What are the migomets you recommend? I like the ideal prakt mig 200 worth?
vSEBOv 35064 15
Is the Ideal Praktik MIG 200 worth buying, or should I choose a used branded MIG welder for welding 1–5 mm sheet metal on a 1000–1200 PLN budget?
The Ideal Praktik MIG 200 does not look like a safe buy; several users report repeated failures and describe it as not worth it or even disposable [#18770178] [#19775447] One user instead recommends the Sherman Dualmig 200, saying it has 8 current settings, works well on thin car sheet and thicker material, runs from 230 V single-phase power, and should fit your budget [#16999017] Another suggestion is a used older transformer-based welder, which is heavier but easier to repair, and its short duty cycle can be improved with forced cooling from one or two fans [#19775490] A factory-repaired Fanmig J15/C15 was also mentioned as available for about 1200 PLN and seemingly worth considering [#18770329]
  • #1 16977386
    vSEBOv
    Hello all :D I have question for you. I am going to buy a migomat, I just do not know how (ideal praktik mig 200 I came across such an Allegro like it I just do not know if it's worth it) and the budget limits me a little, for 1000-1200 PLN. Do you recommend to buy the ideal praktik mig 200? Or maybe some brand name used eg: Bester, Einhell. The thickness of the sheets that I will weld is max 5mm more 1-3mm. I am waiting for the answer: 3
  • Sherman Dualmig 200 recommended for home welding
    #2 16999017
    anaba255
    Help: 95
    Rate: 263
    I recommend Sherman dualmig 200 from myself, I have been using it for 10 years, I am an amateur at home, sometimes small things for my friends. The advantage of this welding machine is a large range of welding current adjustment (8 positions), it is nice to weld thin sheet metal (car), but thick also gives advice. Another advantage (at least for me) is 230V power supply, one phase, you connect it everywhere. For this, buy cylinders with a mixture of CO2Ar, definitely better quality of welds than CO2 and a good reducer with two clocks. You should fit in the budget you have set.
  • #3 17269287
    Mr_Z
    Rate: 43
    And which model did the author of the subject acquire? Because I myself think about this ideal praktik and I do not know if it is worth buying or not.
  • #4 18590550
    ciapsko
    Mr_Z wrote:
    And which model did the topic author acquire? Because I wonder about this ideal practical and I don't know if it's worth buying or not.
    I am raising the question. I'm curious. :)
  • #5 18682774
    balcerowicz79
    Rate: 84
    And what did anyone buy this Ideal Praktik mig 200?
  • #6 18770178
    j.h
    Hello, as to this Praktik mig 200, I would think twice. I bought in March, I welded 2 tubes and the equipment stopped, I sent for guarantees, they did, it lasted 2 weeks. I slept 15 minutes ok, yesterday I started welding again, 2 minutes and again lime. Symptoms as before, until the plugs crashed and again I have to send for warranty, and now the equipment needed. Yes, please, ladies and gentlemen, to think about it.
  • #7 18770186
    Grzegorz_madera
    Help: 268
    Rate: 1736
    And what did you expect from a Chinese toy for less than 1000 PLN?
  • #8 18770221
    j.h
    And I thought that at least the guarantee would last, the gentleman who sold said that the equipment is OK. ?
  • #9 18770329
    balcerowicz79
    Rate: 84
    I rummaged in the network and the bridge company offers a mig15 c15 for 1,200 PLN after a factory repair, a factory defect or something ... If I had cash I would be tempted ... Apparently good ...
    https://www.rywal.com.pl/produkty/fanmig-j15-polautomat-spawalniczy-detail.html
    • What are the migomets you recommend? I like the ideal prakt mig 200 worth? Screenshot_2020-06-20-10-04-44.png (194.29 KB) You must be logged in to download this attachment.
  • #10 18771017
    anaba255
    Help: 95
    Rate: 263
    Chinese is not equal to Chinese, mine cost even less and works 12 years, no problems. Now, even good brands produce in Asia, and they demand you to be valued, I have already run more than once on branded equipment, and the market is half price.
  • #11 18801739
    biba24
    Help: 19
    Rate: 181
    My idel like my friend above. The day before yesterday he fell twice. It is still under warranty. But I'm already angry that I didn't buy a magnum or a used beast. My friend has a castorama maca and has been welding for over a year.
  • #12 18925095
    waldemas1
    Rate: 24
    Hello, where did you buy these ideal practical?
  • Melted board caused premature MIG failure
    #13 19773744
    Pawelk1212
    I bought it on Allegro, it welded well and I was satisfied. She was putting out 1 roll of wire, at the beginning of the second she was dead. After removing the housing, the molten plate can be seen with the naked eye. The warranty ended moments ago, local websites, after hearing the brand, do not even want to watch. When I bought it, I was happy, now I can see that it was not worth it, literally a disposable one. If someone has information on the company that would undertake the inspection, I would like to ask.
  • Moisture protection and board coating improve durability
    #14 19774772
    balcerowicz79
    Rate: 84
    I already bought a tiny 140A mma sherman from 3 years ago and it works to this day, but after welding I blow it and take it to the house.
    These Chinese inverter migomats often burn plates because they are poorly protected against moisture and metal dust which is ubiquitous in the workshop.
    A colleague painted his flashing plate with the preparation and he has been enjoying welding for 3 years, even though he does not hide it under the covers after the work is finished. But he was not afraid of losing the warranty, he did it right after the purchase.
    I bought an old man like the one from the picture for PLN 300 and he is like this doll
    • What are the migomets you recommend? I like the ideal prakt mig 200 worth? Screenshot_20210415-113751.png (753.71 KB) You must be logged in to download this attachment.
  • #15 19775447
    Pawelk1212
    It may be that it is the fault of humidity and in "home" conditions it would last longer. However, I am disappointed and I said goodbye to the IDEAL brand. To the question of the author of the topic, I can only answer that in my case it was not worth it.
  • Forced cooling can improve duty cycle on transformer welders
    #16 19775490
    balcerowicz79
    Rate: 84
    I was also thinking about the Ideal. Nice new, promised large work cycles and light, but still I went to other old equipment with obvious flaws due to the design, heavy because it is a transfirmator, but easy to repair. T.
    am you can either burn out rectifier diodes or, less likely, a transformer that can be overturned.
    The poor work cycle can be slightly improved by forced cooling, i.e. a fan or even two fans, e.g. from a computer power supply and some 12v power supply for a few zlotys.
    I read something there that the magnum is more durable or even a fantasy welder, but unfortunately more expensive.
The discussion revolves around the Ideal Praktik MIG 200 welding machine, with users sharing their experiences and recommendations for MIG welders within a budget of 1000-1200 PLN. Some users express dissatisfaction with the Ideal Praktik MIG 200, citing reliability issues and poor performance after minimal use. Alternatives such as the Sherman Dualmig 200 and older models from brands like Magnum and Bester are suggested as more reliable options. Users emphasize the importance of quality components, proper maintenance, and the impact of environmental factors on the longevity of welding machines. Overall, there is a consensus that while the Ideal Praktik MIG 200 may seem appealing, it may not be worth the investment due to its reported shortcomings.
TL;DR: On a 1,000–1,200 PLN budget, users favored an 8‑position MIG like Sherman DualMIG 200; one expert noted “you connect it everywhere.” [Elektroda, anaba255, post #16999017]
Why it matters: This FAQ helps hobby welders choose a reliable 230V MIG, avoid common failures, and set up gas correctly.
Is the Ideal Praktik MIG 200 worth buying at this budget?
Multiple owners reported early failures and warranty hassles. One user called it “literally a disposable one” after a board melted soon after the warranty. For a limited budget, community sentiment leaned against this model’s reliability. Consider sturdier alternatives or used pro gear. [Elektroda, Pawelk1212, post #19773744]
What alternative MIG welder did users recommend?
Sherman DualMIG 200 received a positive, long‑term report. The owner highlighted 8 current settings and good thin‑sheet control. They also praised 230V convenience for home use. “It welds nice thin sheet metal.” This aligns well with hobby and auto body tasks. [Elektroda, anaba255, post #16999017]
Can I run a MIG welder from a standard 230V outlet at home?
Yes, several hobby‑class units use 230V single phase. The benefit is plug‑and‑play convenience across typical household circuits. One user summarized it as, “you connect it everywhere.” Always verify your circuit’s amperage and use safe practices. [Elektroda, anaba255, post #16999017]
Which shielding gas is better for car panels: CO2 or CO2/Ar mix?
Users reported better bead quality with a CO2/Ar mixture versus straight CO2. A dual‑gauge regulator and a proper cylinder improve consistency. Expect smoother arc starts and reduced spatter on thin sheet. This advice targets hobby auto repair and light fabrication. [Elektroda, anaba255, post #16999017]
How thick can I weld with these budget MIGs?
Owners focused on thin sheet (1–3 mm) and up to about 5 mm. One Sherman user said it handles car body panels yet also manages thicker stock within limits. Prep, bevels, and multiple passes help on thicker joints. [Elektroda, anaba255, post #16999017]
What failures were reported with Ideal Praktik MIG 200?
Reports included machines stopping after minutes, tripping plugs, and even a visibly melted main board. One unit died near the start of its second wire roll. Treat these as red‑flags for durability under workshop conditions. [Elektroda, Pawelk1212, post #19773744]
How big is the risk of very early failure?
At least one user saw a repeat failure within two minutes of welding after prior service. That is an extreme edge case but important for risk assessment on time‑critical jobs. Consider backup plans if buying low‑cost gear. [Elektroda, j.h, post #18770178]
Does humidity or metal dust affect inverter MIG welders?
Yes. Users linked board burnouts to poor protection against moisture and conductive dust. Storing the welder indoors and blowing it out after use helps. One owner coated the board and reported three years of trouble‑free use. [Elektroda, balcerowicz79, post #19774772]
Can adding fans improve the duty cycle on older or budget welders?
Forced cooling can help. A user improved a transformer unit’s work cycle by adding one or two 12V fans and a small supply. Ensure safe wiring and proper airflow paths. This is a low‑cost optimization for hobby use. [Elektroda, balcerowicz79, post #19775490]
Is a used transformer welder a safer bet than a cheap inverter?
Some users preferred heavy transformer machines for repairability. Failures often limit to rectifier diodes or the transformer. They trade weight for durability and predictable fixes. It’s a pragmatic path when uptime matters. [Elektroda, balcerowicz79, post #19775490]
Where did people buy these entry‑level MIGs?
One owner bought on Allegro. They were initially satisfied until the unit failed just after the warranty. If buying online, confirm return policies and local service options before checkout. [Elektroda, Pawelk1212, post #19773744]
What if local service centers refuse to inspect my brand?
A user reported local shops declined the brand. In that case, contact the seller for authorized service routes, or seek electronics specialists comfortable with inverter repairs. Document symptoms and photos before shipping. [Elektroda, Pawelk1212, post #19773744]
How many current settings do I need for car body work?
Eight steps gave one owner good control on thin sheet while retaining range for thicker parts. Finer steps help tune heat input and reduce burn‑through on 0.8–1.0 mm panels. “It is nice to weld thin sheet metal.” [Elektroda, anaba255, post #16999017]
Quick setup: how do I start MIG welding at home with a 230V unit?
  1. Connect to a suitable 230V circuit and verify grounding.
  2. Fit CO2/Ar cylinder, set flow with a dual‑gauge regulator.
  3. Select a midrange current step, test on scrap, then tune wire speed. [Elektroda, anaba255, post #16999017]
