Sonicare HX6511 toothbrush - Turns on by itself from time to time.
slaw777 33045 9
Why does a Philips Sonicare HX6511 toothbrush turn on by itself, and how can I fix it?
The most likely cause is the power button area, especially the center membrane or microswitch, which may be wet, contaminated, deformed, or shorting the contacts. One user with the same symptom found moisture/paste inside the button area, so it is worth checking for any unsealing or leakage [#19198774] Another reply recommends removing the upper button cover, taking out the membrane, and testing whether the brush still misbehaves, because a deformed or damp membrane can make the switch extremely sensitive [#19199169] Cleaning the switch/button area with alcohol may help if there is contamination and the membrane is not mechanically damaged [#19200074] If cleaning does not solve it, the switch itself should be checked for an internal short [#19200074]
  • #1 19198707
    slaw777
    Rate: 215
    Hello everyone. The Philips Sonicare HX6511 toothbrush has such an affliction that it turns on by itself, I don't know what the reason may be. I don't know if this is a problem with these brushes. I should add that the battery was replaced with a new one.
    Thanks in advance for any suggestions.
  • #2 19198774
    arson18
    Help: 28
    Rate: 65
    I had the same in the HX6100, I had a slight unsealing on the upper gasket
    the switch on the board was flooded with paste, I will add that the paste was already dried so it must have leaked for a long time
    did you change the battery yourself? There may have been some moisture
  • #3 19198895
    slaw777
    Rate: 215
    I changed the batteries myself. The switch was clean, no flooding inside, but I was wondering how it works so lightly. When it turns on by itself, just tap the brush housing and it turns off
    arson18
    Help: 28
    Rate: 65
    if it is so sensitive, I bet on the button, and more specifically the membrane in the middle. undress the button, remove the upper cover of the button (it is best to bend the clamps with a knife) remove this membrane and see if it goes crazy without it. Maybe it got wet inside or it deformed from use and practically shorted the contacts
  • #5 19200004
    slaw777
    Rate: 215
    I will not disassemble the switch, because it has to be done under a microscope. For now, it has not turned on today, when it turns on again, I will dismantle it myself and wash the switch with alcohol.
  • #6 19200074
    arson18
    Help: 28
    Rate: 65
    yes, the zoom might come in handy :) alcohol should help if the membrane is not mechanically deformed, if it doesn't help, better look and rule out a short circuit in it
    Good luck
  • #7 19219843
    slaw777
    Rate: 215
    So far, for several days the brush has not turned on by itself and I have not touched it. If the problem persists, I will try to desolder the switch and solder a new one.
  • #8 19522134
    slaw777
    Rate: 215
    One more flaw came out, namely, during work, as if the brush stopped for a fraction of a second and so often, during one tooth brushing, I don't know if it's not the fault of the tips?
  • Choosing a suitable microswitch for the toothbrush button
    #9 19522139
    slaw777
    Rate: 215
    I need to choose a microswitch for the brush, maybe one of you knows how to choose the right one, I measured it and want to choose a similar one, just a question, after turning on the switch must be turned on
    https://allegro.pl/oferta/micro-switch-mikroprzelacznik-4x4x1-5mm-smd-x5szt-8270229345
    I do not know if the one from the auction is bistable, because it is probably needed?
    Thanks in advance.
  • #10 20732416
    ZuzannaO
    >>19522134
    This is a timer - the cleaning process takes 2 minutes. You should hear a signal every 30 seconds that it's time to change the portion of your teeth being brushed.
The Philips Sonicare HX6511 toothbrush has been reported to turn on by itself intermittently, even after a battery replacement. Users suggest that the issue may stem from a sensitive button or a malfunctioning membrane switch, potentially caused by moisture or wear. One user noted that tapping the brush housing can turn it off when it activates unexpectedly. Recommendations include inspecting the button assembly for damage, cleaning the switch with alcohol, or replacing the microswitch if necessary. Additionally, some users mentioned experiencing brief pauses during operation, raising concerns about the brush tips. The device's timer feature, which signals every 30 seconds during a 2-minute cleaning cycle, was also discussed.
