Missing Lenovo ThinkPad T60 Drivers: Windows 7 32-bit, Ethernet Controller, ACPI, IBM0068/0071
Rogal18 6402 5
  • #1 16310962
    Rogal18
    Windows 7 32 Bits
    Ethernet controller
    PCI \ VEN_B73B & DEV_109A & SUBSYS_200117AA & REV_00
    PCI \ VEN_B73B & DEV_109A & CC_020000
    Unknown Device
    ACPI \ ATM1200
    * ATM1200
    Unknown Device
    ACPI \ IBM0068
    * IBM0068
    Unknown device
    ACPI \ IBM0071
    * IBM0071
  • #2 16310994
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Unpack the exe files with 7-zip and install the drivers from the device manager.
    ACPI \ ATM1200: http://drivers.drp.su/Touchpad_Others/Atmel/WinAll/Atmel-WinAll-drp.exe
    ACPI \ IBM0068: http://drivers.drp.su/Vendor/Lenovo/WinAll/Po...ovo-WinAll-PowerManagement-1.67.12.19-drp.exe
    ACPI \ IBM0071: http://drivers.drp.su/Misc/NSC/WinAll/NSC-WinAll-drp.exe
    There is no device with the identifier: VEN_B73B
    Intel has a similar card: PCI \ VEN_8086 & DEV_109A & SUBSYS_200117AA & REV_00
    Drivers for it: http://drivers.drp.su/LAN_Intel/Intel/FORCED/7x86/PRO1000/Intel-FORCED-7x86-PRO1000-drp.exe
    If your device actually has such an ID, change the inf file to match and check if it works.
  • #3 16311052
    Rogal18
    These unknown devices were super installed but there is a problem with this Ethernet controller. I don't want to install and I tried to rename it, it doesn't work (but it's possible that I didn't change this file or I did something wrong)
  • #4 16311132
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    You change in the file e1e6232.INF
    Search all lines:
    and change to:
    There are only two of them.
  • #6 16311159
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    @Gelip the network card has a damaged identifier (possibly hardware damaged), usually drivers won't even install without modification.
