[Solved] Logitech G920 Steering Wheel Not Detected in ETS2 Game: Troubleshooting & Help Needed!
dino_66 58959 8
  • #1 18403519
    dino_66
    Rate: 19
    Good evening everyone.
    I would like to ask you for help in solving the problem, I kicked Logitech g920 steering wheels, unfortunately it does not work.
    When I connect it to the computer, the steering wheel rotates left and right and looks as if it has calibrated, in the device manager, the system sees it as an Xbox controller, while when I start the Ets 2 game, unfortunately the game does not see the steering wheel, there is no option to select the steering wheel. I tried all the available USB inputs I have in the computer, but with the same effect, I will add the LED on the steering wheel is on. I also installed Logitech profiler but unfortunately it cannot be started because most likely the program does not see the steering wheel either.
    I have Win 10 64 bit
    16GB RAM memory
    I wrote to Logitech's technical support, but it is not known when they will reply, so I am asking you a huge request, maybe you had a similar problem and someone could help me for which I thank you in advance.
  • #2 18403803
    wesmar
    Help: 40
    Rate: 199
    "Steam Controller" function - change the settings for the default controllers:
    - Enter Big Picture Mode on Steam.
    - Library, find ETS2.
    - Click "Manage Game" on the left side.
    - Click "Controller Options".
    - Set "Use Steam configuration for non-Steam controllers" - "Global settings (none)".
  • #3 18403871
    dino_66
    Rate: 19
    Unfortunately, I only get to the library with the game, but I don't know where to choose the controller options on the right
  • #4 18403912
    wesmar
    Help: 40
    Rate: 199
    You will find it easy.
  • #6 18403936
    wesmar
    Help: 40
    Rate: 199
    you paste ctrl + v into the gray frame, previously the button "add image"
    PS - I'm going to sleep, maybe I'll help tomorrow
  • #7 18403943
    dino_66
    Rate: 19
    Hello, I would like to return to the topic with the steering wheel, so I sent back that steering wheel and in return I was sent a different one, I am writing as if the problem with this new steering wheel is identical to the previous one, Could any of you, dear forum members, tell me what is it wrong? I have no ideas what to do next, I wrote again today to this website with the steering wheel not working and I will wait for a reply, but in the meantime someone of you may think of where the problem is.
    Logitech G920 Steering Wheel Not Detected in ETS2 Game: Troubleshooting & Help Needed! Logitech G920 Steering Wheel Not Detected in ETS2 Game: Troubleshooting & Help Needed! Logitech G920 Steering Wheel Not Detected in ETS2 Game: Troubleshooting & Help Needed!
  • Mundrunner may not support Ferrari 458 wheel
    #8 19272058
    plan2020
    I have the same problem with the steering wheel, only the mundrunner does not detect the steering wheel, only the pad and the keyboard, while ETS and ATS everything works great. I tried to apply all the changes and improvements read on the forum and from friends, unfortunately nothing. The problem occurred after changing the steering wheel, I currently have a Ferrari 458 Italia. Maybe the Mundrunner is not adapted to this steering wheel, has anyone had a similar case or is there any other reason because I don't know what to do next. Thanks greetings .
  • #9 19423521
    dino_66
    Rate: 19
    Steering wheel sold
The discussion revolves around troubleshooting issues with the Logitech G920 steering wheel, which is not detected by the Euro Truck Simulator 2 (ETS2) game despite being recognized by the computer as an Xbox controller. Users suggest adjusting Steam controller settings by entering Big Picture Mode, navigating to the game library, and modifying controller options to use global settings. The original poster expresses difficulty in finding these options and later mentions receiving a replacement steering wheel, which exhibits the same detection problem. Another user shares a similar issue with a different steering wheel model, indicating potential compatibility concerns with specific games.
