Q-Smart Suzuka Pro SW6060: Seeking PC Steering Wheel Drivers - Help Needed!
Łukasz7689 37212 13
How can I find a driver for the Q-Smart Suzuka Pro SW6060 steering wheel, and why is the vibration not working in Windows?
Try the driver shared in the thread; after installing it, the steering wheel became detectable by the PC again [#17685068][#17714847] The wheel was identified as a Gamepad Adapter / HID-compatible game controller with VID_0E8F and PID_0003, so those device IDs are useful if you need to search for matching support [#17652695][#17652772] If the wheel still works as a controller but vibration does not, check whether vibration is supported in Windows at all for this model and ask the manufacturer [#17653586]
  • #1 17652567
    Łukasz7689
    Rate: 15
    Hello, does anyone have a CD with drivers for Q-Smart Suzuka pro sw6060. Unfortunately, I bought it without the disc and I need these drivers.
    Adds a sample photo NOT MINE
  • #2 17652585
    sosarek
    Help: 9320
    Rate: 15529
    How do you know drivers are needed?
    Did you even connect her to the computer?
    Z
    Pka, Poznań, 60-850
  • #3 17652638
    Łukasz7689
    Rate: 15
    Yes, I connected and I play normally, but the vibrations do not work (Vibration motors are)
  • #4 17652641
    sosarek
    Help: 9320
    Rate: 15529
    No key to activate vibration?
    Vibrations turned on in the game settings?
    Z
    Pka, Poznań, 60-850
  • #5 17652647
    Łukasz7689
    Rate: 15
    There is only a mode key and some others, but not for vibration. I switched the steering wheels from analog to digital and vice versa. The game vibrates 100%
  • #6 17652669
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10454
    Enter system version and steering wheel ID from device manager (pid and vid).
  • #7 17652695
    Łukasz7689
    Rate: 15
    The wheel is discoverable as Gamepad Adapter
  • #10 17652772
    Łukasz7689
    Rate: 15
    I know this way, please give all 3
    Generic USB hub: USB \ VID_0C12 & PID_8801 & REV_0001
    HID compatible game controller: HID \ VID_0E8F & PID_0003 & REV_0109
    USB input device: USB \ VID_0E8F & PID_0003 & REV_0109
    Added after 13 [minutes]:
    Oh, and yet another version of the system
    System: Windows 7 Pro x64
    Added after 1 [hours] 24 [minutes]:
    Anyone have an idea to fix the vibration in this steering wheel
  • #11 17653586
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10454
    Ask the manufacturer if vibration works for Windows at all.
  • #12 17678450
    monteusz
    Hello, have you already solved the problem with the drivers because I also need it?
  • #13 17685068
    DriverMSG
    Help: 3984
    Rate: 4880
    Check operation with this driver.
    Speedlink ...Driver.rar (4.87 MB)You must be logged in to download this attachment.
  • #14 17714847
    Łukasz7689
    Rate: 15
    Well installs the driver, I'll give edit if it works
    Edit: The steering wheel has become detectable by pc after it stopped, unfortunately I have no way to check if the vibration is working because I did update the elevator but when I can write it
The discussion revolves around the need for drivers for the Q-Smart Suzuka Pro SW6060 steering wheel, which was purchased without a CD. The user reports that while the steering wheel is recognized by the PC, the vibration motors are not functioning. Various suggestions are made, including checking game settings for vibration activation, providing system and device identifiers, and contacting the manufacturer for support. The user later shares their system details (Windows 7 Pro x64) and asks for solutions to fix the vibration issue. Other participants suggest checking compatibility with Windows and provide links to potential drivers. The user confirms that a driver installation was attempted, but the vibration functionality remains untested.
TL;DR: 100% in‑game vibration yet no rumble: "The game vibrates 100%." This FAQ helps Q‑Smart Suzuka Pro SW6060 owners fix drivers and vibration on Windows. [Elektroda, Łukasz7689, post #17652647]
Why it matters: It speeds up troubleshooting when your SW6060 is detected but vibration won’t work.
Where can I download drivers for Q‑Smart Suzuka Pro SW6060?
A driver package was shared in this thread by user DriverMSG. Download the attachment from that post, install, and reboot. Then reconnect the wheel and test. Use Device Manager to verify that the controller appears without warnings. This is the only referenced driver in the discussion. [Elektroda, DriverMSG, post #17685068]
After installing the driver, will my PC detect the wheel?
Yes, one user reported that the steering wheel became detectable after installing the shared driver. They could not immediately verify vibration due to timing. Treat the package as a detection fix first. Test rumble in a game after confirming the device reappears cleanly in Device Manager. [Elektroda, Łukasz7689, post #17714847]
Why isn’t vibration working even though games support it?
First, ensure vibration is enabled in your game. Some units may not support Windows vibration at all. "Ask the manufacturer if vibration works for Windows at all." If the model lacks Windows rumble support, drivers will not add it. Contact Q‑Smart support to confirm your unit’s capabilities. [Elektroda, Kolobos, post #17653586]
Does the SW6060 work without drivers on Windows 7?
Yes. The wheel connected and played normally on Windows 7 Pro x64 without extra drivers. Only vibrations did not function. That indicates HID gamepad compatibility for steering and buttons. Install drivers only if you need rumble or additional features. [Elektroda, Łukasz7689, post #17652638]
How do I find and share the wheel’s VID/PID?
Open Device Manager, right‑click the device, and view Properties > Details > Hardware IDs. Copy the VID and PID values. The thread’s example shows VID_0E8F&PID_0003 and VID_0C12&PID_8801. Share these IDs and your OS version when seeking help. [Elektroda, Łukasz7689, post #17652772]
How does the SW6060 appear in Device Manager?
Expect entries like “Gamepad Adapter,” a HID‑compliant game controller, and a USB input device. That pattern reflects a composite USB device with controller and hub functions. The provided screenshot labels it as “Gamepad Adapter.” [Elektroda, Łukasz7689, post #17652695]
Is there a physical vibration toggle on the SW6060?
The reported unit had a Mode button and others, but no dedicated vibration key. Switching between analog and digital modes did not restore rumble. That suggests no physical rumble toggle exists on that sample. [Elektroda, Łukasz7689, post #17652647]
Which Windows version was confirmed in the thread?
Windows 7 Professional x64. If you use Windows 10 or 11, behavior may change. Always include your Windows edition and architecture when requesting support. [Elektroda, Łukasz7689, post #17652772]
The wheel shows as multiple devices; is that normal?
Yes. Three identifiers were listed: a Generic USB Hub plus HID game controller entries. This composite enumeration is normal for many budget USB wheels. It does not indicate a fault by itself. [Elektroda, Łukasz7689, post #17652772]
What should I provide when contacting Q‑Smart support?
Provide your Windows version and the device hardware IDs (VID and PID). Include a brief issue description and any screenshots. This information was specifically requested during troubleshooting in the thread. [Elektroda, Kolobos, post #17652669]
Quick steps to check rumble is enabled
  1. In your game, enable vibration/rumble in the settings.
  2. Check for any wheel Mode key and toggle it once.
  3. Test in‑game again after changes. [Elektroda, sosarek, post #17652641]
Where is the official product page for SW6060 support?
Use the manufacturer’s page for Q‑Smart SW6060 Suzuka to request drivers or vibration details. Reference your OS and hardware IDs when contacting them. [Elektroda, Kolobos, post #17652741]
