[Solved] LogilDA.dll Issue in Windows 10: Error with Module Not Found - Need Help Fixing
dyzio1414 18315 9
How can I fix the Windows 10 startup error saying LogilDA.dll (Logitech Download Assistant) could not be found without reinstalling the system?
Run the attached registry file, then run the short FRST fixlist and restart the computer; this resolved the LogiLDA.dll startup error [#18092638] The fix targets the Logitech Download Assistant Run entry that points to `C:\Windows\System32\LogiLDA.dll,LogiFetch` and also notes that it should restore proper handling of EXE and LNK files [#18092638] The original poster confirmed the problem was solved after following these instructions [#18092895]
  • #1 18086300
    dyzio1414
    Rate: 9
    I have a problem with Windows 10 on my laptop. The system works, loads, but to run anything on it is almost a miracle. After a while, the error pops up: "There was a problem starting c: \ ... \ LogilDA.dll. The specified module could not be found ..."
    I am asking for help in removing the defect without reinstalling the system.
    Regards, Dyzio :)
  • #3 18086412
    dyzio1414
    Rate: 9
    Thank you for your response.
    I am sending the requested files.
    • FRST.txt (87.85 KB) You must be logged in to download this attachment.
    • Shortcut.txt (43.65 KB) You must be logged in to download this attachment.
    • Addition.txt (26.86 KB) You must be logged in to download this attachment.
  • #4 18086525
  • #5 18087024
    dyzio1414
    Rate: 9
    I'm adding a fixlog from repair.
    The error keeps appearing and the system has not increased speed in its operation. Thank you very much for the help above, but could I ask for further attempts to solve the problem?
    Regards, Dyzio
  • #6 18087073
  • #7 18087106
    dyzio1414
    Rate: 9
    I'll call you on Thursday evening because I'm going on tour ?
  • #8 18092575
    dyzio1414
    Rate: 9
    I came back.
    I am sending the current FRST logs. Let's try to solve the problem again.
    • Shortcut.txt (36.87 KB) You must be logged in to download this attachment.
    • FRST.txt (81.82 KB) You must be logged in to download this attachment.
    • Addition.txt (24.65 KB) You must be logged in to download this attachment.
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Run the reg file from the attachment, then run a short fixlist and restart the computer as instructed:
    HKLM\...\Run: [Logitech Download Assistant] => C:\Windows\system32\rundll32.exe C:\Windows\System32\LogiLDA.dll,LogiFetch
    HKU\S-1-5-21-1850792351-1904756639-1746312852-1000\...\Run: [BingSvc] => C:\Users\Admin\AppData\Local\Microsoft\BingSvc\BingSvc.exe [144008 2016-02-12] (Microsoft Corporation -> © 2015 Microsoft Corporation)
    Task: {3BBCA1F6-68CF-41E3-B567-464080123385} - System32\Tasks\Microsoft\Windows\SideShow\SystemDataProviders => {7CCA6768-8373-4D28-8876-83E8B4E3A969}
    Fix from the attachment should restore proper handling of EXE and LNK files. If it is correct now, importing this file will not hurt you either.
    • exe_lnk_fix_w10.zip (1.32 KB) You must be logged in to download this attachment.
  • #10 18092895
    dyzio1414
    Rate: 9
    Thanks to everyone for your help. The problem was solved after following the instructions I got from dt1.
    I greet and wish you much success!
The discussion revolves around a LogilDA.dll error encountered on a Windows 10 laptop, which significantly hampers system performance. The user seeks assistance in resolving the issue without reinstalling the operating system. Initial suggestions include running the Farbar Recovery Scan Tool (FRST) and providing logs for analysis. Subsequent responses involve creating a fixlist and registry modifications to address the LogilDA.dll startup problem. After following the provided instructions, the user reports that the issue was resolved successfully.
