Boiler Upgrade for 100m2 House - Comparing CO, SSC, ACV, Immergas Models
d0minero 6972 13
What condensing boiler setup and model should I choose for a 100 m2 house with three people, bath use, and limited space for a hot-water tank: a combi boiler, a single-function boiler with a tank, or a model with a built-in tank?
For your 3-person household and bath use, a single-function condensing boiler with a DHW tank/coil is the most comfortable solution if you can fit it, because a small built-in tray can still lead to shower temperature drops under heavier hot-water use [#16203911][#16209083] If space is tight, one forum suggestion was a wall-hung 1-function boiler such as Termet Gold Plus 20 plus a separate 100 l Biawar Quattro coil tank, and the boiler itself only needs about 20 kW for this kind of installation [#16206688] If you want an all-in-one unit, people pointed to Termet Ecocondens Integra II 25 (2.8–25 kW, built-in 45 l tank) and Beretta Mynute Boiler Green 25 BSI as candidates, but the lower minimum power is considered better because it matches low heat demand more closely [#16204371][#16207009][#16208285] Also, use a weather regulator with an outdoor sensor so the boiler runs at the lowest water temperature needed, which increases condensation and savings [#16208285]
  • Seeking boiler and DHW storage recommendation for 100 m² house
    #1 16203853
    d0minero
    I was browsing through this forum and searching a lot on the internet about highly effective CO and SSC gas boilers, but I only have a confusion about it, hence the request for help in choosing.
    I have a 100-meter house to be heated, in a mixed manner: partly brick, partly wooden, with a floor on joists.
    Wall insulation is 10 cm ceiling
    When it comes to SSC, I have one bathroom, but the household (3 people in total) like baths :) and the current furnace (junkers Eurostar ZWE 24) heats through flow.
    I would like to replace the boiler with a more efficient, cheap in operation and durable (I heard that ACV or Immergas are good and have a 5-year warranty), and also provide greater comfort of using DHW. I was thinking about 2-function, hanging stoves, perhaps with a built-in tank, within 6-7 thousand. It won't be easy for me to find a place to put the tank next to it.
    A cordial request for advice on the brand, model, or solution to the issue of whether 1 or 2 functions.
  • Built-in 6–8L tank may struggle with simultaneous showers
    #2 16203911
    dragon10
    Help: 12
    Rate: 12
    Good day.
    Privately, I have a single-function Junkers (open COMBUSTION chamber) and a 60-liter DHW tank.
    The furnace has been operating since 2002 without major problems (cleaning once a year).
    House 120m2 + 35 m2 garage. It works so far.
    We have a 2-function Immergas Victrix Zeus with a built-in tray (6-8l).
    CO works fine, but DHW sometimes fails. After work, there is a noticeable drop in temperature in the shower with greater reception (130 m2, 2 bathrooms).
    A good tray is a cool thing, it gives a buffer.
    Maybe newer furnaces don't have such problems anymore.
  • #3 16204371
    serwo66
    Help: 61
    Rate: 292
    Termet Ecocondens Integra II with a power of at least 2.8-25 kW with a built-in 45 lt storage tank. I installed and launched them with 15 zst without problems.
  • #4 16205192
    d0minero
    Interesting proposal, thank you. It's just that the boiler costs 10,000 according to the price list ... On the net like from 5,500, but I'm not sure if exactly the same model. They offer a long warranty, so I will definitely take that into account :)
    Any other suggestions, gentlemen, or opinions about Termet boilers?
  • #5 16206219
    d0minero
    dragon10 wrote:
    Good day.
    House 120m2 + 35 m2 garage. It works so far ..
    Thank you. As I mentioned, I am not able to find a place for the tray, unfortunately, and I estimate that it should be twice as large (about 120l) so that it is really worth taking seriously :)
  • #6 16206688
    ls_77
    Help: 500
    Rate: 947
    As a colleague wrote earlier, you have a Termet Integra 25 boiler. Its overall dimensions (height x width x depth) are 815x795x410 mm.
    You also have the option of hanging a 1-function boiler, e.g. for comparison, Termet Gold Plus 20 with dimensions of 750 x 400 x 349 mm + next to it you hang a container with a 100 l Biawar Quattro coil with dimensions (1033 x 506 x 501 mm) and with slightly larger dimensions you have the entire heating center taken care of. And yet - the boiler only needs 20kW, so you can safely throw the flue gases outside through the wall.
  • #7 16207009
    d0minero
    And what do you think about such a proposal: Beretta MYNUTE BOILER GREEN 25 BSI, also with a tray?
    Its power range is 6 - 25, but I do not know if it is worth having an even smaller power, like Termet Integra?
  • #8 16207035
    tomek3108
    Help: 8
    Rate: 53
    For 3 people, instead of combining with storage tanks, it is proposed to consider the installation of a combi oven with a decent large exchanger and there will be no problem with DHW.
  • Shortlisting Beretta Boyler Green 25 and Termet Integra 25
    #9 16207793
    d0minero
    It will most likely be so. However, choosing a boiler is not that easy :)
    I am currently considering the aforementioned 2, i.e. Beretta Boyler Green 25 and Termet Integra 25
  • Low minimum power and weather compensation improve efficiency
    #10 16208285
    ls_77
    Help: 500
    Rate: 947
    The lower the minimum power - the better. Then the boiler adapts better to the heat demand, especially during the periods: the beginning of the season and the end of the heating season - when the demand for heat is the lowest.
    A weather regulator with an external temperature sensor should be connected to the condensing boiler, then the boiler works with the lowest boiler water temperature needed at a given moment, and the lower the water temperature, the greater the condensation phenomenon and greater savings.
  • Lower minimum power improves seasonal efficiency and modulation
    #11 16208423
    d0minero
    Ok that's clear. I am simply wondering if the difference between 3 and 6 kW of minimum power is really significant?
  • Prefer Buderus or Junkers with a 26-plate DHW exchanger
    #12 16208450
    tomek3108
    Help: 8
    Rate: 53
    It is known that the boiler is chosen your whim, but from what I see, Termet EcoCondens Integra II 25 costs 10,000 without a discount, so I personally would prefer to buy something from Buderus or Junkers (the same Bosch capital group) and instead of a 45l tray on the wall next to the boiler large 26-plate DHW exchanger. When choosing, make sure you have any sensible service of the selected company in the area "just in case" ;)
  • #13 16209083
    ls_77
    Help: 500
    Rate: 947
    Do not look at the list price: Termet Ecocondens 25 Integra II
    And I prefer an exchanger with a coil than a plate exchanger, which is more limescale.
    I am always betting on a solution: a hanging boiler + a tank with a coil (even of the smallest capacity). Vaillant has this solution with a 75 l container that is hung next to the boiler - it has the same housing as the boiler, so two identical devices hang next to each other - but the price, unfortunately, as from outer space.
  • #14 16221574
    d0minero
    Ok, thank you for your help and I'm closing the topic
The discussion revolves around selecting an efficient gas boiler for a 100m2 house with mixed construction (brick and wood) and specific domestic hot water (DHW) needs. The user seeks a replacement for their current Junkers Eurostar ZWE 24, aiming for a more durable and cost-effective solution. Recommendations include various models such as the Immergas Victrix Zeus, Termet Ecocondens Integra II, and Beretta MYNUTE BOILER GREEN 25 BSI. Key considerations include the boiler's power output, the option for a built-in storage tank, and the importance of a low minimum power for better heat demand adaptation. The discussion also highlights the advantages of using a coil exchanger over a plate exchanger for DHW efficiency.
