[Solved] Configuration Guide: TP-Link Archer C6 Router as Access Point - Step by Step Instructions
Vester11 12489 2
  • #1 17977552
    Vester11
    Rate: 49
    Hello, how to configure the tp link archer c6 router to work as acces point?
    Set access point IP outside main router DHCP range
    #2 17977608
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Hello. More or less like this: https://www.tp-link.com/pl/support/faq/417/
    Log in to your main router and check what range its DHCP server assigns addresses from. Set the address of the second router (192.168.2.11 in the example, this will be your Archer C6) so that the first three octets of it are the same as the IP address of your main router, and the last number is apart from the range of addresses assigned by the DHCP server of your main router.
    Example - if your router is 192.168.0.1 and assigns addresses 192.168.0.100-192.168.0.200 then you can set as Archer's address, for example, 192.168.0.2 (assuming that no other device has been manually assigned this address) - it is in the same network as router, it will not conflict with the addresses given by DHCP.
  • #3 18023270
    Vester11
    Rate: 49
    I bought an archera c20. As for the advice.
