[Solved] evobox lite decoder update error 0xa6 then crashes anyway over and over again.
Genek 8 30933 6
  • #1 17655684
    Genek 8
    Rate: 23
    Hello, I have a problem with the evobox lite decoder, namely the decoder updates every time I turn it off and it takes more than 10 minutes, then it starts downloading and after a while the error 0xa6 is displayed, then it turns off and so on over and over again.
    Interestingly, it already has the latest soft.
    This is the third decoder.
    Antenna 80 assembled by a professional converter from the polsat antenna.
    MER at the level of 13.5 - 14 signal strength around 80 quality 75
    I wanted to ask if anyone else had a similar problem because they did not help much on the hotline, thank you in advance
  • #2 17658899
    netTv
    Level 32  
    Help: 193
    Rate: 579
    This is not normal behavior. What type of converter do you have set up in your antenna configuration?
  • #3 17659611
    Genek 8
    Rate: 23
    The converter is set to universal
  • Factory reset and reinstall without network connection
    #4 17660107
    netTv
    Level 32  
    Help: 193
    Rate: 579
    1. Disconnect the power.
    2. Disconnect the cable from the antenna.
    3. Connect the power of the decoder and wait for it to start up.
    4. Go to the Settings / Hardware Settings menu and restore the decoder to the default settings.
    5. After rebooting the decoder, the first installation screen will appear.
    6. Disconnect the power and reconnect the antenna cable.
    7. Reconnect power and perform First Time Installation. During the first installation, do not connect the set-top box to the network.
    8. Write down how it went.
  • #5 17660142
    Genek 8
    Rate: 23
    So far I have a new one that cannot be activated, I suspect that it has something wrong with the card because there is a different number on the screen than on the bottom of the decoder
  • Activation requires internet and channel 1 or 23
    #6 17660233
    netTv
    Level 32  
    Help: 193
    Rate: 579
    If possible, connect the set-top box to the Internet, then the activation will be faster.
    The customer number displayed on the message screen is for technical purposes.
    The most important information for you is in the menu Settings / Diagnostics / Conditional access.
    The card inserted into the decoder is not currently being used, so do not take it out and do not be influenced by its data.
    To activate the decoder, turn it on and leave it on channel 1 or 23.
  • #7 17696945
    Genek 8
    Rate: 23
    but the converter was nuts
The user is experiencing a recurring update error (0xa6) with their Evobox Lite decoder, which fails to complete updates and crashes repeatedly. Despite having the latest software, the decoder takes over 10 minutes to update each time it is powered on. The user has already replaced the decoder three times and is using a professional-grade 80 cm Polsat antenna with a universal converter, achieving a signal strength of 80 and quality of 75. Responses suggest checking the antenna configuration, restoring the decoder to default settings, and ensuring proper activation by connecting to the internet. There are concerns about the compatibility of the card used with the decoder, as the displayed customer number differs from the one on the device.
