Integra 128 Plus: Controlling Driveway Lighting and Entry Gates via Mobile App
cino111 10128 8
  • #1 16370870
    cino111
    Rate: 10
    I want to connect the driveway lighting to the Integra 128 Plus Central Unit (with ETHM-1 Plus module) so that it switches on at a specific time according to the time set on the timer, but additionally from the Integra Control application installed on the phone. I managed the timer, sle set macros as output enable, change output status and nothing. He showed me once in the Outputs tab in the application, but after clicking on it he immediately returned to the previous position. Something I can't quite handle it. Please help, can I change the status of the outputs from the phone? I will also want to connect entry gates to open by phone.
  • #2 16370971
    dariusz.bembenek
    Stationary Alarms specialist
    Help: 455
    Rate: 615
    The outputs can only be controlled from the telephone, from the keypad, if they are programmed as:
    - MONO switch
    - BI switch
    - Roller blind up / down
    - Telephone relay.
    If the output is set to "26. Timer" then it will not be available in the "Control" menu and thus it will not be possible to "tap" it on the telephone to switch it on. If you need to control the output in various ways, such an output can be set as "Logical sum of outputs" and add the necessary outputs to this sum.
  • #3 16371296
    cino111
    Rate: 10
    I did just that. I have output 128 controlled by timer. 127 mono or bi uncontrolled (I want to manually switch it on from the phone) and output 5 logical sum of outputs 127 and 128. The problem is that the phone can not switch outputs. Only green or gray balls on or off are shown. Unless you have broken something after the last update of the app?
  • #4 16371316
    dariusz.bembenek
    Help: 455
    Rate: 615
    Which output do you want to control? You should be able to activate the output from the telephone 127. Because output 5 is SUM, so you won't be able to post from your phone ...
    If there is no 127 output in the telephone, then check in the output groups whether it is unchecked (it should be orange). Additionally, uncheck all outputs that are not to be visible in Integra Control.
  • #5 16371472
    cino111
    Rate: 10
    I want to manually control output 127. On start with Dloadx and Integra Control. By the way - how to change the names of exits? I can't change it by clicking on the name. So what's up with exit groups?
    Integra 128 Plus: Controlling Driveway Lighting and Entry Gates via Mobile App Integra 128 Plus: Controlling Driveway Lighting and Entry Gates via Mobile App
    DloadX output grouping and input-based gate status display
    #6 16371546
    dariusz.bembenek
    Help: 455
    Rate: 615
    The names of the outputs are changed in the DloadX program. The cursor will not show, but you can write. Select zones for BI switch because they are probably unchecked. As for output groups, this is the right window, but not this tab.
    What's up with exit groups? First of all, I refer to the instructions. And in general: you can group outputs, e.g. for blinds, lamps, gates, sprinklers (max. 4 groups). In addition, the second tab of this window allows you to show the output status by suggesting input, not output. Useful for gates when there is a reed switch.
    For now, it works on a physical LCD, on Integra Control it will work soon.
  • #7 16371665
    cino111
    Rate: 10
    Thanks a lot. It was enough to select the zones and I can control the output from the phone :)
  • #8 16373695
    darzec
    Help: 13
    Rate: 24
    "showing output status by input, not output" The function works after the last update, I have tested it and it is very useful.
  • #9 16373943
    dariusz.bembenek
    Help: 455
    Rate: 615
    Ok thanks for the info. Good case.
The discussion revolves around integrating driveway lighting and entry gates with the Integra 128 Plus Central Unit using the Integra Control mobile application. The user seeks to control the lighting based on a timer and manually via the app. Initial attempts to set up outputs were unsuccessful, as outputs configured with a timer were not accessible through the app. Solutions provided included ensuring outputs are set as MONO or BI switches and checking output visibility settings in the app. The user successfully resolved the issue by selecting the appropriate zones, allowing control from the phone. Additional insights on output naming and grouping were also shared, emphasizing the importance of following the instructions for proper configuration.
