[Solved] How to Fix a Self-Opening Door: Adjusting Hinges, Leveling & Tips for Apartment Doors
m4xon 27021 8
  • #1 17694068
    m4xon
    Rate: 74
    Hi, I need help with the following issue. Namely, one of the doors in my apartment started to open automatically when they are slightly ajar. How can I "fix" them, I read that the hinges are adjustable, but I don't really know how to go about it, which one to adjust or level something, etc. I will be grateful for any advice.
  • #3 17694417
    Wawrzyniec
    Help: 392
    Rate: 1075
    jaszto wrote:
    Turning the closing cam should raise and lower the door.
    And what does it give? Nothing. Height adjustment does nothing. You have to remove the door and either unscrew the lower hinge by 1 turn (the one in the door frame), or screw the upper one in. Do not move the part of the hinge that is located on the door
  • #4 17694476
    zimny8
    Help: 26
    Rate: 503
    Weigh the doorframe with a waser weight, because if it's installed incorrectly (from the vertical), you won't be able to do much.
    Could also be an overflow.
  • #5 17694772
  • #6 17697598
    m4xon
    Rate: 74
    So I understand that I have to spin and watch :D
  • #8 17699056
    retrofood
    Help: 1140
    Rate: 4797
    This is where you should start. That is, from establishing the facts and determining what disease occurs. At the frame and door leaf. Only then does treatment begin.
  • #9 17708052
    m4xon
    Rate: 74
    as my friend Jaszto recommended, I lowered the hinged wing lower. Greater friction inhibited the self-opening process.
To address the issue of a self-opening door in an apartment, users should first assess the door's hinges and frame alignment. Adjusting the hinges is crucial; specifically, the lower hinge may need to be unscrewed or the upper hinge tightened to correct the door's position. Observing the gap between the top and bottom of the hinge while opening and closing the door can help identify the problem. If the door frame is not vertical, it may require additional adjustments. Increasing friction by lowering the hinged wing can also inhibit the self-opening behavior. Careful observation and methodical adjustments are key to resolving the issue.
