NICE remote gate and lighting control - integration and applications
ixs 2142 4
  • #1 18162297
    ixs
    Rate: 97
    I have a few questions about light and gate control:I have bought a NICE gate operator with WI-FI control option. I just need to buy a module....
    1 I am wondering how to optimally solve the whole control. I need a remote control for the gate, but I would also like to be able to add users authorised to open the gate, or copy a few remote controls to make them available to someone in an emergency...
    2.Secondly, I would like to install remote-controlled lighting in the driveway, or a remote control + option to switch the lighting on at night when opening the gate....
    3.Thirdly, I also have lighting around the house in the soffit which is controlled by a double switch (2 zones). I do not want to give up the functionality of switching this lighting on via a button, but would it be possible to additionally switch this lighting on via wi-fi? Now the question of an application to control everything. The NICE door has its own controller and application, could the other points be connected to the same application? What is the best solution...
    4.Another issue at the entrance will be intercom + electric lock, but the intercom does not have the option of opening from the outside, only with a key, could it be possible to add a reader, e.g. for a key ring?
    5.The last issue at the entrance will be a polagros warning lamp for a 10x10 post connected to a NICE drive with a white Led light function, how to connect this lamp so that the white light shines only at night?
  • #2 18162417
  • #3 18163912
    ixs
    Rate: 97
    And does anyone know if the NICE wi-fi moduf will be able to be plugged into any of these systems? At the moment the most important things for me are remote gate opening and the light on the driveway. Secondly, can anyone recommend a radio receiver with a long range for switching off the light in the driveway (from the house by remote control and from outside, it would be nice if it also had a timer option - range of approx. 100m)?
  • #4 18163978
  • #5 18164178
    ixs
    Rate: 97
    Exactly - I want to have one remote somewhere in the house at a fixed location, the receiver would be in the basement (I have a window there, I could somehow bring the aerial outside....I am just looking for a set), the other 2 or 3 remote controls at the car keys, then I switch on and off the light in the driveway from the house with the remote control, or when getting to the house I also switch on the light with one remote control (preferably also temporarily, so that it switches off by itself when I get to the house), with the other remote control I open the gate (the gate from the house at a distance of about 50m, so the remote control must have a longer range.... I need a wi-fi module for the gate to open the gate when no one is at home, and I also need to be able to temporarily enable someone from outside to open the gate - e.g. copy several remote controls, or add a user in the wi-fi application.
    another topic to be solved - there will be a warning light on a post with a white light function.... I am reading the instructions, the warning light comes from the drive, the power supply for the white light is any 12-24v power supply - so it would also be good to take constant voltage from the drive - it should be on the output which is also connected to the wi-fi module - the only issue is that the light does not light up all the time - it would be a good idea to mount it through a motion and light sensor so that it lights up when someone approaches the gate at night.... Does anyone have a reference to such a sensor? - Can it be any sensor or are there any other sensors for 12v?
