PS4 Pad Issue - Reacts but Doesn't Charge: Socket and Battery Checked, Self-replacement?
Majorek89 19185 8
  • #1 18162416
    Majorek89
    The ps4 pad stopped charging at some point. It was running but not charging. When it died, I took it to the service technician who replaced the socket. After the replacement, he walked for a day. The service technician said that the socket is unobstructed and the battery is ok. I will add that when you click on the power button, the pad reacts for 5 seconds and goes out. What could be the problem? Could it be the charging system and can it be replaced by myself? Thanks in advance for any tips
  • #2 18162493
    2konrafal1993
    Help: 581
    Rate: 746
    It would be necessary to determine what went wrong, maybe it is enough to replace the battery, but also some integrated circuit may be damaged. You can check the battery with a meter to see if there is voltage and what is the value of this voltage.
  • #3 18162596
    Majorek89
    In theory, the battery voltage was checked by this service technician, so it should be ok, when I was with the others, after what I said, this front black panel was proposed to change, but for PLN 150, I recently found a new one on olx for PLN 116.
  • #4 18162640
    2konrafal1993
    Help: 581
    Rate: 746
    Are you trying to repair? If so, you need to measure. Or give it to someone who knows and can remove the fault, maybe the service technician is cheating on you and did something wrong and is afraid to admit it.
  • #5 18162653
    JoseArcadioMorales
    I too had a similar situation. Unfortunately, I ended up buying a new pad
  • #6 18163975
    Majorek89
    So it turns out that I will leave it for parts in case something breaks in the other one.
  • #7 18222396
    Monet24
    My friend is struggling with the same problem, I think I'm getting ready to buy a new one, unfortunately ...
  • #8 18222417
    Majorek89
    Yes, I already bought the second one, I'll drop it off for a friend and this one, well, I think it will go for parts.
  • #9 18370084
    Kamilos19
    I have a consideration that the pad did not charge and even on the battery it did not work I prepared a USB cable to the bottom and the pad works shows that it is charging And the battery is not inside and it works :)
The discussion revolves around a PS4 controller that stopped charging despite a socket replacement and a supposedly functional battery. The user reports that the controller reacts briefly when the power button is pressed but then shuts off. Responses suggest checking the battery voltage, considering potential damage to integrated circuits, and the possibility of replacing the front panel. Some participants share similar experiences, with a few opting to purchase new controllers instead of attempting repairs. One user mentions successfully using a USB cable to power the controller without the battery installed, indicating a potential workaround.
