19 Rack Cabinet for Home Server Room: Choosing between 9U and 12U, Equipment & Brands
1kamilkras 14832 13
How should I choose the size, construction features, and manufacturer of a 19-inch rack cabinet for a home installation containing network, TV, CCTV, and possibly server and UPS equipment?
Choose at least a 15U cabinet rather than 9U or 12U, leaving roughly 5–6U for ventilation, cable space, and future additions such as a NAS, UPS, or server [#17874166] [#17874183] [#17879564] Ensure the cabinet can be opened from the sides and has good ventilation, since access and fan noise become increasingly important as equipment ages [#17874167] Prioritize a rigid mounting frame and side support, because some inexpensive cabinets sag or have poorly aligned or unthreaded mounting nuts after loading [#17875052] [#17877412] Signal and ZPAS are regarded as solid choices, while LinkBasic is also considered good; ZPAS offers extensive accessories but costs more [#17875052] [#17879593] [#17879996] Lanberg can be adequate for a home or small office at a low price, but reported weaknesses include front deflection and a mounting frame that may be insufficiently stiff, so floor support or a stand may be needed [#17875131]
  • #1 17874130
    1kamilkras
    Level 4  
    I have a prepared place for a rack at home. Wires from rtv, mains and cctv sockets come there. Slowly, I would like to equip them with appropriate equipment
    Starting with the purchase of a 19 "rack, I would like to advise you what height and rack to buy, I range between 9U and 12U.
    I want to distribute rtv (11), network (14) sockets on the strip, and also cctv cables on the appropriate strip for convenience. In general, the cabinet will have a router and switch for the network, a multiswitch for TV, a cctvv recorder and that's probably all (if I haven't forgotten something, suggestions are also welcome). Hardware rather not in a rack version due to the lower price, except for power sockets.
    Do you recommend any specific manufacturers or it does not matter here and each wardrobe will be ok?
    What does Getfort 9U 600x450 think?
  • #2 17874166
  • #3 17874167
    adamjur1
    Help: 772
    Rate: 1003
    Buddy - not the manufacturer, it is important here, only the place in the wardrobe, access from the sides, ventilation.
    12U is not much - especially as the location will not allow you to approach from the sides.
    Very useful for CCTV recorders,
    If the ventilation noise is harmless, you can try to pack it into a smaller one, but remember that the fans get louder with age ...
    Greetings J.
    Buddy Erbit - I can see that we went to the same school of life in IT, and experience is measured there with torn hands and bruises on the forehead :D :D :D
    Greetings J.
  • #4 17874183
  • #5 17874736
    IC_Current
    Help: 1499
    Rate: 2523
    If you only have space, mount 15U or more.
    @Erbit
    I think that the first person to invent, patent and implement rubber switchgear for production will become the richest man in the world.
  • #6 17874837
    1kamilkras
    Level 4  
    I cannot imagine the sides not being opened, this is the basis for me.
    The wardrobe stuffed into a tight nook, which can only be accessed from the front, is a misunderstanding, not to mention ventilation ...
    When I asked about the manufacturer, I meant whether the performance of such an average cabinet is satisfactory, whether the profiles do not bend under their own weight, etc., but will withstand a moderate load of equipment and cables.
    I do not plan a VOIP switchboard, but a small server I forgot about it (thanks for the hint :D ) plus maybe small ups for the needs of the recorder (but as a last resort it can stand next to the wardrobe, because the wardrobe will be suspended relatively low above the floor)
    Szfa 48U in a single-family house - yes, it's definitely crazy for me! :wink:
    I guess I'll go with the 15U
    When browsing the well-known auction site, I am surprised that there is such a small selection .. mainly Getfort, Lanberg, these names do not tell me anything, but the price seems to be attractive compared to Pulsar and Signal wardrobes available in other online stores
  • #7 17875052
    IC_Current
    Help: 1499
    Rate: 2523
    The decent quality of wardrobes is Signal (I assemble myself) and this price shelf. Many wardrobes do not have a side support frame, which makes the wardrobe sagging. I have already seen wardrobes, where the front part was tied with a string so that the wardrobe would not fall off (junk from napad.pl).
  • #8 17875131
  • #9 17877329
    1kamilkras
    Level 4  
    The opinion of the falling down concerns the 600X600 cabinet, maybe the 600x450 cabinets are devoid of this defect (less depth): d but it's probably wishful thinking ... the support seems to be a solution
    Thanks to everyone for the answers provided. I will buy a minimum of 15U :)
    Regards
  • #10 17877412
    dawidedziu
    Industrial cameras specialist
    Help: 500
    Rate: 644
    Lanberg cabinets are quite shoddy, the worst thing about them is the twisting (crookedly mounted nuts, minimal differences in dimensions, no thread). They are not suitable for more things. LinkBasic, for example, is good.
  • #11 17879564
    markooff
    Help: 79
    Rate: 178
    Well, I used to have a similar cabinet for sale (used for disassembly, so at a good price), but I have already managed it (for ONT, patch cord guides and the PSP switchboard itself), so unfortunately I will not help. (BTW, how can you download an announcement from the classifieds forum?) With what you write here, my friend will surely find something comfortable, ergonomics is very important (access from as many pages as possible) plus ventilation and the height reserve in "U" units :) )
    As a rule, it is good to have not only 3 U of reserve, but even a little more (even if it turns out that one or more devices mounted one above the other - it heats up a lot and it is a good idea to raise those "who are above" by 1 U for better cooling ...
    So the clearance in the closet is a critical and reasonable condition at the same time :)
    I would - for the 12 U needed from the calculation - I would prefer to have 5-6 U in stock ...
    In addition, the contents of the wardrobe tends to expand over time :)
    Regards
  • #12 17879593
    adamjur1
    Help: 772
    Rate: 1003
    There is also a domestic producer of ZPAS - very solid welded cabinets, I've been installing them in banks for the last 30 years. One 42U 600x600 m was left (without the glass because it broke) and makes it a shelf in the garage - everything withstands, nothing bends and does not leave ...
    Greetings J.
  • #13 17879618
    markooff
    Help: 79
    Rate: 178
    After browsing the quick catalog - I have to say that I like this ZPAS. Nice and rich accessories for cabinets, racks, etc. There is a lot to choose from and you can see the concern for the overall shape and ergonomics of the solution :)
    It's nice that a colleague threw it.
  • #14 17879996
    IC_Current
    Help: 1499
    Rate: 2523
    I forgot all about them. I don't know how it is now, but three or four years ago were pretty neat.
    markooff wrote:
    I must say that I like this ZPAS.
    Decent wardrobes. One of the best. However, if you count all the necessary elements, you will get a lot of money. Like LinkBasic and Signal put together. :-)
The discussion revolves around selecting a suitable 19" rack cabinet for a home server room, with considerations between 9U and 12U sizes. Participants emphasize the importance of future expansion, ventilation, and accessibility from the sides. Recommendations lean towards a minimum of 15U to accommodate additional devices like a small server and UPS. Various brands are mentioned, including Getfort, Lanberg, Signal, LinkBasic, and ZPAS, with mixed reviews on their quality. Users advise ensuring the cabinet can support the weight of equipment and cables without sagging, and highlight the need for good ventilation to prevent overheating.
TL;DR: For a home 19" rack, plan 5–6U spare capacity; "the clearance in the closet is a critical and reasonable condition." Pick 15U+ if space allows, ensure ventilation and service access, and choose sturdy frames. [Elektroda, markooff, post #17879564]
Why it matters: Homeowners building a compact server/AV room can avoid noise, heat, and upgrade pain by sizing and outfitting the rack correctly.
What’s the right size for a home rack: 9U, 12U, or 15U+?
Choose 15U or more if you have space. 12U fills up fast once patching, power, and future devices appear. Also ensure the cabinet opens from the sides for service. As one pro put it, "This is not a joke, this is an experience." [Elektroda, Anonymous, post #17874166]
How much spare U should I leave, and why?
Leave 5–6U free beyond your current calculation. Add about 1U clearance above hotter devices to improve airflow. This gives room for a NAS, UPS, or added patching later. The author stresses that clearance is critical for cooling and future expansion. [Elektroda, markooff, post #17879564]
Do I really need side access in a wall cabinet?
Yes. Prioritize side access and ventilation over brand. Without side access, installing and servicing cables and DVRs is painful. Noise can rise if you overstuff a small chassis. The key is "access from the sides" and good airflow. [Elektroda, adamjur1, post #17874167]
Is Signal a safe brand to buy?
Yes, Signal cabinets are described as decent quality. Watch for designs lacking side support frames, which can sag under load. One installer even saw a cheap unit tied with string to keep the front from dropping. Choose robust frames to avoid that failure mode. [Elektroda, IC_Current, post #17875052]
Are Lanberg wall cabinets okay for home use?
They are budget-friendly and adequate for light gear, but inspect the frame. A shared user review noted "Significant lowering of the front after loading" and that the frame "could be stiffer." Consider supporting the cabinet or using feet to reduce droop. [Elektroda, Anonymous, post #17875131]
Is LinkBasic a good alternative at this price point?
Yes. Users call LinkBasic good, while flagging Lanberg for build issues. Reported problems include twisting, crooked nuts, small dimensional variances, and missing threads. These issues slow installation and can misalign rails. [Elektroda, dawidedziu, post #17877412]
What premium options should I consider if I want very solid build?
ZPAS welded cabinets are very solid and have seen bank deployments for decades. They resist bending and feel overbuilt, though they cost more. They are a strong choice if you value rigidity and longevity. [Elektroda, adamjur1, post #17879593]
600x450 vs 600x600 depth — which is safer to wall-mount?
Some reports of front lowering concern 600x600 depth when wall-mounted and loaded. If you choose deeper models, add support or place on a stand or feet. This helps prevent the front from dropping under weight. [Elektroda, Anonymous, post #17875131]
How noisy will it get, and how can I manage it?
Fans get louder with age, and cramped cabinets trap heat. If noise is acceptable, a smaller cabinet can work with active cooling. Otherwise, choose a larger chassis and plan airflow paths. Remember, “fans get louder with age.” [Elektroda, adamjur1, post #17874167]
Can I keep a small UPS outside the rack?
Yes. If the wall cabinet is mounted low or space is tight, park a small UPS next to it. That frees U-space for patching and active gear. [Elektroda, 1kamilkras, post #17874837]
Is a 48U rack overkill in a house?
For most homes, yes. One user called a 48U wardrobe "definitely crazy for me!" Go 15U–18U if you can, and leave headroom. [Elektroda, 1kamilkras, post #17874837]
What devices can I combine in one home rack?
A typical home setup includes router, switch, multiswitch for TV, and a CCTV recorder. You might add a small server and a UPS. The OP planned 11 RTV and 14 network sockets terminated on strips, plus CCTV. [Elektroda, 1kamilkras, post #17874130]
What pitfalls should I watch for with cheaper racks?
Beware of poor machining and tolerances. Issues reported include twisting frames, crooked nuts, small dimensional differences, and missing threads. These defects complicate assembly and mounting rails or accessories. [Elektroda, dawidedziu, post #17877412]
How do I choose the right rack height?
  1. List all gear and patching you’ll mount, then total required U.
  2. Add 5–6U for expansion, plus about 1U gaps above hot devices.
  3. Confirm the space allows that height and provides clearance to manage cables. [Elektroda, markooff, post #17879564]
Wall-mount or floor-mount: what reduces front droop?
If the cabinet hangs low, consider placing it on the floor or on feet. Added support reduces the chance of the front lowering under load. This helps lighter frames bear weight safely. [Elektroda, Anonymous, post #17875131]
Does brand matter less than layout and ventilation?
Yes. Prioritize space, side access, and airflow before the logo. The advice is clear: not the manufacturer, but place, access, and ventilation decide success. [Elektroda, adamjur1, post #17874167]
