out of veins, he decided to use the protective conductor (yellow-green) in an unauthorized way (or assumed in advance that he would connect it). Now it is not known what this yellow-green wire running to the blinds is supposed to do - whether it is to serve as "zero" or as "opening attempt" (phase).
    Thank you for the message - I am almost convinced that the yellow-green wire from the blind was used as a phase - opening control. I would conclude that the network ground wire is tied with a loop.
    I guessed that the blue cables should be connected. So it would appear that the blue next to this connector would have to be connected outside of it, while:
    - brown power supply put in 1;
    - brown blind in 3;
    - green-yellow blind in 5 (assuming that it is used as a vein).
    Am I right?
    In addition, the service, which was in the case of two roller blinds, connected them both to the power supply using clamps connected to the roller shutter cables in a box on one side and on the other there was an ordinary plug, which they inserted into the socket. There was a switch in the middle of the cable that made the blind close / open. Which in my opinion would confirm that the yellow-green from the blind is a "vein" and not an earth ground.
  • Need to inspect the blind’s internal wiring
    #6 17576252
  • Blue wires are spliced externally, only brown and earth go to switch
    #7 17576409
    MaleLampy
    Rate: 9
    Erbit wrote:
    Guesses refer to the color of the wires and guesses apply separately to the place of connection (I did not find the description of Ospel) although you are right in principle.
    I just checked the second switch (because in the second place I have a one-button switch up / zero / down) and actually the blue ones are connected with a cube outside of it, while the brown network and brown from the blind and the yellow-green from the blind are connected to the switch. There is no additional vein.
  • #8 17576528
  • #9 17576551
    MaleLampy
    Rate: 9
    Erbit wrote:
    I dare to doubt it
    You are right - it would be easier for me because other manufacturers have either good diagrams on the Internet or more default markings on connectors.
    Thank you very much for your help. Tomorrow I will try to test the hypothesis in practice ;-) .
  • #10 18019155
    guest666
    Rate: 13
    Here's the diagram ...
    And all clear ;) ... interesting solution ... Connecting Ospel Two-Key Shutter Switch: Somfy Programmer Replacement, Cable Connections & Wiring
The discussion revolves around replacing a broken Somfy programmer for roller shutters with an Ospel two-key switch. The user seeks assistance in wiring the new switch, detailing the existing cable connections, including phase, neutral, and ground wires. Responses highlight the uncertainty regarding the use of the yellow-green wire, which may have been incorrectly utilized as a phase wire. Suggestions include connecting the blue wires externally and using specific terminals for the brown and yellow-green wires. The conversation emphasizes the need for clarity in wiring connections and the importance of verifying the existing setup to avoid potential hazards.
