[Solved] Lenovo T420 ThinkPad Drivers Needed for Windows 7 64bit - Not Found on Lenovo Site
kisiol 27057 12
How can I find and install the missing Windows 7 64-bit drivers for a Lenovo ThinkPad T420 by hardware ID when Lenovo’s site is not obvious to use?
The ThinkPad T420 does have Windows 7 64-bit drivers; for the listed PCI/ACPI IDs you need to download the correct Lenovo/Intel packages, unpack them, and install them from Device Manager if the EXE does not install automatically [#17748371][#17748367] Matched drivers were: DEV_1502 -> 83rw20ww_64.exe, DEV_1C22 -> Intel chipset 10.1.17 zip, DEV_1C3A/DEV_1C3D -> 83ra31ww.exe, DEV_0085 -> 8aw217ww.exe or Intel WiFi_Win7_64_19.70.0.exe, DEV_E823 -> 8ass82ww.exe, and ACPI\LEN0068 -> n1zku17w_x64.exe [#17748371][#17748448] The main Lenovo T420 driver page also contains the needed packages, but they may need to be downloaded and unpacked before installation [#17748354][#17748367] If graphics is still weak, install the Intel graphics package win64_152824.exe [#17748448] If touchpad gestures or hotkeys are missing, install Ultranav 6hgx81ww.exe and Hotkeys 8jvu43ww.exe [#17748479]
  • #1 17748298
    kisiol
    Help: 36
    Rate: 469
    Hello. I am looking for drivers for the lenovo t420 thinkpad, from the lenovo site they do not approach. Windows 7 64bit. Please help.
    PCI \ VEN_8086 & DEV_1502 & SUBSYS_21CE17AA & REV_04
    PCI \ VEN_8086 & DEV_1C22 & SUBSYS_21CE17AA & REV_04
    PCI \ VEN_8086 & DEV_1C3A & SUBSYS_21CE17AA & REV_04
    PCI \ VEN_8086 & DEV_0085 & SUBSYS_13118086 & REV_34
    ACPI \ LEN0068
    PCI \ VEN_1180 & DEV_E823 & SUBSYS_21CE17AA & REV_05
    PCI \ VEN_8086 & DEV_1C3D & SUBSYS_21CE17AA & REV_04
  • #3 17748336
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8291
    Hello. What does "don't approach" mean? Recently, I installed the whole set for the T420, there were no problems.
  • #4 17748350
    kisiol
    Help: 36
    Rate: 469
    The drivers downloaded from the Lenovo website, the installation goes and the computer does not see the drivers.
  • #6 17748355
    kisiol
    Help: 36
    Rate: 469
    Kolobos, hint how to download it, because they are some cab files.
  • #7 17748367
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Download, unpack, install from the device manager. You probably need to do the same with those from Lenovo, not just run and unpack.
    dt1
    Help: 7315
    Rate: 8291
    https://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/83ra31ww.exe
    https://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/8ass82ww.exe
    kisiol wrote:
    ACPI \ LEN0068
    https://download.lenovo.com/pccbbs/mobiles/n1au414w.exe
    https://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/8aw217ww.exe
    alternatively:
    https://downloadmirror.intel.com/27239/a08/WiFi_Win7_64_19.70.0.exe
    https://downloadmirror.intel.com/28182/eng/chipset-10.1.17.zip
    https://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/83rw20ww_64.exe
    It used to be that they only unpacked themselves, but now they download as EXEs by default, unpack themselves, and have the option checked by default to install them.
  • #9 17748418
    kisiol
    Help: 36
    Rate: 469
    Almost everything was installed, just this
    ACPI \ LEN0068
    Yet the graphics drivers are somehow weak.
    dt1
    Help: 7315
    Rate: 8291
    Most of the drivers I listed were from the T420 driver site - I replaced only a few with others, but only due to the availability of newer versions elsewhere.
    ACPI \ LEN0068 check https://download.lenovo.com/pccbbs/mobiles/n1zku17w_x64.exe.
    As for graphics, check out https://downloadmirror.intel.com/24971/a08/win64_152824.exe
  • #11 17748467
    kisiol
    Help: 36
    Rate: 469
    Thank you so much for help. I struggled with it half a day and a night.
  • #12 17748479
    dt1
    Help: 7315
    Rate: 8291
    In fact, of the things that are not showing as not installed, you may still need a touchpad driver (finger scrolling and shortcuts), or some hotkey software:
    Ultranav: https://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/6hgx81ww.exe
    Hotkeys: https://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/8jvu43ww.exe
    Apart from the previously mentioned, probably all the relevant drivers for this model would be there.
  • #13 17748487
    kisiol
    Help: 36
    Rate: 469
    Thanks again a lot.
The discussion revolves around the difficulty of finding and installing drivers for the Lenovo T420 ThinkPad on Windows 7 64-bit. The original poster reports issues with drivers from the Lenovo website not being recognized after installation. Various users provide solutions, including links to specific driver downloads, instructions for unpacking and installing drivers via Device Manager, and suggestions for additional drivers such as touchpad and hotkey software. The community shares direct links to necessary drivers, including those for ACPI and graphics, and emphasizes the importance of ensuring all relevant drivers are installed for optimal functionality.
TL;DR: 6 device IDs mapped to drivers; "They download as EXEs by default." Fix T420 Win7 x64 by installing the Lenovo/Intel packages below. For graphics and ACPI LEN0068, use the specific links provided. [Elektroda, dt1, post #17748371]
Why it matters: Clear steps for Windows 7 x64 ThinkPad T420 owners whose Lenovo downloads don’t install or don’t appear to work.
Which Lenovo T420 drivers match these PCI IDs on Windows 7 64‑bit?
Install 83ra31ww.exe for DEV_1C3D and DEV_1C3A. Use 8ass82ww.exe for VEN_1180 DEV_E823. Use n1au414w.exe for ACPI LEN0068. Install 8aw217ww.exe or Intel 19.70.0 for VEN_8086 DEV_0085. Use chipset 10.1.17 for DEV_1C22. Install 83rw20ww_64.exe for VEN_8086 DEV_1502. [Elektroda, dt1, post #17748371]
Should I check Windows Update after installing the LAN driver?
Yes. “After installing, check on WU if there are others.” If Windows Update finds nothing, search the exact PCI ID in Google and download a matching package. This approach quickly resolves the remaining devices once networking works. [Elektroda, Kolobos, post #17748334]
How do I install a .cab driver from Microsoft Update Catalog?
“Download, unpack, install from the device manager.”
  1. Download the .cab and extract it to a folder.
  2. Open Device Manager > right‑click the device > Update driver.
  3. Choose Browse my computer and point to the extracted folder. This installs unsigned .cab contents cleanly. [Elektroda, Kolobos, post #17748367]
Why do Lenovo installers run but drivers still don’t show up?
Recent Lenovo packages download as EXEs that unpack and auto‑install. Ensure the installer completes and the install option remains checked. Older packages only unpacked, so nothing changed until you installed manually. Re‑run the current EXE build to trigger installation. [Elektroda, dt1, post #17748371]
What driver fixes ACPI LEN0068 on a T420?
Install Lenovo’s n1zku17w_x64.exe to resolve the ACPI LEN0068 device. This package targets the power management interface that shows as an unknown device. Reboot after installation to finalize. [Elektroda, dt1, post #17748448]
Which driver do I need for Intel LAN controller VEN_8086 DEV_1502?
Use Lenovo’s 83rw20ww_64.exe package. It matches the 8086:1502 adapter used in the T420 and installs cleanly on Windows 7 x64. If needed, install via Device Manager after running the EXE. [Elektroda, dt1, post #17748371]
What package covers Intel system devices DEV_1C3D and DEV_1C3A?
Install Lenovo package 83ra31ww.exe. It handles the Intel system interface devices flagged by those hardware IDs on the T420. Reboot once completed to clear the warnings. [Elektroda, dt1, post #17748371]
Where do I get the Ricoh card reader driver (VEN_1180 DEV_E823)?
Use Lenovo package 8ass82ww.exe for the Ricoh reader. This driver restores SD card functionality and removes the unknown device flag in Device Manager. [Elektroda, dt1, post #17748371]
Wi‑Fi (VEN_8086 DEV_0085) not working—what should I install?
Install Lenovo’s 8aw217ww.exe, or use Intel’s WiFi_Win7_64_19.70.0.exe. Both target the 8086:0085 adapter. Reboot and reconnect to confirm wireless functionality. [Elektroda, dt1, post #17748371]
Intel HD Graphics feels slow—how do I fix it on Windows 7 x64?
Install Intel graphics driver win64_152824.exe. It’s the recommended package for the T420’s integrated graphics under Windows 7 x64. Update, reboot, and verify acceleration is enabled. [Elektroda, dt1, post #17748448]
Where can I download all T420 drivers in one place?
Use Lenovo’s official ThinkPad T420 driver page. Choose Windows 7 64‑bit, then download listed packages. This centralizes chipset, LAN, Wi‑Fi, and system utilities. [Elektroda, Pedros050, post #17748354]
What unknown device IDs are typical after a fresh Windows 7 install?
One user reported seven unknown devices: 8086:1502, 8086:1C22, 8086:1C3A, 8086:0085, ACPI\LEN0068, 1180:E823, and 8086:1C3D. Use these IDs to match exact drivers. This speeds resolution and avoids mismatched packages. [Elektroda, kisiol, post #17748298]
How do I enable touchpad gestures and ThinkPad hotkeys?
Install UltraNav 6hgx81ww.exe for touchpad features and scrolling. Then install Hotkeys 8jvu43ww.exe for on‑screen display and Fn‑key functions. Reboot between installs for reliability. [Elektroda, dt1, post #17748479]
If Lenovo’s driver “doesn’t approach,” what should I do next?
Match your PCI ID to the specific package and install that driver. The mapped links cover LAN, Wi‑Fi, chipset, card reader, and ACPI devices. Lenovo EXEs unpack and auto‑install when run. [Elektroda, dt1, post #17748371]
