Ammeter in Series & Voltmeter in Parallel Connection: Understanding the Science
COOLig17 31911 4
  • #1 1997159
    COOLig17
    Hello everyone
    I'm new and I have a fairly simple question that I can't find the answer to :cry: Why is the ammeter connected in series and the voltmeter in parallel? Please help me quickly. Thank you in advance.
    karol3
    Help: 86
    Rate: 261
    Hello .
    The case is as follows. We connect the voltmeter in parallel, because it has a very high internal resistance. Connected in series, it causes such a large voltage drop that devices connected after it would receive a voltage equal to or close to 0V and its operation would be impossible. The ammeter has a very low internal resistance and is connected in series in the circuit. The voltage drop across it is minimal and connected in parallel to a circuit will cause a short circuit in that circuit. It can't be explained any simpler.
    Regards
  • #3 1997228
    smaug
    In simple terms (more or less): an ammeter is a voltmeter that measures the voltage drop across a built-in resistor and calculates the current using Ohm's law. And that's why it must be connected in series (because the current must flow through the resistor). A voltmeter measures the voltage drop between two points, so it must be connected in parallel.
  • #4 1997231
    szymon188
    Help: 50
    Rate: 39
    An ammeter measures the current flowing through a given section of a circuit, and a voltmeter measures the voltage, i.e. the difference in potential between two points in the circuit.
  • #5 1997241
    COOLig17
    Thank you very much for the detailed answer and best regards. You helped me a lot :)
