Why Should an Ammeter Be Connected in Series and Not Parallel?
Maffel 18123 9
Why must an ammeter be connected in series instead of parallel, and what is the principle behind that connection?
An ammeter must be connected in series because it is designed to measure the current flowing through a load, and its internal resistance is very low, close to 0 Ω, so putting it in parallel effectively creates a short circuit that can burn out the meter or the connected wires [#17664974] The meter works by measuring the small voltage drop across a shunt resistor with minimal resistance [#17664968] That is why it has to be placed in the same current path as the receiver, like a flow meter inserted in a pipe [#17665606]
  • #1 17664909
    Maffel
    I have a question about connecting an ammeter. Why should you connect in series in a circuit?
    What I mean here is the principle of operation, I know that if we connect it in parallel it will burn, but why?
  • #2 17664968
    Ricoh_220
    Help: 464
    Rate: 754
    The matter is simple, you measure the voltage drop on the shunt (a resistor with minimum resistance), there is a potential difference indicated by the meter. Search https://pl.farnell.com/ohms-law-calculator?CMP=KNC-GPL-GEN-KWL&mckv=_dc |pcrid|241172065677|&gclid=CjwKCAiA9qHhBRB2EiwA7poaeOEXxg3PMgdz7vC48lU1hV8bc7oSHbHH-Tja_a0B_1yKWBgbzNrhkBoC-WwQAvD_BwE
    I refer you to the literature, e.g. practical electronics. If you have any questions, write me a PM, there`s no point in fooling around.
    Zakład techniki biurowej"Kserograf" .Serwis kserokopiarek i urzdzeń marki ricoh
    Bronowicka 73, Kraków, 30-091 | Tel.: 603XXXXXX (Show) | Company Website: https://kserograf.e.pl
    diantus
    Level 32  
    Help: 203
    Rate: 277
    An ammeter is used to measure the current consumed by any current receiver - a light bulb, a motor, a radio, etc., so it is connected in series with this receiver. In order for the error of this measurement to be as small as possible, its internal resistance must be as low as possible - close to zero Ω.
    Connecting such a low resistance in parallel to the voltage source causes a short circuit and burns out the ammeter itself or the wires connected to it.
  • #5 17664990
    mieszaczwcz
    Help: 185
    Rate: 258
    The ammeter has an internal resistance ranging from several mΩ to Ω, so you can make parallel measurements, because it is actually mV, and you want to measure the current flowing through a given element. Therefore, the lower the internal resistance. the ammeter is better, unlike V measurements - the higher the internal resistance, the better because it does not burden the source
  • #7 17665027
    mieszaczwcz
    Help: 185
    Rate: 258
    RICOH... for the author, your translation is a sentence which is written too much, but for the author it may be difficult to understand, judging by the level of the advanced question, a shunt is... what is it, comes with little knowledge and basically you have to answer the question from His level. The young man wants to educate himself!
    Added after 7 [minutes]:
    regarding #5 (delay, we wrote it together It wasn`t for you) I didn`t explain it to YOU because as I understand it. You`re HAPPY but you somehow treat people in advance.
  • #8 17665446
    Maffel
    Okay, so if we connect a diode and an ammeter in this way, why won`t it burn out?
  • #10 17665606
    retrofood
    Help: 1140
    Rate: 4798
    And if you have a hose with water, how will you connect a water meter to measure the volume of water flowing? The same applies to the dispenser counter at a gas station. Between the pump and the hose.
    Therefore, the ammeter must be placed along the power supply - receiver route. You don`t see any analogy with the so-called life?
An ammeter must be connected in series within a circuit to accurately measure the current flowing through a load, such as a light bulb or motor. This is due to its design, which features low internal resistance to minimize measurement error. If connected in parallel, the ammeter would create a short circuit, potentially leading to damage or destruction of the device and connected components. The discussion also touches on the importance of using a shunt resistor for current measurement and the necessity of additional components, like resistors or diodes, to prevent damage in specific configurations.
