IBM T41 Driver Installation: Manual .inf File for Audio, Video, Ethernet, Network & PCI Modem
Damien. 5634 16
How do I manually install the missing ThinkPad T41 drivers on Windows XP SP3 when Device Manager asks for INF files?
Install the ThinkPad T41 drivers from the proper Lenovo package, and do the chipset driver first; if devices are still missing, reinstall the chipset and then the other drivers [#16278869] [#16279088] If the downloads are EXE installers, extract them with 7-Zip and then install from Device Manager by pointing to the unpacked driver folder, or use automatic install against that folder instead of trying to pick random INF files by hand [#16279111] [#16279586] For the hardware IDs you listed, the thread points to the ADI audio driver for PCI\VEN_8086&DEV_24C5, Intel PRO1000 for VEN_8086&DEV_101E, and the AMD legacy graphics driver for VEN_1002&DEV_4C57 [#16279111] One reply notes that the extracted drivers are typically under C:\DRIVERS [#16283548]
  • #1 16277861
    Damien.
    After installing the drivers from the
    ".exe" yellow question marks appeared in the device manager.
    For manual installation, the ".inf" file is required.
    Is it the "$ winnt $ .inf" which I have in system32?
    The hardware is IBM T41, screen is here Windows XP SP3
    below are the hardware identifiers.
    Multimedia Audio Controller:
    PCI \ VEN_8086 & DEV_24C5 & SUBSYS_05371014 & REV_01
    Video controller:
    PCI \ VEN_1002 & DEV_4C57 & SUBSYS_05301014 & REV_00
    The screenshot shows the problem with the following, but I don't think they are
    urgently needed, so I did not write about them:
    Ethernet controller:
    PCI \ VEN_8086 & DEV_101E & SUBSYS_05491014 & REV_03
    Network controller:
    PCI \ VEN_8086 & DEV_1043 & SUBSYS_25518086 & REV_04
    PCI modem:
    PCI \ VEN_8086 & DEV_24C6 & SUBSYS_05241014 & REV_01
    Unknown device:
    ACPI \ IBM0068
  • #2 16277887
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    Enter the version of the system and identifiers of the devices for which drivers are missing.
    Also, write what is this exe file and are you sure you installed something, not just unpacked on the disk?
  • #3 16277888
    Kasek21
    Help: 4981
    Rate: 3548
    Post screen from Device Manager.
  • #4 16278101
    Damien.
    It is about this audio driver i this for graphics on Windows XP SP3.
    How do I install them manually?
  • #5 16278124
    Kasek21
    Help: 4981
    Rate: 3548
    What is this computer?
    Where's the screen?
    Where are the IDs?
  • #6 16278161
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    I guess some Lenovo.
    The listed installers should install drivers and applications.
    It is possible that the devices visible in the manager are not audio and graphics but something else, so you MUST provide the model of this lenovo and device IDs from the manager (ven and dev or pid and vid - just not screenshots!).
  • #7 16278813
    Damien.
    I gave in first post .
    As if I had marked "yes" in options here would it work for audio?
    I did not select anything in the "Have disk ..." option. "Intel" and "Intel (r) AC'97 Audio Controller" only.
  • #9 16279068
    Damien.
    I had all the necessary drivers saved in advance
    and installed them in the order in this list. Controller
    the chipset was last, so the last one installed.
    Is it possible that these drivers are not working and how
    fix it?
  • #10 16279088
    Kasek21
    Help: 4981
    Rate: 3548
    Reinstall the chipset driver, then other device drivers.
  • #11 16279111
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    For PCI \ VEN_8086 & DEV_24C5 install: http://drivers.drp.su/Sound_ADI/ADI/5x86/Lenovo_6/new/ADI-5x86-Lenovo_6-new-drp.exe
    Download, unpack the exe file with 7-zip and install from the device manager by selecting driver updates.
    VEN_8086 & DEV_101E: http://drivers.drp.su/LAN_Intel/Intel/FORCED/5x86/PRO1000/Intel-FORCED-5x86-PRO1000-drp.exe
    VEN_1002 & DEV_4C57: http://drivers.drp.su/Videos_AMD-XP/AMD/FORCE...5x86/10.4/AMD-FORCED-Legacy-5x86-10.4-drp.exe
  • #12 16279299
    Damien.
    I downloaded the first audio driver.
    I choose "Update Driver", I come to the hardware selection
    and check "Sound, video and game controllers" then
    I have options like here ("Intel" and "Intel (r) AC'97 Audio Controller"),
    I click "Have disk ..." and adding the unpacked whole thing doesn't work
    file ".exe", I'm looking for the file ".inf" and finds the following:
    SMWDMAT4.INF
    SMWDMCH4.INF
    SMWDMCH6.INF
    Which one to choose?
  • #13 16279539
    r103
    Level 37  
    Help: 283
    Rate: 968
    And not the easiest way to install the Lenovo System Update program - it should show you what you need to install ???
    Or just great - look for images of Recovery tiles for T41 published by a Thinkpad fan and install the system that the factory gave :-)
    Because someone who uses the T41 also does it for such not very commercial reasons ...
    There is a special forum http://www.forum.thinkpads.com/
    section in our Polish forum: http://www.nhl.pl/index.php?s=8c0a438f00e3ff116d60e2f8974752c7&showforum=63
    Oh, I'm also a thinkpadofilm, I have T42p, R50p, T60 / T60p, X60tablet, X200 tablet ... You have so much sickness for these 15 years and it's a pity to throw away because they are fully functional, housings and screens crush today's trash, but these interiors they are not doing very well anymore ...
  • #14 16279586
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    @Damien.. why do you choose the driver manually? Select automatic installation, pointing only to the directory with drivers.
  • #15 16281447
    Damien.
    I think so, but he didn't find everything with me.
    After selecting the drivers it suggested
    he downloaded and installed them himself. Is downloaded
    driver installation files somewhere with me
    wrote down Where can they be?
    Before using Lenovo System Update, this option was
    inactive but already running.
  • #16 16283548
    r103
    Level 37  
    Help: 283
    Rate: 968
    Where can they be:
    C: \ DRIVERS
  • #17 16283601
    Kasek21
    Help: 4981
    Rate: 3548
    All drivers should install from the so-called "slot machine". "
The discussion revolves around the installation of drivers for an IBM T41 laptop running Windows XP SP3, specifically addressing issues with missing drivers for audio, video, Ethernet, network, and PCI modem devices. The user initially attempted to install drivers using an executable file, resulting in yellow question marks in Device Manager. Participants suggested providing hardware identifiers and recommended using the Lenovo support site for driver downloads. Manual installation using .inf files was discussed, with specific links provided for downloading necessary drivers. The importance of installing the chipset driver first was emphasized, along with the suggestion to use Lenovo System Update for automatic driver installation. The user expressed difficulties in finding the correct .inf files and the location of downloaded driver installation files.
