[Solved] Transfer Windows 10 Pro License from Lenovo T520 to T530: Upgrading from Win 7 with Sticker
mailak 11430 12
Can I transfer my Windows 10 Pro upgrade license from my Lenovo T520 to a new Lenovo T530, if the original license came from Windows 7 and I have the Windows 7 sticker key?
You usually cannot legally transfer that Windows 10 Pro upgrade to the T530 if the original Windows 7 license was factory preinstalled/OEM; in that case the license stays with the original device [#18043404][#18043979] Only a standalone/retail (BOX) license can be moved to another device, and then it must be removed from the old PC first [#18043979][#18043799] The thread also notes that, in practice, “transfer” means installing Windows on the new machine and activating it with the appropriate key from the label, not sharing one license between two computers [#18043799]
  • #1 18043085
    mailak
    2 years ago I bought a Lenovo T520 with Windows 10 Pro EN x64, a license from an upgrade from Windows 7, I have a Windows 7 sticker.
    Currently I bought a more powerful computer Lenovo T530 (2x more RAM, bigger hard drive, USB 3.0). How can I transfer the license?
  • #2 18043089
  • #3 18043098
    kociol96
    Help: 39
    Rate: 45
    On the T530 there should also be a sticker with a windows key. Download 10 and use the key from 7.
  • #4 18043131
  • #5 18043404
    Matuzalem
    Help: 1653
    Rate: 1101
    If the base system - here: Windows 7 - was preinstalled at the factory, then legally license transfer you can't . It results directly from point 4 lit. a \ Windows 10 license terms.
    If so, then as well as suggesting the use of a key from a sticker from old equipment, in this case, you can "recommend" the use of any activator (for Windows 10) - the end result will be better, because the acceptance of the key may be different (not necessarily at the stage of its typing during installation), and the activator will work for sure.
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #6 18043543
  • #7 18043656
    Matuzalem
    Help: 1653
    Rate: 1101
    Tomequ123 wrote:
    More important than Microsoft's ridiculous law (based on Microsoft's cash register) is the law established by the Union for Europe, so the key can be transferred.
    Please first read the judgment of the CJEU (its content, at least in these important passages, is available), to which everyone now so commonly refers, and then check whether it applies in specific conditions.
    Supporting question: Why in the case of Windows 10, the License Terms in Section 4 consists of two parts - lit. a \ ib \ (distinguish between two factual states)? - And please do not mix the terms OEM and BOX, because such terms do not appear in this document.
    Tomequ123 wrote:
    Using an activator is associated with the risk of data theft, system infection, etc.
    And this, and not the issue of legality, is, in your opinion, the most important issue? If so, I can assure you that I know at least a few activators and sources from which to download them, without risk (infecting the system to be activated).
    Doradztwo podatkowe
  • #9 18043799
  • #10 18043979
    Matuzalem
    Help: 1653
    Rate: 1101
    Ladies annmedia:
    4. Transfer. The provisions of this section do not apply if you acquired the software in Germany or other countries listed on this page (aka.ms/transfer), in which case all transfers of the software to third parties and the right to use it must comply with applicable law.
    a. Software pre-installed on the device. If you acquired the software preinstalled on a device (or if you upgraded from the software preinstalled on the device), you may transfer the license to use that software directly to another user as long as you simultaneously transfer the licensed device to that user. This must include the transfer of the software, if one came with the device, as well as the original Windows product key label. Before receiving the software, that user must agree that the terms of this agreement apply to assigning and using the software to another user.
    b. Standalone Software. If Licensee acquired the software as standalone software (or if Licensee upgraded from software acquired as standalone software), Licensee may transfer the software to another Licensee's device. You may also transfer the software (with the license) to another device owned by someone other than you, provided that (i) you are the first licensed user of the software and (ii) the new user accepts the terms of this agreement. You may use a backup copy or genuine software media as permitted by Microsoft to transfer the software. Any time the software is transferred to a new device, you must remove the software from the previous device. The licensee may not transfer the software so that licenses can be shared between devices.
    since
    anmedia wrote:
    ... the BOX version has a different license than the OEM ...
    then please indicate which version the above fragment comes from and present a quote from "the second". A quote documenting the difference the Lord wrote about.
    Just please do not rush to reach for licenses other than for Windows 10 - this thread is about this system.
    Lest it was that a system installed "loosely" can always be moved - there is one and this is an undocumented exception. It applies to licenses obtained as a thank you for participating in the Insider program before the premiere of Windows 10. In this case, not only the license cannot be transferred, but even minor hardware changes can cause - and often cause - the loss of activation.
    Point 4 of the license terms as quoted above have been in force for well over 4 years (for about a year after the premiere of Windows 10, they looked different, but this is a completely different story. A story that only those who not only have a good memory, but also have the habit of knowing "what's going on in the license".
    PS
    I would also be careful with OEM, as in the case of Windows 8, for example, there were two license versions. The differences between them can be easily checked today - the texts are available
    Doradztwo podatkowe
  • #11 18043987
  • #12 18044008
    Matuzalem
    Help: 1653
    Rate: 1101
    anmedia wrote:
    Watek concerns an upgrade license for Windows 10 from version 7.
    No - the thread concerns the right to migrate a Windows 10 license obtained as an upgrade from an older, qualifying version of the system - here: Windows 7 - acquired under the conditions described in point 4 (a). a \, to the new computer.
    There will be no further quotes from your post - it is a pity to translate half-truths and untruths. You use the word "legally" quite often, but in a misleading context.
    Really, please give up on such "explanations", because they only lead to the fact that simple matters - for people who do not suffer from functional illiteracy - result in dilemmas leading to misunderstandings, and sometimes myths that find crowds of publishers (because fit them). As a result, a legend is created that something is needed or something is allowed, because there are many voices on the Internet that this is what it is (and a billion flies cannot be wrong). I myself was a victim / perpetrator of such things in the case of the XP license, but then I read the CJEU judgment and I do not regret it.
    Doradztwo podatkowe
  • #13 18179332
    mailak
    First, the problem is not resolved.
    The EU provision by the order but M $ prevents the license from being transferred.
    In connection with the above, I am already writing from Linux Mint.
    Actually, I don't care about the precious M $ license anymore. Linux is 5x faster.
    I recommend Mint to everyone.
The discussion revolves around transferring a Windows 10 Pro license from a Lenovo T520 to a Lenovo T530. The user originally upgraded from Windows 7, which is validated by a sticker on the older device. Responses suggest attempting to activate the Windows 10 license on the T530 using the key from the Windows 7 sticker. However, legal concerns arise regarding the transferability of OEM licenses, which are typically tied to the original hardware. Some participants recommend using an activator for Windows 10, although this poses risks such as data theft. The legality of license transfer is debated, with references to EU law and Microsoft's licensing terms. Ultimately, the user expresses frustration with the licensing situation and considers switching to Linux Mint.
TL;DR: Windows 10 license transfers follow 2 paths; “as long as you simultaneously transfer the licensed device.” Retail/standalone upgrades can move. For ThinkPad T520→T530 owners, this FAQ explains legal transfer, activation, and alternatives. [Elektroda, Matuzalem, post #18043979]
Why it matters: It helps Lenovo owners avoid activation errors, license violations, and downtime when upgrading machines.
Can I move my Windows 10 Pro upgrade from a Lenovo T520 to a T530?
If your original Windows 7 was factory‑preinstalled on the T520, Section 4(a) binds the upgrade to that device. You cannot move it to the T530 unless you transfer the licensed device itself, including the original product key label. Buy a transferable license instead. [Elektroda, Matuzalem, post #18043979]
How do I know if my Windows 10 license is transferable?
Check how the qualifying Windows was acquired. Section 4 has two parts: 4(a) for preinstalled software and 4(b) for standalone software. Preinstalled upgrades stay with the device. Standalone upgrades can move, provided you remove them from the old device. Review your purchase records and media. [Elektroda, Matuzalem, post #18043979]
How do I move a transferable Windows 10 license to a new PC?
Use this 3‑step process:
  1. Remove Windows 10 from the old device.
  2. Install Windows 10 on the new PC.
  3. Activate using your standalone product key. This satisfies Section 4(b), which allows transfer to another device if removed from the previous one. [Elektroda, Matuzalem, post #18043979]
Can I use the Windows 7 COA sticker key to activate Windows 10 on the new ThinkPad?
Yes. Install Windows 10 and use the Windows 7 key from the COA sticker during activation. This approach often works when moving between compatible editions, assuming licensing permits the move. It is a straightforward activation attempt suggested by users. [Elektroda, kociol96, post #18043098]
Why did activation fail even after the key seemed accepted?
Key acceptance can differ between installation and later validation. Activation may appear to work, then fail during subsequent checks. This happens when licensing terms don’t permit the move or when the backend rejects the entitlement. “Acceptance of the key may be different.” Try a licensed path instead. [Elektroda, Matuzalem, post #18043404]
Does EU law override Microsoft’s transfer restrictions?
Do not assume broad transfer rights from the CJEU ruling. You must read it in context and check applicability. Windows 10 license terms still distinguish preinstalled and standalone cases, and those conditions govern typical transfers. Follow the contract terms that match your situation. [Elektroda, Matuzalem, post #18043656]
Are OEM and BOX labels relevant for Windows 10 licensing language?
The Windows 10 license text avoids OEM/BOX labels. It uses the conditions “preinstalled on the device” and “standalone software.” Base your decision on those definitions, not packaging names. “Please do not mix the terms OEM and BOX” for this document. [Elektroda, Matuzalem, post #18043656]
My new T530 has its own Windows sticker. Should I use that key?
Yes. If your T530 has a Windows COA sticker, install Windows 10 and use that Windows 7 key for activation. This lets you activate the new machine using its own entitlement rather than moving a non‑transferable license. Check the sticker under the battery or base. [Elektroda, kociol96, post #18043098]
Can I clean‑install Windows 10 after upgrading and skip entering the key?
After successful activation, you can reinstall Windows 10 cleanly on the same hardware without re‑entering the key. The activation service recognizes the device again. This keeps you compliant and simplifies future maintenance on that machine. Back up your files before reinstalling. [Elektroda, Anonymous, post #18043987]
I got Windows 10 via the Insider program before release. Can I transfer it?
No. Insider‑granted licenses from before Windows 10’s launch are a special case. You cannot transfer them, and even minor hardware changes can cause activation loss. Treat that entitlement as locked to the original configuration. Plan separate licensing for new hardware. [Elektroda, Matuzalem, post #18043979]
Can one Windows 10 license activate two PCs at the same time?
No. Section 4(b) requires removal from the previous device before transfer. “You may not transfer the software so that licenses can be shared between devices.” One license activates one device at a time. Deactivate before moving. [Elektroda, Matuzalem, post #18043979]
Is switching to Linux Mint a practical workaround?
Yes. One user reports Linux Mint ran about 5× faster on the same hardware and avoided licensing issues. This can extend older ThinkPad usefulness and reduce costs. Evaluate your app needs and hardware drivers before migrating. Test from a live USB first. [Elektroda, mailak, post #18179332]
Where can I read the exact Windows 10 transfer terms cited here?
See the quoted excerpt of Section 4 posted in the thread. It covers 4(a) for preinstalled software and 4(b) for standalone software. Use it to verify whether your upgrade is tied to the old device or can legally move. Keep the COA label safe. [Elektroda, Matuzalem, post #18043979]
