How to Refill Pressure in a Viessmann Vitodens 111 Boiler
wiadrak 31812 8
  • #1 17589640
    wiadrak
    Rate: 19
    I recently purchased a Vitodens 111 boiler and the pressure dropped below 1 bar.
    The question is which valve can let water in, because I can`t find information on this anywhere.
    ta_tar
    Help: 699
    Rate: 2052
    And there`s nothing about this in the manual? Just in case, I`ll give you the one I have.
    • Vitodens 111-W typ B1LD.pdf (13.02 MB) You must be logged in to download this attachment.
  • #3 17589717
    wiadrak
    Rate: 19
    Not really, I remember that the installer said that you can top up the water using one of these valves, but I don`t remember which one.
  • #4 17589816
    ta_tar
    Help: 699
    Rate: 2052
    And don`t I write anything on page 8 of this manual? I don`t know if you have the same layout as in the picture.
  • #5 17590553
    wiadrak
    Rate: 19
    You see, I missed it, so it turns out that the right knob is for admission.
  • #6 17591007
    ta_tar
    Help: 699
    Rate: 2052
    Check if this manual of mine is really for your boiler. You only provided the initial boiler designation.
  • #7 17592003
    wiadrak
    Rate: 19
    Yes, the same, the installer also added that you need to unscrew one valve slightly and the other one can be turned up to the maximum and reach 1.2 bar, but it is best if the furnace does not run. I found this information somewhere else, so I guess it`s correct.
    There should be 2 black knobs under the boiler (from the bottom). First open one, then the other - about 4-5 turns. Any order. After topping up to 1.5 bar - close.
  • #8 17592613
    ta_tar
    Help: 699
    Rate: 2052
    So try it and see what happens.
  • #9 17604221
    wiadrak
    Rate: 19
    I added water and it`s OK for now. You need to turn both valves to the left (from the bottom, looking counterclockwise) several times, in my case 3 times, and place a bucket under it because something may drip, and wait, in my case it filled very slowly, but it can probably be done faster. The installer recommended 1.2 bar and that`s what I got.
✨ The discussion revolves around refilling the pressure in a Viessmann Vitodens 111 boiler, which had dropped below 1 bar. Users sought clarification on which valve to use for adding water. It was noted that the manual may not provide clear instructions, but one user identified that the right knob is for water admission. Another user confirmed that both valves need to be turned counterclockwise to refill, with a recommendation to achieve a pressure of 1.2 bar while ensuring the boiler is not running. Users shared their experiences, indicating that the process may be slow and suggested placing a bucket underneath to catch any drips during refilling.
