Compatibility of Vaillant Turbotec 20kW Combi Boiler with Galmet Fusion Storage Tank
Lowell 21129 13
Can I connect a Galmet Fusion stratified storage tank to a Vaillant Turbotec 20 kW combi boiler to get the comfort of a hot-water tank without replacing the boiler?
Yes, a stratified storage tank of this type can be connected to a 2-function/combi boiler, but it has to be a setup the boiler can actually control with a charging pump and tank thermostat; similar solutions are sold as Galmet/Euroterm and DeDietrich SW100 for 2-function boilers [#17986881][#17987114] The tank works by sending cold water into the storage tank, and when the tank temperature drops below the set point, the pump forces flow through the boiler so it heats domestic hot water until the thermostat is satisfied [#17986881] However, it is still essentially a flow-based system, so the improvement in comfort may be limited and not as “tank-like” as expected [#17986458][#17988239] One reply warned that if the boiler has a fixed 15°C hysteresis, the system may need a much higher target temperature, which increases scale risk in the plate heat exchanger and can make the benefit disappointing [#17988239][#17988480] Hard water makes the scaling issue worse, and one suggestion was to check the boiler’s available controls/options or ask the manufacturer before buying [#17987114][#17986545]
  • #1 17986344
    Lowell
    Rate: 9
    I have a Vaillant Turbotec 20kW combi boiler. Unfortunately, it does not work well with hot water - it is impossible to bathe in 2 bathrooms at the same time.
    After negative experiences with flow water heating - I am determined to buy a tank, but I would not like to buy a new central heating furnace. Will Galmet Fusion work properly with my boiler? Is there any other product on the market that I can connect to my boiler and that will give me the comfort of a storage tank?
  • #2 17986408
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    Can't seem to connect. Solar panels may be the solution. In such systems, hot water is dangerous with the central heating circuit. This is taken into account in the software and boiler control.
  • #3 17986442
    Lowell
    Rate: 9
    Why can't I connect? The manufacturer on the product page writes: "It has been designed to work with combi gas boilers and take advantage of the natural advantages of layering heated water. Hot water heated in a gas boiler first accumulates in the upper part of the tank from where it is taken to the domestic hot water system. This allows you to draw hot water without frequent start-up of the gas boiler. This solution guarantees significant gas savings and extends the life of the boiler. The waiting time for hot water is also significantly shortened, compared to the use of a gas boiler alone."
  • #4 17986458
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    It still works on the flow principle. If we assume that the water for use will be taken overnight, e.g. it turns out that the temperature in the tank has dropped so much that it is too cold, then in order to obtain the set value, for example, the entire tank must be poured into the bath.
    You can try, but I haven't come across such a solution. On such a rock. There are so-called boilers with warmer Wodyńska comfort, but the tank is small, 30-40 liters, to prevent the boiler from being switched on, e.g. when rinsing a glass.
  • #5 17986528
    Lowell
    Rate: 9
    But if I understand correctly, then there is an additional circulation pump. If the temperature in the tank drops, the water will be heated, right?
  • #6 17986545
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    I don't know. It's probably like that at the factory. The water is heated to maintain the temperature. And when used a lot, it is heated up to date. The solution may be an electric flow heater. Check what Google says about it. How does this relate to your boiler. Have you asked the manufacturer?
  • #7 17986881
    ls_77
    Help: 500
    Rate: 947
    You can connect this tank, but I have not seen it in use anywhere and I do not know how it works. In theory, it looks good. A similar tank is offered by Eutoterm. They also have their 2-function condensing boilers and they also sell them in packages. Biawar also used to offer such a boiler, but they no longer produce it.
    Here the principle is that cold water flows into the tank. There is an adjustable HUW thermostat in the tank. If the water in the storage tank is colder than the set point, the charging pump is activated, which forces the flow through the 2-function boiler where cold water is normally connected. The movement of water through the pump forces the boiler to heat HUW (as if we turned on the tap with DHW). The pump works until the thermostat in the tank reaches the set temperature.
  • #8 17987114
    krzyzak11
    Level 19  
    Help: 25
    Rate: 100
    There are dedicated tanks for 2f boilers
    such, for example, is the SW100 DeDietrich
    https://dedietrich.pl/produkty/wyposarzenie/heaters-cwu/sw-100/
    The problem may be with hard water, then the plate heat exchanger will scale
    I do not recommend doing too much circulation (additional waste of energy)
    Krzyzak11
  • #9 17987575
    BUCKS
    Help: 536
    Rate: 1087
    Lowell wrote:
    it is not possible to bathe in 2 bathrooms at the same time.
    I have a Vaillant atmospheric 24kW twisted to approx. 17kW and I can easily take a shower in the bathroom + you can turn on the tap in the kitchen and I do not feel any decrease in comfort in the shower, so in theory you can use 2 taps.
    Although it actually gives too small flows to talk about fully comfortable 2 showers, but if you are stubborn, you could try something there.
    Only I have an apartment, so the cold tap water is warmer than in a detached house, and additionally my boiler is after my private modernizations, so it offers higher comfort than the factory version.
    Remember that this works both ways.
    If you buy a stratified tank for a 2-function boiler now, then if you need/want to replace the boiler in the near future, the new boiler will also have to be a 2-function boiler.
    Otherwise, you will have to buy a new tank with a coil together with a new 1-function boiler.
    I rather doubt that the old boiler will last another dozen or so years before you decide that the tank would be worth replacing and then you could buy a new set with peace of mind.
    Much depends on the options available in the boiler.
    There is a comfort feature in my Atmosphere which is ideal for use with a stratified storage tank.
    The disadvantage of my boiler is the fact that the hysteresis is constant and amounts to 15 degrees, so if we take 38 degrees as the minimum temperature at which heating will be activated, the target temperature must be at least 53 degrees, which means that the plate heat exchanger will be more exposed to precipitation scale and due to the rigid hysteresis of 15 degrees, the thermal comfort will be the same.
    The cartridge will improve something, but the effect can be a bit disappointing.
    Unless we will try to use some external thermostat to control the boiler operation cycles in hot utility water mode with lower hysteresis, e.g. 10 degrees, etc.
  • #10 17988239
    Lowell
    Rate: 9
    This is Galmet but sold under the Euroterm brand.
    In my opinion, this is an absolute lack of comfort. First, I turn on the tap, wait God knows how long for hot water (quick washing of hands is always cold), then when the heat is running, when someone else turns on the tap, the temperature drops again. There is no question of ecology at all - you can't take a shower in such a way as to use hot water, turn it off for the time of soaping, and then turn it on again, the water has to pour all the time. Very annoying, hence my search for a tank for this boiler.
    Added after 50 [seconds]:
    Thanks, that's what I was after. This product looks very good.
  • #11 17988480
    BUCKS
    Help: 536
    Rate: 1087
    Lowell wrote:
    In my opinion, this is an absolute lack of comfort. First I turn on the tap, wait god knows how long for hot water (a quick hand wash is always under ice cold),
    You will always have the same effect, regardless of whether you heat domestic hot water flowing or with a tank. The only solution to this problem is to install the boiler right next to the tap, but there will always be another tap that will be further away and therefore you will wait longer for hot water. Only hot water circulation will provide the greatest comfort, but it also means an increase in costs if it was to run non-stop, so for this reason some people use circulation activated manually on demand or automatically at certain times if you have a constant daily cycle of using hot water
    Lowell wrote:
    then when the heat is flowing, when someone else turns on the tap, the temperature drops again.
    It's a matter of proper regulation.
    If the boiler offers a capacity of, for example, 10 l/min, then the sum of water flows when using 2 taps should not exceed 10 l/min, which gives an average of 5 l/min per one tap.
    A minimum of 6 l/min is assumed for the shower to be considered as comfortable.
    So for 2 showers you would need a capacity of 12 l/min.
    You limit the flow of water, e.g. with aerators with selected flows,
    If you have standard aerators, there are no strong ones, but the flows on both taps exceed the technical capabilities of the boiler and hence the cold water.
    I usually use one tap, so I don't have a problem. However, despite this, I adjusted the installation so that even with 2 taps there was no problem with cold water in the shower.
    At my place, you can turn off the tap for the time of soaping and turn it on after a while.
    Only in winter you have to be careful, because if the boiler is heating, turning off hot water means switching to central heating mode and hot boiler water will flow to the radiators, so turning hot water back on means waiting a while, because there will be a wave of cold water and after a while it will be warm again.
    When using a 2-function boiler, it is very helpful to understand the idea of how the boiler works, i.e. how the hot water in the radiators and tap is obtained.
    It was only when I understood this that I could take conscious and deliberate actions to get the best possible results using the available resources.
    The tank increases comfort and when replacing the boiler with a new one, I plan to install a 1-function + tank with a coil, but there is no circulation in my place and at least I am not planning to do a mega renovation to install it. Even so, it's still a comfort for me.
    However, with a 2-function boiler, it is also possible to use hot water quite decently, although without circulation, you can forget about washing your hands quickly in hot water. This is where I got used to the cold, so I don't need circulation, because the costs of renovation and its burdensomeness to set up circulation are too big for me to treat circulation as something worth attention.
    If someone is doing a general renovation of the apartment, then it is worth installing a circulation system, but after a general renovation, another renovation for the circulation is pointless.
  • #12 17996171
    subratri
    Rate: 12
    hello, the problem of the creator of the thread has probably been solved, so I'll join in on a similar one ;)
    I already have a 300-liter solar-heated tank, I've done it so that I already have a lot of hot water. Well, you only know how the sun is ;)
    I am at the stage of setting up gas, choosing a stove and also heating water :)
    Plumbers insist on loading my large tank with gas, because the upper coil heats it up quickly, etc.
    I, on the other hand, originally had the idea to buy a stove with instantaneous water heating and power the stove from my large boiler. Then, when I have water from the sun, I don't touch the gases, and when it's there ... let's say 30 degrees, I only heat it up.
    Now I'm thinking whether or not to invest in this tank as in the link at the top.
    I would give him water from ... then basically a sun-heated buffer.
    What do you think?
    The initial choice of the oven is duocompact +24 and probably a controller for two circuits (because there are many floors)
  • #13 17997823
    krzyzak11
    Level 19  
    Help: 25
    Rate: 100
    I understand that your 300l tank has two coils?
    You attach dollars to the bottom and they heat 300 liters of water
    You raise the 1f boiler to the upper one and it heats about 120-140l of water. The phenomenon of heat transfer is used here. Hot water goes up.
    You receive the controller for the boiler so that you can set the hours of hot water heating
    You set them, for example, from 6 to 9 and then from 19 to 23. If solar is not recorded, the boiler is well placed in the upper part of the tank.
    At other times the water is cooler (e.g. 40 degrees) but not cold.
    Circulation as long as it is limited to a minimum by the timer
    Check out Junkers zsb24-5c plus cw400 as long as you have a good service in the area
    The Cw 400 performs for you with all of this
    Unless you have a solar controller yet, there is also a control module and then the cw400 manages the entire heating system
  • #14 17998471
    subratri
    Rate: 12
    Okay, thanks for the answer. Yesterday I fought the topic quite intensively and I drew amc25 from de dietrich. It won with extensive automation and deep modulation. And the price is relatively low compared to comparable ones. At least those that I was able to check, although in fact there are so many of these boilers on the market that it is impossible to bite into it.
    This five allows me to timer program the heating of the keg.
    I think there is much less than half of the top coil in my storage tank. If I remember correctly it's 100 or even 80l.
The discussion revolves around the compatibility of the Vaillant Turbotec 20kW combi boiler with the Galmet Fusion storage tank. Users express concerns about the boiler's inadequate hot water supply for simultaneous use in two bathrooms. Suggestions include using a storage tank to improve hot water availability, with some users noting that the Galmet Fusion is designed to work with combi boilers, allowing for better hot water layering and reduced boiler cycling. However, there are warnings about potential issues with flow rates and the need for proper regulation to ensure sufficient hot water delivery. Alternatives like Eutoterm and DeDietrich tanks are mentioned, along with the importance of considering future boiler replacements and the implications for tank compatibility.
TL;DR: Want two showers? You’ll need about 12 l/min; “A minimum of 6 l/min is assumed for the shower to be considered as comfortable.” A stratified tank can raise comfort but boiler hysteresis and flow limits still apply. [Elektroda, BUCKS, post #17988480]
Why it matters: This FAQ helps owners of Vaillant Turbotec 20 kW and similar combi boilers who want storage‑like hot water comfort without replacing the boiler.
Will a Galmet Fusion (stratified) tank work with my Vaillant Turbotec 20 kW combi?
Yes. A stratified tank can be connected to a 2‑function combi. In this setup, the tank’s thermostat and a charging pump trigger the combi’s DHW heating path until the tank reaches set temperature. In theory, it improves comfort. [Elektroda, ls_77, post #17986881]
How does a stratified add‑on tank for a combi boiler actually work?
Cold mains water enters the tank. A DHW thermostat in the tank starts a charging pump when the tank is below setpoint. The pump forces flow through the combi’s DHW inlet, making the boiler heat as if a tap opened. It stops at setpoint. [Elektroda, ls_77, post #17986881]
Can my 20 kW Vaillant run two showers at once?
Plan for about 12 l/min total if you want two comfortable showers. “A minimum of 6 l/min is assumed for the shower to be considered as comfortable.” Use flow‑limiting aerators so combined flow stays within the boiler’s capability. [Elektroda, BUCKS, post #17988480]
Will adding a tank eliminate the long wait for hot water at taps?
No. Without a DHW circulation loop, you still wait for hot water to travel through the pipes. Circulation provides the greatest comfort, but it increases costs; many users trigger it on‑demand or on schedules to balance comfort and efficiency. [Elektroda, BUCKS, post #17988480]
Do I need to worry about limescale or wasted energy with this setup?
Yes. Hard water can scale the combi’s plate heat exchanger. Also avoid excessive DHW circulation because it wastes energy. Keep circulation minimal and consider water treatment if scale is a known issue. [Elektroda, krzyzak11, post #17987114]
Are there off‑the‑shelf tanks designed for combi (2‑function) boilers?
Yes. “There are dedicated tanks for 2f boilers,” for example the DeDietrich SW100. Such products are intended to pair with combi units and improve DHW comfort while integrating controls and hydraulics. [Elektroda, krzyzak11, post #17987114]
If I add a stratified tank now, am I locked into combi boilers later?
Yes. A stratified tank pairs with 2‑function boilers. If you later want a 1‑function boiler, you’ll need a coil cylinder instead. Plan your upgrade path to avoid replacing a compatible tank prematurely. [Elektroda, BUCKS, post #17987575]
Does boiler DHW hysteresis impact comfort and scaling with a tank?
Yes. One example notes “the hysteresis is constant and amounts to 15 degrees.” If heat starts at 38°C, a 53°C target is required, which can raise scale risk and keep comfort changes modest. [Elektroda, BUCKS, post #17987575]
Is a small 30–40 L micro‑storage an alternative to a full tank?
It helps with short draws by avoiding burner starts, but it’s not for bathing. Typical micro‑storage volumes are ~30–40 L, meant to smooth brief uses like rinsing a glass, not sustain two showers. [Elektroda, bumble, post #17986458]
How do I connect and control a stratified add‑on tank with my combi?
Do this:
  1. Fit a DHW thermostat in the tank and set the target temperature.
  2. Wire the thermostat to a charging pump on the tank’s circuit.
  3. Pipe the pump to circulate through the combi’s DHW path; the pump stops at setpoint. [Elektroda, ls_77, post #17986881]
Why does my shower go cold briefly when I pause it in winter?
When you stop DHW, the combi can switch to space‑heating mode. Reopening the tap sends a brief cold slug before DHW resumes. Expect a short delay before hot returns; keep DHW open or adjust usage to avoid toggling. [Elektroda, BUCKS, post #17988480]
I have a 300 L solar cylinder—what’s a smart way to add gas backup?
Use solar on the lower coil and a 1‑function gas boiler on the upper coil, heating roughly 120–140 L. Program DHW heating windows, e.g., 6–9 and 19–23. Keep circulation minimal via a timer to limit losses. [Elektroda, krzyzak11, post #17997823]
Is Euroterm’s stratified tank the same as Galmet Fusion?
Yes. One owner notes the Euroterm‑branded unit is Galmet sold under the Euroterm brand. This helps cross‑reference documentation and parts. [Elektroda, Lowell, post #17988239]
Do I need an extra pump with a Galmet/Euroterm stratified setup?
Yes. The tank uses a dedicated charging pump controlled by the tank thermostat. That pump forces flow through the combi’s DHW circuit during charging until the tank reaches setpoint. [Elektroda, ls_77, post #17986881]
Is integrating solar DHW with my heating circuit risky?
It can be if controls are incorrect. “In such systems, hot water is dangerous with the central heating circuit. This is taken into account in the software and boiler control.” Follow manufacturer control logic. [Elektroda, bumble, post #17986408]
