Comparing Orlen Platinum Engine Oil: Quality and Value Assessment
LENIWIEC_PL 81105 35
Is Orlen Platinum engine oil worth buying, and is it any good for a car engine?
Orlen Platinum is generally seen as acceptable budget oil, but only if you pick the exact variant that meets your engine’s required specification and viscosity; for the Land Rover example, the needed spec was WSS M2C913, so Platinum Pro would be appropriate, not just any Platinum [#17651194] Several users reported trouble-free long use on Orlen oils—100,000 km in one car, 30,000 km fleet intervals, and 285,000 km in an Alfa 156 on semi-synth—with no abnormal wear or oil consumption [#17649907][#17651173][#19505135] One poster also noted that Orlen produces oils for Castrol, suggesting the label alone is not a reliable quality indicator [#17649568] The main criticism was that some cheaper/mineral Platinum oils can leave more carbon deposits and may be less suitable for more demanding engines, so shorter oil-change intervals are recommended [#17649770][#17651545] In short, it can be worth it as a low-cost oil for the right engine, but buy by specification, not by brand name alone [#17649907][#17651194]
  • #1 17617233
    LENIWIEC_PL
    Help: 119
    Rate: 322
    I warmly welcome.
    Well, recently reviewing various prices of engine oils I came across oils of the "Orlen" group under the name Platinum in red bubbles. You need to pay around PLN 60 for a 5l bank, so the price is low compared to a mobile or a sheel, for example.
    But what do you think about this oil? Is it worth it
  • #2 17617257
    fifcio13-13
    Level 30  
    Help: 148
    Rate: 305
    Chicken feed. Unless you have to pour for sale, then I recommend.
  • #3 17617262
    kortyleski
    Help: 957
    Rate: 3858
    Oil like oil, viscosity grade must stick. You can assume more frequent changes of cheaper oil, the engine will only work out health.
  • #4 17618047
    BANANvanDYK
    Help: 1167
    Rate: 2599
    About 10 years ago there was a scandal connected with monopolistic practices, after which a millionth penalty was imposed. The entire report is presented at UOKiK, although with some classified information. One can deduce from them. "Premium" or "premium gold" oils are just a marketing gimmick to push the price of a product. On the other hand, oils from the bottom shelf are again quality goes the other way. Like Platinum, and Superol quality. Similarly, recently someone brought me oil dedicated to tractors, and qualitatively Superol CC SAE 30 ... To the disadvantage of this group is the fact that they do not have a contract for the first flooding in cars, or the lack of oils dedicated to given cars / engines which would be recommended by producers. One exception is Yamaha, but I'm not in the subject.
    Take into account that mineral oil, no matter whether engine, gear or hydraulic, should cost at wholesale quantities about 10 PLN / liter ...
  • #5 17648638
    Electro855
    Rate: 17
    Orlen has very bad opinions. It is better to add a few zlotys and buy something better ;)
  • #6 17649568
  • #7 17649770
    fifcio13-13
    Level 30  
    Help: 148
    Rate: 305
    cefaloid wrote:
    Any evidence to support this thesis?
    Is classic grumbling 'bad because it's Polish'?
    (There are strong financial groups who would care for that)
    Orlen also produces oils for Castrol, if someone likes to give more for the same and feel better with it is such an option.
    Bad oil, the engine got stuck on it every 10-12 thousand. km. A friend also rode it and after unscrewing the valve cover there was already a very large carbon deposit.
  • #8 17649840
  • #9 17649907
  • #10 17649972
    yogi009
    Help: 848
    Rate: 2650
    atari_robbo wrote:
    They stay on the market not because they sell good products - only because they pump money from the state budget by hand.
    And that's an interesting thought. Orlen - no matter about the quality of its products - is the largest Polish taxpayer. It does not have to have state subsidies. Please do not sow defeatisms.
  • #11 17650149
    *Impala*
    Help: 5
    Rate: 39
    I'm curious why they still produce Mixol after all, this oil is not even suitable for lubrication of hinges, their cheaper oils have always left huge amounts of carbon deposits, with the more expensive ones I did not risk.
  • #12 17650330
    yogi009
    Help: 848
    Rate: 2650
    Mixol is very good when you pour gas instead of oil :-)
  • #13 17650549
  • #14 17651118
    fifcio13-13
    Level 30  
    Help: 148
    Rate: 305
    cefaloid wrote:
    What engine has stuck to it, to whom exactly and at what course?
    I am asking because I have already done 100,000 km on this Orlen and I do not see these terrible masses and carbon deposits or signs of blur. Maybe this engine was a turn from the trader, flooded with a motorized driver and would get stuck on anything?
    2.7TDV6 engine from Land Rover Discovery 3, mileage below 245 thousand. km.
  • #15 17651173
    Eidems
    Help: 83
    Rate: 253
    Fleet cars are often flooded with orlen oil (e.g. max platinum) or comma oil and what? And the cars drive without a problem, nothing happens to them, and they do 30 thousand from exchange to exchange on such eagle and this is proof for me that you can buy cheaper oil and nothing will happen. As for this Land Rover, surely the oil itself has not blurred the engine, and please do not write stupidity!
  • #16 17651192
    fifcio13-13
    Level 30  
    Help: 148
    Rate: 305
    The engine has been regularly serviced. The second engine in the Range Rover with Motul oil has already traveled easily + 350,000 km. I don't think anything else is causing a fault than the oil itself because the shells have turned and the crankshaft has broken.
  • #17 17651194
  • #18 17651211
    Eidems
    Help: 83
    Rate: 253
    The new fleet skats are flooded with 5w30 Orlen platinum MAX oil, they do 30,000 from exchange to exchange, nothing happens, so you really had to be unlucky just with this car, the oil had nothing to do with it.
  • #19 17651226
    fifcio13-13
    Level 30  
    Help: 148
    Rate: 305
    Even if I was unlucky - because there may be a defective part, this oil certainly shortened its lifetime. I have not used this oil since then. It is the fifth car that I have and pour good oils since. No problem, nothing happens.
  • #20 17651545
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6428
    LENIWIEC_PL wrote:
    You need to pay around PLN 60 for a 5l bank, so low price
    And how is the mineral mountain ...... the normal price is qualitatively suitable for the c330, Fiat 126p and lawn mowers.
    Somehow I do not remember that one of the car engines had dedicated 15w40 oil for use.
    I had x10xe after pouring orlen baked rings on one cylinder. They are also not fairy tales.
  • #21 19445765
    szogun114lm
    Rate: 8
    Hello. For several years I have been pouring PLATINUM Max Expert C3 5W40 oil into my 1.9TDI and nothing is happening to my car. It also uses PLATINUM oils for other cars and I highly recommend them !!! I use PLATINUM AGRO for tractor and agricultural machinery. Do not be deceived that Polish is bad - quite the opposite.
    I HIGHLY RECOMMEND PLATINUM OILS !!!
  • #22 19445771
    Help: 1405
    Rate: 6428
    In such a tractor it is not surprising, flood 1.6 hdi or d4d, you will regret it quickly. I had the transition from platimumen so I do not recommend it. Well, for the C330 and similar constructions.
  • #23 19446110
    yogi009
    Help: 848
    Rate: 2650
    You're exaggerating. Oil is oil, refineries around the world already have installations for its production. This is not building a space shuttle.
  • #24 19446238
    gibon139
    Help: 25
    Rate: 42
    Oil for the old corpse is ok.
  • #25 19446244
    yogi009
    Help: 848
    Rate: 2650
    Do not buy this and fuel on Orlen :-) CircleK (former Statoil) also sends its barrel wagons to Płock.
  • #26 19446309
    strucel
    Level 36  
    Help: 271
    Rate: 623
    And if I flood these engineering wonders with oil for PLN 100 / liter, I will travel without problems with only the replacement of consumables? Somehow I doubt ...
  • #27 19446395
    Help: 1405
    Rate: 6428
    not for PLN 100 but for PLN 42 a liter, so apart from exploitation activities, you should drive 600kkkm calmly.
  • #28 19446407
    lukaszmech
    Level 19  
    Help: 26
    Rate: 48
    I personally flooded my 10w40 GM 2.0 DTH diesel when I disassembled the engine shell as new, nothing worn, and I flew 100,000. on him. In most of the engine failures, it is not the oil that is to blame, but the design defects of the engines and the prolonged interval
  • #29 19446415
    Help: 1405
    Rate: 6428
    10w40 in 1.9tdi and 1.8 tddi in winter 2nd props hydro tappets! So don't write that it's safe. As the engine goes out while driving and you feel the lack of compression.
  • #30 19446438
    anchilos
    Help: 491
    Rate: 964
    lukaszmech wrote:
    as I disassembled the bearing motor as new, nothing worn and I flew 100,000. on him.
    Write for what reason you dismantled the engine after 100kkm.
    Greetings.
The discussion centers around the quality and value of Orlen Platinum engine oil, particularly its pricing compared to other brands like Mobil and Shell. Users express mixed opinions, with some recommending the oil for its affordability and satisfactory performance in certain vehicles, while others criticize it for poor quality and potential engine damage. Concerns are raised about the oil's ability to maintain engine health over time, with anecdotal evidence of carbon deposits and engine failures linked to its use. Some participants argue that Orlen oils meet necessary standards and can perform well, especially in older or less demanding engines. The debate also touches on the perception of Polish products and the marketing strategies of oil brands.
TL;DR: At ~60 PLN for 5 L (12 PLN/L) [Elektroda, LENIWIEC_PL, post #17617233], Orlen Platinum meets ACEA C3, and “Oil is oil” [Elektroda, yogi009, post #19446110]; after 10 000 km intervals users report 0 L burn-off [Elektroda, WiesawPrzybya, post #19505135]
Why it matters: Knowing real-world results helps decide if saving 30–50 % on oil is smart or risky.
• Common viscosity grades: 5W-30, 5W-40, 10W-40, 15W-40 [Orlen Datasheet, 2021] • MaxExpert C3 carries ACEA C3 & API SN approvals [Orlen Datasheet, 2021] • Pro line meets Ford WSS-M2C913 & VW 502.00/505.00 [Orlen Datasheet, 2021] • Retail price: 60–90 PLN per 5 L, vs 140 PLN for top imports [Elektroda, LENIWIEC_PL, post #17617233] • Forum users change every 10–12 k km despite 15 k km OEM max [Elektroda, kortyleski, post #17617262]
Is Orlen Platinum engine oil good value for money?
Yes. It costs about half of major imports yet carries identical ACEA/API approvals and OEM specs [Orlen Datasheet, 2021]. Several drivers logged 100 000 km without sludge or extra consumption [Elektroda, 19445765; 19505135].
Why do some users call it “chicken feed”?
Early mineral 15W-40 versions were basic and left deposits in outdated engines [Elektroda, Strumien …, post #17651545] Newer semi- and full-synthetics meet stricter C3/SN standards, so the nickname lingers more than the problem.
Did Orlen oil seize a Land Rover 2.7 TDV6?
One user reported bearing failure at 245 k km after 10–12 k km changes [Elektroda, fifcio13-13, post #17651118] That engine is known for fuel-dilution issues that ruin oil life [Jaguar Forum Post]. So oil quality was likely a factor, not the sole cause.
Does Orlen really manufacture Castrol oils?
Yes. Rafineria Gdańsk blends some Castrol, Shell and Mobil products under contract [Elektroda, Anonymous, post #17649907] Formulations differ; only the refiner is shared.
Can I use Platinum 5W-40 in modern 1.6 HDI or Toyota D-4D?
Only if the label shows ACEA C2 or PSA B71 2290 for HDI, or ACEA C2/C3 for D-4D. Standard MaxExpert C3 fits Toyota but not the HDI’s low-SAPS need [Orlen Datasheet, 2021].
How often should I change cheaper Polish oil?
Forum consensus: every 10–12 k km or once a year [Elektroda, kortyleski, post #17617262] Shorter intervals offset any additive fade and match high-end oil protection.
Will Platinum clog hydraulic tappets in winter?
The 5W grades stay fluid to –30 °C. Users blaming tappet knock used 10W-40 during –20 °C starts [Elektroda, Strumien …, post #19446415] Choosing the right viscosity avoids that edge-case failure.
Does Orlen still sell outdated Mixol 2-stroke oil?
Yes—for chainsaws and vintage engines. It lacks modern low-ash additives, so avoid it in direct-injection 2-stroke motors [Elektroda, Impala, post #17650149]
How do I check if a bottle meets my engine spec?
Look for the ACEA/API line and any OEM code (e.g., VW 505.01). Cross-match with your manual. If missing, choose a higher grade or another range.
3-step How-To: Pick the right Orlen Platinum oil
  1. Find your manufacturer code (e.g., GM dexos2) in the service book.
  2. Visit Orlen’s online selector or read the label until you see the same code.
  3. Select 5W-30 or 5W-40 if you need DPF/low-ash compliance; use 10W-40 only for pre-2000 engines.
Are all refineries’ oils basically the same?
“Installations worldwide can now make oil that meets the standards” [Elektroda, yogi009, post #19446110] Base stocks are similar, but additive packages differ. Approvals, not brand, decide suitability.
